Go to Post The programmers tend to get less credit than they deserve, but the robot wouldn't run if we weren't there. :) - IMDWalrus [more]
  #91   Spotlight this post!
Unread 04-05-2016, 16:42
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: New Off-season Defenses
Originally Posted by DareDad View Post
In exactly the same way. A 12 foot loop of chain can be raised well above 4' 6", it isn't as simple, but should still be quite possible.
Many tall (and short) robots relied on the motion of the portcullis to get through it. One push (or ramming into it a few times, in some cases) would send it flying high, and they could quickly get through it before it came crashing down.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #92   Spotlight this post!
Unread 04-05-2016, 17:04
Doug Frisk's Avatar
Doug Frisk Doug Frisk is offline
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
The Portcullis is gone. I offered up a manipulation defense that it functionally similar to the portcullis. What do you suggest? What are you willing to build in your garage to bring to off season events?
  #93   Spotlight this post!
Unread 04-05-2016, 17:34
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
Let's tone it back a little.
While I do like your chain idea and think it would have made an interesting defense, the reason people are a little skeptical is because while similar, the chain would act vstly different than the Port. Most Port manipulators were also built with the bottom of the "door" being a solid bar. Ideally, any replacement defenses are actuated similarly to existing defenses so as to not require a completely new mechanism be built in the off season.
Academic Student (Forever)
  #94   Spotlight this post!
Unread 04-05-2016, 18:02
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
4-bar linkage portcullis? Seems like you could counterbalance it to where it spring assists up and then gently glides back down
It isn't shiny enough.
  #95   Spotlight this post!
Unread 04-05-2016, 18:09
AKA: Kara Bakowski
I would argue that your suggested defense is not functionally the same as the portcullis, because of the reason I stated in my post. Some robots might be able to use the exact same mechanism on your defense, or a very similar one, but not all of them.
I'm not saying the chain is a bad idea. I actually think that, if we are considering all ideas for portcullis replacements (similar or not), it would be a good challenge. I'm just saying that it is not functionally the exact same, and if we are looking for an exact (but safer) replacement that would not require any existing portcullis-capable robots to change their design, that's not it.
Honestly, I don't have a suggestion right now. I'm glad that nobody else will end up being hurt by a portcullis, and for that reason I will be accepting of whatever replaces it.
I think that some of the ideas presented in this thread are good (I particularly like the "rolling log" ones). If I had a garage and the equipment to do so, I would very gladly take the time to build any one of these ideas.
Kara Bakowski
WMWBS '10 '11
  #96   Spotlight this post!
Unread 04-05-2016, 18:39
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
I emailed Mark Lawrence yesterday a suggestion that the new defense be a 12 foot length of heavy chain encased in a vinyl tube suspended across the platform with the center of the loop 5 inches above the bottom platform.
It provides a challenge that is similar to the portcullis in that you have to lift the chain up and over the robot, but is easier in that it swings out of the way and harder in that the chain can catch on the robot as it passes under.
The vinyl/plastic cover is of course to prevent the chain from completing a circuit as it drags over your robot.
To me, this sounds like the original low bar, just...higher. If so, it could be functionally similar to both the low bar and the portcullis, allowing robots to pass through just by pushing the tube, like the tubes on the old low bar. Maybe then even bots too tall for the low bar could get through this.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
  #97   Spotlight this post!
Unread 04-05-2016, 18:52
wlaroche wlaroche is offline
FRC #2177 (Robbettes)
wlaroche is on a distinguished road
What about putting the flat base for the portcullis in the slot and allow teams to cross whenever they like. The difference being that the crossings will not count till the last 20 seconds. So you can make the deicsision on doing crossings or climbing.
If it was easy someone else would do it.
  #98   Spotlight this post!
Unread 05-05-2016, 10:34
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Originally Posted by Alan Anderson View Post
Many drivers would like to see the Drawbridge and Sally Port gone (or changed) because they are large and impossible to see through.
Is it bad I see the visibility issue as a feature?
