Go to Post I am used to politicians getting up and being blowhards. - Steve W [more]
Unread 03-05-2016, 18:13
erin623 erin623 is offline
AKA: Erin L
FRC #0623 (Cougar Robotics)
erin623 is a jewel in the rougherin623 is a jewel in the rougherin623 is a jewel in the rough
Team Size
So my team is relatively small (only about 20 members who came more than once during the season) and I was wondering what you guys' preferences are for team size. Personally, I was thinking about attempting to make our team up to 40 active-ish members next year in order to have people to cover all the different awards/tasks, but I'm not sure if that's unrealistic or too big. One of our mentors thinks that we should do interviews and become even more selective, but I don't think that's what FIRST is for, honestly.
Unread 03-05-2016, 18:17
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Re: Team Size
4967 had 24 students this year. I've (personally) always felt that about 25-30 is a good number. However, I've never been involved with a team above the ~25ish number so I can't truly speak from experience.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 03-05-2016, 18:20
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Team Size
We have 100+ members and far too few mentors and good leaders. I would say to try 1 mentor to 10 kids maximum. 40 active members is definitely doable (many large/good teams function like this) as long as you have the leadership to guide them. At a certain point team size starts to make the team function less effectively, although I can't say for certain where that is.
Unread 03-05-2016, 18:24
natejo99's Avatar
natejo99 natejo99 is offline
Captain/Human Player
AKA: Nate Johansen
FRC #0074 (Team C.H.A.O.S.)
natejo99 is on a distinguished road
Re: Team Size
Our team is about the same size (20 members or so). Now, in some ways, I consider this to be a good size. If there are fewer people around, there's a greater chance that none of them will be sitting around doing nothing and distracting those who are working, because they will all be preoccupied with an important job. However, this has proven to not be the case. Most of the time, students don't show up, or do, and don't do the work anyway, which puts a lot of strain on the other half of our student body that commits a lot of their time to our team. So 40 members would be great for our team, as hopefully it would increase the amount of dedicated members. It all depends on the dedication and work ethic of the students.
I agree with your wholeheartedly on the interview issue. The only time I would find it appropriate to have "tryouts" of sorts for a FIRST program is if there are an overwhelming amount of students applying to be on your team, and even then, I would consider either starting a new FIRST team for the students that didn't make the cut (which I know can be expensive) or referring them to another smallet area team.
Hope this helps!
2013-Present - Student, FRC 74
2014 FRC Champions - 254, 469, 2848, 74
2014 FRC MSC Finalists - 1718, 67, 74
2016 Traverse City District Winners - 3688, 74, 6128
2016 Tesla Quarterfinalists - 74, 2054, 4468, 3238
Thanks to our 2016 Alliance Partners:
4580, 71, 2405, 3572, 3688, 6128, 5505, 2054, 4468, 3238
Unread 03-05-2016, 18:59
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
Re: Team Size
Big teams are not necessarily bad, but you need to make sure that you have a solid structure in place to occupy all of those kids. 1124 had a bit of a similar situation, with our team size going from around 20 to as high as the mid 50s, then back down to around 35ish in the past four years.
That many kids will be very hard to manage and occupy productively without good planning (or at least it was for us, it's very possible you have better solutions in mind).
Some teams, like 254 for example, have member counts around 100- it's all in how you manage and engage them. Just make sure you know what you're getting into
Unread 03-05-2016, 19:00
AKA: Erin L
Re: Team Size
Hope this helps!
Thank you so much!! I also want to create very solid leadership and add more mentors to the team, so hopefully that will go along with adding more students.
Unread 03-05-2016, 19:25
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
Re: Team Size
We have 30ish members and 2 full mentors (and a few parents who really started helping too) 6/10 would recommend more mentors.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 03-05-2016, 19:48
Type's Avatar
Type Type is online now
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
Re: Team Size
My team consist of 9 members. I'm actually proud to say that. We are a small team that is competitive. When we told people at Worlds we only had 9 people, they were shocked. But with any team, there is about 1/3rd to 1/4th of the team that doesn't do anything. The percent is roughly the same no matter how many are on the team. This is my opinion and doesn't reflect how my team feels though. Just talking to other teams, most have about the same number percent of activities members. It's now always that percent but close.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 03-05-2016, 20:04
ey206208's Avatar
ey206208 ey206208 is offline
FRC #1701 (RoboCubs)
ey206208 is a jewel in the roughey206208 is a jewel in the roughey206208 is a jewel in the roughey206208 is a jewel in the rough
Re: Team Size
We had about 20 active students and 10 mentors this season, and it has been on of, if not, the most successful in our team's history. We won our first district event, finished states higher than ever before, and had our best showing at worlds. While a smaller team can be challenging, I think it really comes down to commitment and the ideas within the team. I think our team is a great size; everyone works on the robot in some fashion, everyone contributes, and everyone plays a part in the success or failure.
