Go to Post Besides, if you look back on anything you've already made and can't find any flaws that can be improved, you're doing it wrong. - artdutra04 [more]
Unread 18-04-2016, 14:34
Re: Predictions for Season High Score
The current high score of 257 will stand through champs.
Unread 18-04-2016, 14:35
EmileH's Avatar
EmileH EmileH is offline
uses the Talon SRX way too much
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Originally Posted by Richard Wallace View Post
60 pt auton. 20 teleop high goals. Breach, double tap Sally, capture, triple scale. No defense, no fouls.
That makes 285. I think it will happen in a stacked CMP qualification match.
At NE Champs, the #2 seed alliance of 195, 125 and 2168 had multiple runs with a 70 point auto due to 195's two ball capability. I doubt there would be a triple scale in a qual match, but it depends how much teams change between now and Champs.
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 18-04-2016, 14:37
Chris is me's Avatar
AKA: Pinecone
Agreed. It took a complete lack of presence in the secret passage for 257 to happen, and that quite simply will never happen again. Not to mention an alliance with the quality and depth to find three very proficient high goal shooters like that.
Unread 21-04-2016, 19:27
sysdes sysdes is offline
Engineering Mentor
AKA: Maurice Veldhuis
FRC #4678 (CyberCavs)
sysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant future
Originally Posted by EmileH View Post
Check out 4678. Their Sally Port/Drawbridge mechanism isn't that different from other teams' but the software makes all the difference:
http://watchfirstnow.com/archives/162638135
Very true. The programming of our sally port and draw bridge crossing is actually based on the code that 254 posted on their impressive, smooth and precise drive train motion control. We studied how they managed fairly complex motion like their auto in 2014 that allowed them to park up against the low goal before tossing the ball into the target to guarantee they couldn't be defended against.
Thanks to their willingness to share how they did it, we came to realize that the motion control profiles they described did not need to be restricted to just the drive train motors. Our Sally Port and Drawbridge crossings are pretty much automatic (in teleop, the operator just has to hold down a button as the programming goes through the motions). We use a system similar to their drive train motion profiling but we add in the 2 axes of our arm to go along with the motion of the drive train. To program the motion, we took our robot and placed it in front the defense. We manually put the arm into the starting position, recorded the encoder values and then moved the arm to what appeared to be a good "next position". We did this several times and recorded encoder values of the arm and the drive train encoders until we had moved the robot completely through the defense. Then we created code that would interpolate the encoder positions based on time and we just feed new position values to the Talon SRXs for the arm joints and do a similar position control of the drive train (using Victor SP's) at approximately 50 times per second. There are plenty of videos of the results.
Thanks again to team 254 for sharing their valuable insights (and code) on how to get the most out of the robots we build.
Unread 21-04-2016, 21:10
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Our HP's prediction- the Einstein finalist alliance will set the high score in division semis.
My prediction- 257 will remain the world high score until IRI.
Lead qualitative scout- 272 in Einstein semis.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 02-05-2016, 00:12
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
This
And this.
Unread 02-05-2016, 15:14
RoboChair's Avatar
AKA: Devin Castellucci
World High Scores
With 25 Foul Points (Carver QF3-2)
275 (250 without)
Teams 330, 120, 2481, 1086
Auto High Goal x2: 20pts
Auto Cross x3: 30pts
TeleOp Cross x5: 25pts
TeleOp High x19: 95pts
Scale x2: 30pts
Challenge x1: 5pts
Breach: 20pts
Capture: 25pts
Fouls: 25pts
Win Margin: 120pts
NO Fouls High Score (Hopper QF1-2)
270
Teams 148, 1678, 364, 2990
Auto High Goal x3: 30pts
TeleOp High x21: 105pts
Scale x2: 30pts
Challenge x1: 5pts
Breach: 20pts
Capture: 25pts
Win Margin: 140pts
World Combined High Score
480 Points (440 without)
Teams 148, 1678, 364, 2990 vs 4334, 294, 2013, 1732
Auto Cross x6: 60pts
TeleOp Cross x10: 50pts
TeleOp High x32: 160pts
Scale x2: 30pts
Challenge x4: 20pts
Breach x2: 40pts
Capture x2: 50pts
Fouls: 40pts
Win Margin: 40pts
11 Years and counting! Over a third of my life has been spent with FRC.
