Go to Post If I run into some of your team's student coaches/drivers on the field of battle someday, I still might ask 'em what they're doing after high school. :) - Ken Patton [more]
Unread 23-03-2003, 17:00
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
power transmission NOT using gears/chains?
I was toying with possible gearbox/transmission ideas as a start for next year, and I was wondering if polyurethane or however that is spelled rollers would work to transmitt power like a gear.
specifically, I was thinking about MrB's white pages gear ratio thing that had an idea for a CVT at the bottom, and was wondering is high traction rollers would work.
overview: mrB had two cones side by side, one with the base at the top of the drawing, on with the base at the bottom, so there was a constant distance between them. And in between them was a gear/roller that could move in the space between them. At one end it was close to the base on one and the narrow part of the other, at the other end it was reversed . . so as you slide it back and forth the gear ratio changes. Gears could not work for this design, at least not without very very complicated tooth patters, and maybe not even then. But what if you used high traction rollers? It would even act as a clutch of sorts, if you could vary the tension.
so, how would I get good sticky stuff to put around cones? Also, the roller in the middle may be hard to move, so maybe an omni wheel type thing would be best. or just really powerful actuator to move it.
MrB's spreadsheet is here.
Well, really what I want is polyurethane/other sticky stuff suppliers to scout.
end.
Unread 23-03-2003, 21:31
Frank,
Detroit has been experimenting with continuously variable drive systems for many years. They have been particularly suited for hybrid or all electrical vehicles. I know there is a great amount of info out there beginning with Popular Mechanics going back many years. I am surprised to not have seen any popping up in our robot designs but I do keep watching for them. There are a number of teams that have taken the shifting idea to a logical integration in robot design. Of particular note is Thunder Chicken's multi-speed transmission of last year. I believe that there is a white paper on their design. It was not only impressively designed and implemented but was surprisingly small and very well engineered.
Unread 23-03-2003, 21:41
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
We have built a CVT
Our team has actualy built a CVT and it worked really well, but because of this years game we could not use it and fit everything else in to get under the bar.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 24-03-2003, 02:51
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
190 had a toroidal CVT last year, and will have one again this year if we can get it in under weight. The hard part about the CVT is programming it, as it is a very complex system to model.
There are many other kinds of CVTs out there, from the cone/belt design (like in the Honda Civic HX), to variable geometry designs, universal joint driven (Varibox), etc.
Zan Hecht
Unread 08-04-2003, 21:27
mjt902 mjt902 is offline
mjt902 is an unknown quantity at this point
i don't think anyone is still following this, but i am really looking for somebody who has knowledge of a robot clutch system that can shift on the fly?? i was informed earlier today that there were several teams that could, and me and a friend are wanting to make our own... are there any quick and easy (or long and ardruous) processes we might need to work through that you could help us solve??
Top Ten Reasons to Procrastinate:
1.
Unread 08-04-2003, 23:09
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
We don't use a clutch, but we do shift on the fly by using two sets of wheels, one large and the other small. You can see pictures at our web site. See below.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 09-04-2003, 00:01
I was talking to some of the guys on Christian Holland Team 107 at Midwest and they said they were working on a CVT drive system. They hadn't worked all the kinks out so they didn't include on this robot but what I had described to me sounded pretty cool.
Unread 09-04-2003, 00:52
Mike Rush's Avatar
Mike Rush Mike Rush is offline
Somewhat Insightful
FRC #4154 (Perpetual Recursion)
Mike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really nice
CVT
I know that 64 has a CVT this year. Don't know exactly how it is working out. Oh well, guess I'll find out in Houston...
Mike Rush - Engineer/Mentor
Perpetual Recursion (4154)
Arizona Community Team (1492)
2004 AZ Regional Woody Flower's Award
Basha High School & Intel (1456)
Gila Monsters (64)
Awards!?! Too many to list...
Unread 09-04-2003, 04:08
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
When I first saw these wheels, I thought they were spinning their wheels when they weren't even pushing! It took a little while to realize that those wheels weren't even contacting the carpet, and that they could lower them when they wanted to go fast.
Unread 13-04-2003, 14:24
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I thought they were different material for traction on the carpet and ramp, but then they were used on both. Very interesting idea.
116 designed a 2-speed transmission that can shift on the fly, and be built with limited shop capability. It is clutch less, but not extensively tested in competition.
This is from 2002, so note that the drill motor is different from this year. It was updated for the new drill motor, but no white page as yet.
http://www.team116.org/2002/EDTransmission.pdf
Wetzel
mmmm...manual shop tools
Unread 22-04-2003, 22:04
Jared Russell's Avatar
Taking a year (mostly) off
Take a look at team 45's ball drive demonstration bot...by far the most interesting drive train I've seen.
Unread 28-04-2003, 08:29
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
A CVT is very, very nice, but one draw back. Sure, you can have a huge "gear selection" but their 1 drawback is their ability to hold torque. I'll assume for FIRST drill motors, FP motors, and others in our kit, it will be fine, but that is why you don't see more CVTs out there today. Their belts will slip under that high torque demand situtation!
I have tought of cone-shaped gears or so. I'll be working on that during the summer and see if i can get it to work w/o the weight and size that I am currently thinking of!!
That rug really tied the room together...
Unread 28-04-2003, 10:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I don't think it will work at all. Either the cone gears will have a constantly varying pitch or more teeth will majically appear the further you go toward the larger side of the cone. Niether of those ways would work. So, unless you've got some patented gear technology I don't know about, you're probably bettr off sticking to high friction rollers or something of the sort.
Unread 28-04-2003, 15:48
AnimatorSarah's Avatar
AnimatorSarah AnimatorSarah is offline
AnimationObsessed
FRC #1507 (The Warlocks)
AnimatorSarah is an unknown quantity at this point
Not sure
I'm not sure if this will help but our team this year shifted on the fly by using a little pnumatic cylinder to shift back and forth. We also added a spring to help the cylinder shift back to high from low. I don't know if this helps you at all since I'm not exactly what kind of drive train your going for.
2003 Newton Division Winner
3rd place 2003 National Championship
1st place 2003 Canadian Regional Winner
2nd place 2003 Buckeye Regional Winner
2003 "Best Stack Smasher" from the Artic Warriors.
2003 "Most Feared Robot" and "Best Autonomous Function" from team 1064.
~from when I was on team 378 The Circuit Stompers
Unread 28-04-2003, 16:10
The Honda CIvic has a CVT in it.
One easy way to make a two speed tranny is to use the freewheeling mechanism on the back wheel of a ten speed bike.
(Not the shifter)
when you pedal a ten speed, as long as the wheel is going slower than the pedals, the pedals stay engaged. If you go down a steep hill, and dont pedal faster, then the pedals are just spinning, and the back wheel is going faster, right?
so you could have two separate motors driving a link the same way, with different gear ratios
when you are going slow, both motors will be engaging the wheel, and the high torque motor will be doing most of the work - once the machine gets beyond the top speed of the high torque motor its sprocket will freewheel (like the pedals on your bike) and the high speed motor will take over.
Only drawback, you cant go backwards, unless you add a reverse gear.
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
power to the pits Ken Leung Off-Season Events 12 11-05-2003 22:48
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
