Go to Post How easy will it be for a driver to control 5-6 different motions at once? Most drivers only have two hands. - Kevin Sevcik [more]
Unread 02-05-2016, 21:59
Chris is me's Avatar
AKA: Pinecone
Re: [MCC] Minimum Competive Concept 2016
There are several different robot designs this year that meet this criteria, I think.
Ultimately, the robot needs to do the following:
- Cross two defenses a match regardless of the configuration on the field (both defenses of one category + the low bar should do it)
- Pick up balls and score them in the low goal
- Stay on the batter
- Push
I do think you need a pickup to be consistently competitive. You can win events without one but you won't consistently seed well. This robot can seed #1 with some luck (or the ability to cross more than 3 of the 9 defenses).
