Go to Post I see you've one-upped me in the stripped gear game. I commend you. - frcguy [more]
  #46   Spotlight this post!
Unread 05-03-2016, 09:20 AM
scaryone's Avatar
scaryone scaryone is online now
FRC #0058 (The Riot Crew)
scaryone will become famous soon enough
Re: New Off-season Defenses
We are considering having all teams vote prior to the event, and have static defenses (not changing throughout event). Lots easier on volunteers.
  #47   Spotlight this post!
Unread 05-03-2016, 09:22 AM
Storcky's Avatar
Storcky Storcky is offline
FRC #3634 (Hard Botties)
Storcky is on a distinguished road
See http://www.chiefdelphi.com/media/photos/43664
Alum of 1629 - GaCo [2005-2008]
Mentor for 3634 - Hard Botties [2013-2015]
Mentor for 230 - Gaelhawks [2013-2015]
Pittsburgh Regional Planning Committee [2016-?]
  #48   Spotlight this post!
Unread 05-03-2016, 09:34 AM
mrmummert's Avatar
mrmummert mrmummert is offline
AKA: hank
FRC #1610 (bot)
mrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to behold
Send a message via Yahoo to mrmummert
Just had this idea....some sort of swinging bridge...similar to a rope bridge.
basically a suspended platform the size of a defense bottom about a inch or so high off the defense base. each corner would have a rope (or chain) attached to a post holding the this up. As you drive across it could swing back and forth. If a robot sat on it then took off the base would tend to swing out from under the robot. Driving onto it too fast would make it difficult to drive across.
winner vcu 2006,winner vcu 2013,2014,2015
  #49   Spotlight this post!
Unread 05-03-2016, 09:41 AM
Chris is me's Avatar
AKA: Pinecone
Any newly created defense is not fair to teams that designed around the very specific defense arrangements on the field. Sure, it's "not fair" that other defenses will be removed too, but removing a game element is a lot less of a penalty than adding one that not everyone can cross.
Honestly, they should just make off season defenses static. CDF, Rock Wall, Ramparts, Moat. CDF in 2 to block the human player, yet Moat in 5 and Rock Wall in 3 to allow skilled HPs something to try. Terrain defenses in 3 and 4 for auton. Skipping Sally port and Drawbridge for visibility reasons, and skipping Rough Terrain because it's easy and we're out of room. This will save tons of time and congestion for field reset, reduce load on volunteers, increase defense robustness (you can bolt down defenses instead of pinning them) and generally make things smoother. I will miss the strategic depth of defense selection (and trust me, there was some) but I think ultimately it's worth it for a better event without disadvantaging certain teams.
  #50   Spotlight this post!
Unread 05-03-2016, 09:44 AM
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
-A normal defense base... Covered in rollers
-A running treadmill (running towards the neutral zone)
-The black knight
-Car tires
-A pit full of mutton legs
It isn't shiny enough.
  #51   Spotlight this post!
Unread 05-03-2016, 10:00 AM
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Stickers were put on at World Champs.
Granted the Portcullis is probably one of the more hazardous game elements in recent years, but the stickers were a little -- bizarre. No one is supposed to be on it anyway. I'm surprised there weren't more stickers on it saying "Danger - Tipping Hazard".
Having static defenses would be kind of dull. Most of them weren't a problem moving in and out of the bases, except like the Rock Wall or Ramparts which got banged out of position by the robots and the pins wouldn't come out. My crew at UMass Dartmouth were running ahead 30 minutes. The reset crew at the NE Champs were dancing even after 3 days of resetting.
  #52   Spotlight this post!
Unread 05-03-2016, 10:08 AM
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I don't know that creating new defenses is any more or less fair than choosing a set of defense to use permanently. We're specifically choosing defenses that should be crossable by all drive trains.
  #53   Spotlight this post!
Unread 05-03-2016, 10:12 AM
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
You can make something that is easy, fun, and/or weird. For instance, I don't think putting a short stack of gray totes or an Aerial Assist ball sitting on a ring on the portcullis base for teams to bulldoze through is particularly difficult to execute in construction or requires any significant change to an existing Stronghold robot, but could make play more interesting/wacky for an offseason.
  #54   Spotlight this post!
Unread 05-03-2016, 10:21 AM
scott.smith's Avatar
scott.smith scott.smith is offline
Inventor guy
FRC #0639 (Code Red Robotics)
Team Role: CAD
Rookie Year: 2015
scott.smith will become famous soon enough
You would think that the CDF would block the human player, however, our human player actually was able to bowl over it, without any robot assistance. No matter how you try to stop the human players, they will always find ways around it.
That said, I think that it is already hard enough to to bowl it over the rock wall, ramparts, or moat, so you don't need to make it even harder. It would decrease the value of the human player, and make all but the best human players much less valuable. Then again, after much practice, it might become more common for HPs to bowl it over spots 3,4, and 5. Also, your idea would be great for field reset times.
  #55   Spotlight this post!
Unread 05-03-2016, 11:01 AM
Professional Stat Padder
I think static defenses at a lot of smaller off-seasons makes a ton of sense. Get more matches into one day by lowering field reset times and require less volunteers.
However I still want to see changing defenses at IRI, Chezy Champs, and other similarly competitive and/or long off-seasons.
(2015-Present)
  #56   Spotlight this post!
Unread 05-03-2016, 11:15 AM
Shrub's Avatar
Shrub Shrub is offline
no team (N/A)
Shrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant future
Make the new defense another robot. Alternately, two smaller robots.
  #57   Spotlight this post!
Unread 05-03-2016, 11:43 AM
Refresh's Avatar
Refresh Refresh is offline
AKA: Chris
FRC #0074 (Holland C.H.A.O.S.)
Refresh has a spectacular aura aboutRefresh has a spectacular aura about
Originally Posted by carpedav000 View Post
I call this one the mega moat:
Same as the moat, but the bumps are the size of the rock wall instead
Not the cliffs of Insanity!!!
  #58   Spotlight this post!
Unread 05-03-2016, 11:49 AM
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Potentially, yes this could disadvantage teams, but by adding a defense that could be pretty easily traversed by most drivetrains in FRC this year, I would wager that for the most part it would be a non-issue. Plus, it's the offseason, which is the perfect time to try out fun stuff like this without hurting anyone's chances at winning a blue banner. I think it'd be really fun to see something like what a lot of people have proposed. The defenses could still be static if that makes things easier on field crews, but the added twist might be pretty cool.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
  #59   Spotlight this post!
Unread 05-03-2016, 12:04 PM
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
A MOAT WITH ACTUAL WATER.
  #60   Spotlight this post!
Unread 05-03-2016, 12:22 PM
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Sometimes, teams are too good at it.
Now, I'm not saying that its not hard. In fact, its incredibly hard. However, I feel like people would want to minimize the influence of human players, as this is a robotics competition, not a human player competition.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
