Re: Was the Low Bar worth it?
Transformer bot was the way to go this year, it is not an easy task to package and make successful this design. We only built how we did because of the last 2 years of offseason robot projects. In 2015 preseason we built our first ever elevator using proper methods, and then we built our 2015 robot with an elevator using what we learned. In 2016 preseason we built an articulated arm bot, a knockoff Mammoth from 971 to play Aerial Assist at MadTown Throwback, this year we built an articulated elevator arm using what we learned. Teams that successfully implement swerve drives do so by making it work in the offseason first. Build what you know, learn before you build as much as you can.
I completely agree, and this was one of the main deciding factors for our team to go tall. Two members of our design team, myself included, were on the team back in 2012 and this year we essentially designed and built a Rebound Rumble robot for 10" balls that could also climb. This helped us to see what to do and what not to do based off of successes and failures of that past design.
