Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Unread 05-05-2016, 09:00
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
Re: pic: Basketball Drive
Originally Posted by Team3844 View Post
It looks like each ball is in contact with 2 wheels. that would make every ball turn at the same rpm since they are all tied together which would just make the bot rotate in circles.
Only when all 4 CIMs are engaged in the same direction. When moving left/right or forward/backward with 2 CIMs engaged the balls should just pivot around the inactive wheel. You may receive some rotational movement when trying to move diagonally.
Unread 05-05-2016, 15:01
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
I dug up a couple photos in my email of the ball drive Eric was talking about, we were both on the team in 2005 when it was developed in the offseason. As Eric mentioned, it shared a lot of conceptual similarities with yours - 4 corner balls in a square frame, driven by 4 motors between each ball. It was also inspired by the 2-ball omni drive that Technocats built in 2003.
These were taken when we first assembled everything, as a first pass fit/function check of the captive ball. The lego tires shown on the rollers are just placeholders, and we later had to switch to a stronger hinge at the pivot point above the springs.
We tried several different balls to get something to work - we wanted something in the 4-5" diameter range. Many balls we tried were not quite round enough or too rough (dimpled pitching machine softballs). What is pictured are actually garden gazing balls. They were cheap and light, but welded together from two halves, so they had a bit of an oblong shape. The springs helped accommodate this. Also to Eric's point about preventing driving the balls out from under the chassis, our outer corner ball transfer unit was placed below centerline of the ball (much like your latest update) to mitigate this.
Some of the biggest functional issues stem from the contact point between the ball and the driving rollers/wheels. To drive, you need friction here to transmit torque to the ball, necessitating a fairly significant normal force on the roller, and a grippy material. When the ball is being driven by the opposite roller, you want the ball to spin freely with low friction about the roller contact point. Finding the right balance here can be tricky.
I do like the use of larger wheels as a single roller contacting two balls. It is simpler (less moving parts) than the belt/roller system we had, and there should be minimal load on the wheel shaft, as the normal forces from the balls on either side are balanced. The layout works pretty well because of your choice of larger, basketball-sized balls.
I'll try and do some more digging. Somewhere I have a low quality video of ours driving down a hallway.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 06-05-2016, 18:36
BotDesigner's Avatar
BotDesigner BotDesigner is online now
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
Thank you everyone for the help! From what you have have told/shown me it looks as though I am moving in the right direction.
If we build this we would absouloutly have to use these balls.
http://www.amazon.com/Light-Basketball-Uses-Bright-Official-Weight/dp/B009JBJ142/ref=pd_sim_200_18?ie=UTF8&dpID=51KSObOw1YL&dpSrc=s ims&preST=_AC_UL160_SR159%2C160_&refRID=1EEZ0MCBGS AE9NRQ5C5D
Now to find a way to power them from the robot battery .
2016, 2017 Colorado FLL Champions
2014 FLL North American Invitational, 1st place Strategy and Innovation Award
2014, 2013 Kentucky FLL Champions
2nd place Strategy and Innovation ward
FLL Team Automaticus Rex, Team Captain('11-'14) youth mentor ('15-'17) FRC Team 4418 Member ('14-') Design Lead ('15-16') Program Managment ('16-')