I like a number of items which have been brought up, let me through in a wild card.
Allow teams to bring in their own defenses of whatever design they choose (within a few rules)
1) Can't fod the field
2) Must be possible to cross
3) If their robot cannot cross, the other alliance has higher priority for choosing to use it against them.
  #99   Spotlight this post!
Unread 05-05-2016, 21:07
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
I personally hated the visibility issues (im the driver) since we have a low bot. But then again, I would not want them gone, because it was just another challenge of the game. It's like tall bots saying they don't like the low bar, so it should be gone.
Plus I also like the visibility constrains, because it separates the good drivers from the not so good. For example (not bragging here), after the first few matches at our first regional, i was getting used to the field and our bot. So even when I didn't have direct line of sight, our performance wouldn't degrade (unless there was defense being played), because I could still estimate exactly where the bot was based off of instinct, even making knocking out the sally port easy.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
  #100   Spotlight this post!
Unread 05-05-2016, 21:09
How about using a Portcullis-like setup...
But instead of springs, use a counterweight system, to keep the door at roughly 5 lbf up-force? (Maybe use a return spring to start it on the downward motion, though.)
  #101   Spotlight this post!
Unread 05-05-2016, 21:15
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
I personally am a fan of the following ideas:
1. Cheval De Frise stuck in the down position, it provides the challenge of not going so fast or slow that might cause your bot to tip over, (plus the airtime photos are going to be great )
2. Or a custom made variant of the cheval de frise ramp idea, so that teams can go over it from both sides, and not just one.
3. Somehow stick boulders in the defense base/holder, so a bot would have to drive over the boulders. Challenge is to not get stuck.
I really don't like the idea of having an empty defense with no points. Because once the other 4 defenses are knocked out, than shooter bots will just traverse the outer works using the empty defense, making it way too easy.... plus 3 ball auto anyone?. And also, that completely negates the effect of the secret passage.. (okay not completely, but still).
  #102   Spotlight this post!
Unread 05-05-2016, 22:31
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
I really like the idea of having a rolling log or logs as a defense, but I feel like it might be very hard to build consistently or reliably. Another idea would be to take the frame of the Portcullis we already have and mount double doors that open in the middle to the sides of the Portcullis that are already there. However, the difficulty of this defense is that one of the doors, say the left door, will only open towards the Courtyard and the right door will only open towards the Neutral Zone. I think this could be moderately easy to build, and a fun defense for teams to tackle.
  #103   Spotlight this post!
Unread 05-05-2016, 22:49
Jonny_Jee's Avatar
Jonny_Jee Jonny_Jee is offline
FRC #2085 (Robodogs)
Jonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to behold
the bumps from breakaway would make for a neat obstacle.
  #104   Spotlight this post!
Unread 06-05-2016, 08:52
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Let me ask this: Where exactly was the problem on the portcullis? I know what the problem is but I just want to know what part of the portcullis caused the problem. Then we could try to think of a new portcullis that removes this problem.
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
  #105   Spotlight this post!
Unread 06-05-2016, 09:38
Doug Frisk's Avatar
Keeping Score
AKA: Doug Frisk
The problem is, the springs on each side are 40 pound constant tension springs which means the actual door within the portcullis is 85 pounds total. With the springs attached, the door can be easily raised to about 10 feet at which point the assembly becomes very top heavy and tippy. Without the springs attached, the door can be lifted even higher and I understand that may have caused an incident or two. The springs themselves are metal ribbons with, while not a sharp edge, and edge that can cut ungloved fingers as the door moves up and down. Think of someone running 4 feet of the edge of a tape measure across your fingers. The wheels at the bottom of the door present a crush hazard as they roll up and down as well.
The assembly when finished is very easy to tip and has no hand holds or way to lock the door in place.
So, an improved portcullis is:
  • lighter.
  • has no exposed counterweight components.
  • has fewer sharp edges.
  • has a door that can be locked in place during transport.
  • has handholds for the field reset folks.
I'm sure there's more.
