Go to Post I don't think we really fit into those rigidly defined categories, my team builds our robot. - AdamHeard [more]
Unread 22-01-2002, 17:34
pavelthegeek pavelthegeek is offline
#0114 (Eagle Strike)
pavelthegeek is an unknown quantity at this point
Send a message via AIM to pavelthegeek Send a message via Yahoo to pavelthegeek
Team Update #3 is up
http://www.usfirst.org/robotics/2002/tmup3.pdf
Run! Don't Walk!
Paul Ivanov, Team 114
Unread 22-01-2002, 18:24
Jan Olligs's Avatar
Jan Olligs Jan Olligs is offline
#0448 (Crandroids)
Jan Olligs is on a distinguished road
Thanks a lot!
It is strange and yet weird, but when I opened the FIRST team update page, #3 was not listed. Nevertheless, your link works.
Seems as if FIRST forgot to post the link on the update page...
Thanks a lot, without you I would never have got to know that there was an update!
I have great faith in fools - my friends call it self-confidence. --- Edgar Allen Poe
Unread 22-01-2002, 19:15
Re: Thanks a lot!
Are you sure that you weren't looking at a page that your browser cached?
Unread 22-01-2002, 20:42
Jan Olligs's Avatar
#0448 (Crandroids)
Re: Re: Thanks a lot!
I just cleared the browser cache and reloaded, its still the old page. The only thing I can imagine is that it is cached on our school server and has not been reloaded recently. O fcourse, I can't find that out from my computer, but it is actually not hard to imagine...
Unread 23-01-2002, 02:14
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Update three says:
The following rules have been revised/clarified or updated
GM20. Robots may NOT intentionally:
- Tip any goal over
- Attach to the upper or lower plywood decks. (If enough
force is applied to either of these decks to move the goal
then you are considered to be attached).
- Deploy any sort of mechanism below the bottom plywood
deck or attach to the casters.
- Remove any of the 1” PVC from the goals.
GM21. In order to pick up or pull the goal in another direction, a
robot may ONLY grab onto the 16 metal pipes and their flanges
between the 2 plywood decks.
-- New Rule
GM 23. You may push on the vertical surface of the stainless steel
edges around the upper and lower plywood deck to move the goal in a new direction.
Is rule 23 superseding the other two? Because if you're pushing on a goal, and it moves, as 23 says you can, that would violate rule 20 as it is written above.
Someone help me out here.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 23-01-2002, 09:05
FRC Key Volunteer Trainer
AKA: CrazyNate
I think the main reason for the 2nd bullet in GM20 was to prevent teams from reaching between the plywood decks and pushing up on the upper deck to lift the goal. Thus, for goal interaction, I read it as follows:
-You can attach to the following surfaces:
*12" steel pipes
* pipe flanges
-You can push WITHOUT attaching to the following surfaces:
* VERTICAL face of stainless steel angle
Any other contact with the goal must fall under the rules listed in GM20.
Nate Smith
nsmith@smythsoft.com
Unread 24-01-2002, 08:07
Dr.Bot
Posts: n/a
O.K. Riddle me this riddler.
If your robot is wedge shaped and goes underneath the casters on the goal so that the goal rides up onto the robot, is this a violation? Is it a violation if your robot is stationary and someone
pushes or legally lifts a goal and places it on you robot?
Unread 24-01-2002, 12:42
Andy A. Andy A. is offline
Getting old
FRC #0095
If some one pushes the goal onto you or in some way makes you tip or otherwise interact with the goal in a way that is against the rules, it isn't your fault. But of course, thats up to the refs.
As for the wedge, I think any contact with the casters is illegal, unless it's unitentional. But again, up to the refs. If you keep interacting with the goal against the rules, your fault or not, the judges may decide your bot is just designed poorley and make you change it.
I get the feeling that FIRST got real tired of duck taped goals last year.
-Andy
Unread 24-01-2002, 14:51
Dr.Bot
Posts: n/a
I don't think it was the ducktaped goals - it was the busted bridges that got on their nerves.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