A long time ago, people who sacrificed their sleep, family, food, laughter, and other joys of life were called saints. Now they are called engineers.
Unread 03-05-2016, 20:08
hutchMN hutchMN is online now
2502 alumnus
FRC #4360
hutchMN has a spectacular aura abouthutchMN has a spectacular aura abouthutchMN has a spectacular aura about
Re: Team Size
When I was on 2502, we had about 55 kids. Only about 30 kids were major parts of the team. The team has grown much larger since, and we've added more sub teams so there are a lot more things for people to get involved with now.
Unread 03-05-2016, 20:26
Liu346's Avatar
Liu346 Liu346 is offline
FRC Enthusiast
FRC #0346 (Robohawks)
Team Role: Human Player
Liu346 is an unknown quantity at this point
Re: Team Size
Team 346 has a pretty solid size team we are about 60 students with 20 mentors. We enjoy having a closer connection between students and mentors to get a more personal experience. With a 3:1 ratio it is very easy to keep all the students occupied and working when the season has come to a lull. I personally would not be opposed to growing my team to 80-90 but it really depends on the place that y'all work in.
Unread 03-05-2016, 20:27
erk1119 erk1119 is offline
AKA: Elizabeth
FRC #0107
erk1119 is an unknown quantity at this point
Re: Team Size
Can you really double a team's size in one year? At least in my view, such a large increase would need to be a 4-ish-year plan. If half your students are "freshmen", I can't imagine there being enough leaders (student or mentor) to adequately guide the new students so that they can be active participants. To grow, you also need to grow structures and systems (sub-teams, education...). But you know more about your team than I do.
As a member of a small team, I have really appreciated how we only have about 20 students. A smaller team makes it easier to learn by doing and branch out in a variety of areas to find out which area we most enjoy, rather than being assigned to a sub-team.
However, I agree that it can be challenging for a smaller team to have enough people to work in every group. For example, as a graduating senior, I looked for someone to take my role as safety captain, and I ended up going to an 8th grade FTC student who should be joining the team next year.
Unread 03-05-2016, 20:40
Leila Silver's Avatar
Leila Silver Leila Silver is offline
FRC #0973 (The Greybots)
Rookie Year: 2016
Leila Silver is an unknown quantity at this point
Re: Team Size
973 has 19 students, all of whom are very committed.
In your case, I agree with some of the other posters in this thread. You should train up your freshmen and try to increase team size gradually. Otherwise it might negatively impact the team in many ways (EG, leadership stress due to more student management).
I also don't think that interviews are a good choice. Some kids who may not be eloquent or demonstrate commitment in the off season may become hardworking and passionate. Those who join came for a reason, and some might be better at demonstrating it than talking about it.
Unread 03-05-2016, 20:42
Broboraider's Avatar
Broboraider Broboraider is offline
AKA: Austin O'Neill
FRC #0075 (RoboRaiders)
Broboraider will become famous soon enoughBroboraider will become famous soon enough
Re: Team Size
During my time on 75 we always had 100+regestired members although we would vary from 50-80 active members depending on the season and what competitions we were going to. We always had great mentor support and our warehouse never felt small. It wasn't until this year that we made a minimum fundraising req. in order to be considered to attend the competition. With that in mind we never plan on moving to a selective process as we try to be as open as possible. Plus it makes it easier to accomplish tasks the more members you have
Unread 03-05-2016, 22:02
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Team Size
IMO, grow your team. 20 is enough to make a robot, but not enough to truly become inspirational to a large school.
Your mentor has a valid concern with respect to managing student behavior. While I too disagree with interviews - they very rarely bring out the true student - you will want to address behavior and respect concerns up front with every new and existing student.
Get your team to drop team seniority fallacy. The person who has performed with mediocrity for longer is often worse for a job than the person who has performed with ambition for a shorter time. However, leaders are not dictators - listen to the experienced people.
Good luck!
GitHub
