Go to Post Who am I kidding, FIRST is so much cooler now than it was when I was a youngin'! - Michael Corsetto [more]
Unread 02-05-2016, 13:50
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of light
Re: New Off-season Defenses
Originally Posted by CalTran View Post
Spoiler for 10th Defense?:
As much as we'd love to cart Tim around to every off-season event, I think we'll have to pass. It was hard enough getting him to two event in two pieces.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 02-05-2016, 14:15
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Originally Posted by AllenGregoryIV View Post
Was this from HQ, Andymark, or someone else? I'm just wondering what off-seasons won't have the portcullis.
From Frank
the base of the defense will certainly be sent. The idea would be (for events that don't want to create a new defense, though I think that's a neat idea!) is that the 'Category A' defense would just be the CDF, so in that category, there would be no real option, the CDF would just be put on the field.
Unread 02-05-2016, 14:27
rlowe61's Avatar
rlowe61 rlowe61 is offline
AKA: Roger
FRC #0624 (CRyptonite)
rlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant future
I was thinking a rolling-log type of defense. Should be quite entertaining to watch robots try to go over some round-ish material(s) that can spin in place but not roll off the platforms.
This would be an easy design. 4" dia steel pipe set center of defense plate, with 1"-4" underneath (make it adjustable (1" increments) so the head ref pulls a number out of a hat for each time it's used)(or make it perm to the field like the low bar and set the height to pneumatics so the FTC can change randomly during a match). The end of the pipe would have end caps with bearing in them for it to rotate on (make it more fun, have the bearings off center so it has a cam effect).
Roger
1986, Team Titanium, 2011 - 2012
624, CRyptonite, 2013 - ????
Unread 02-05-2016, 14:31
Originally Posted by rlowe61 View Post
This would be an easy design. 4" dia steel pipe set center of defense plate, with 1"-4" underneath (make it adjustable (1" increments) so the head ref pulls a number out of a hat for each time it's used). The end of the pipe would have end caps with bearing in them for it to rotate on (make it more fun, have the bearings off center so it has a cam effect).
Or a series of smaller pipes, same general idea. Oughtta be quite "entertaining" (and maybe claim a few robots on the way...)
Unread 02-05-2016, 14:32
Professional Stat Padder
Originally Posted by chmconkling View Post
A set of boulders that are attached to the flat base that you have to drive over.
  • Boulders cut in half, then affixed flat-side-down to a base.
  • The platform without installing a defense (with no attachment, so that there's a lowered portion)
  • A big ramp to launch yourself into the courtyard, but almost impossible to cross backwards
  • A 2012 Bridge
  • a 2010 bump
  • A series of bungee cords strung across the base very close together
  • a Lunacy trailer you can push onto the batter that can replace a robot for the challenge requirement (or a tote or some other item to push onto the batter and can start on top of a defense platform)
  • A tall bar that can be hung from as a replacement for the hanging endgame
  • rolling bars
  • Just a platform, no defense on it, but you need to clear the other 4 defenses in order to get the breach
  • A bunch of 2013 frisbees
  • ACTUAL FIRE
(2015-Present)
Unread 02-05-2016, 14:37
jodge1706's Avatar
jodge1706 jodge1706 is offline
Captain | Driver | Bench Grinder
AKA: Gavin
FRC #1706 (Ratchet Rockers)
Team Role: Driver
jodge1706 is on a distinguished road
In the midst of craziness and rambling, here's an actual good idea
Just because you graduated doesn't mean you have to stop being a student....right?
2016 Championship Volunteer
2016 Robot: "MASTERKEY" | St. Louis Regional Semi-Finalists | Rocket City Regional - Spirit Award / Quarter-Finalists
Unread 02-05-2016, 14:42
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I think this would be a difficult change for FMS. Unless you just didn't get any points at all for crossing this defense in auto or teleop.
Unread 02-05-2016, 14:46
Wouldn't be all that hard, just gotta train the refs that if that defense was in play, it doesn't get entered as a crossing.
Of course, offseason events like to make up their own rules...
Unread 02-05-2016, 15:04
Brian Sherman Brian Sherman is offline
FIRST Mid-Atlantic Chairman
FRC #0708 (Hatters Robotics)
Brian Sherman is a splendid one to beholdBrian Sherman is a splendid one to beholdBrian Sherman is a splendid one to beholdBrian Sherman is a splendid one to beholdBrian Sherman is a splendid one to beholdBrian Sherman is a splendid one to beholdBrian Sherman is a splendid one to behold
MAR will also not be providing the portcullis to off-season events. If anyone (or group) wants to design and build a replacement defense, we have a few bases available.
PM or email me.
Unread 02-05-2016, 15:08
jodge1706's Avatar
AKA: Gavin
Team Role: Driver
Why don't we do that? It will still allow robots designed solely for crossing defenses would still be able to cross, and it would make it easier for robots designed to shoot to do that. If anything, it think it would make the game more exciting, more high scoring shots.
Unread 02-05-2016, 16:13
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
I wouldn't put nothing in the base- the holes in the platform for the defenses' wheels would be problematic for robot wheels.
A flat defense that you put in the slot with the mentioned rule change would certainly be interesting.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 02-05-2016, 16:25
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
"Why would they select to put nothing in the defense position? What is the other alliance playing at?? "
Originally Posted by Sun Tzu, Art of War
The whole secret lies in confusing the enemy, so that he cannot fathom our real intent.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 02-05-2016, 19:05
Originally Posted by waterwaterwater View Post
Ok, I know we were talking about the portcullis, but I have an idea to replace the drawbridge visibility issues. For both the sallyport and drawbridge, replace the wooden part with clear lexan, but insert a low bar sized cutout (with a few inches on each side) that robots can drive through. In order to make it more difficult than the traditional lowbar, doing the portcullis/sallyport the "proper way" (ie. without just driving through the cutout) earns one more defense crossing than it would normally (ie. proper earns both for the breach or 2 of the 3 if one more crossing is added to the rules).
Somebody pulls that, we'll have too big of an advantage. Fully damaged drawbridge/sally port in auto or something like that. Rewards very few of the teams for putting in a lot of hard work, penalizes the rest of 'em.
Unread 02-05-2016, 19:12
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Or the new pseudo low bar crossing adds one to your tower score.
You mean that they cross it like they would cross a drawbridge, right?
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 02-05-2016, 19:25
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
Spoiler for Full Summary of Idea:
The sally port and drawbridge will both have a slot cut out of them at the bottom, 14" high and with a few inches on each side. A team that crosses them without using these cutouts will receive one of the following (depending on which one the event organizer feels is the most balanced);
1. An extra defense crossing.
2. An extra (5?) number of points for their crossing.
Another option instead of rewarding the proper way is to penalize the new way by;
1. Making the crossing worth no points AND/OR;
2. Adding one to your tower strength.
That's answers my question. I just wanted to know if the defense being crossed like a drawbridge or a sally port (I didn't realize initially that the sally port was included) caused the special points/tower increase/etc. to occur. Thanks.
2. Wire the robot
7. Be active on CD
