Go to Post ...I tried to pump it up to the 47 inches. I stopped around 42 inches, than tried getting it through a 36" door. It got stuck, I proceeded to dropkick the thing in front of my team and a girl I had gone out with the previous Fri. It didn't move, I hit the floor. Ouch, my pride. - ChrisMcK2186 [more]
Unread 05-05-2016, 07:24 PM
Oldgoer Oldgoer is offline
FRC #3814
Rookie Year: 2015
Oldgoer is an unknown quantity at this point
Unable to build command based program
Our team is moving towards a new command based program for our future robots and are having an issue that makes no sense. when we attempt to build ANY command based program (including a new unaltered void project) we get a fatal error:
Info: Internal Builder is used for build
arm-frc-linux-gnueabi-g++ -std=c++1y "-IC:\\Users\\PiBotics/wpilib/cpp/current/include" "-IC:\\Users\\PiBotics\\workspace\\null command based\\src" -O0 -g3 -Wall -c -fmessage-length=0 -o "src\\OI.o" "..\\src\\OI.cpp"
In file included from ..\src\OI.h:4:0,
from ..\src\OI.cpp:1:
C:\Users\PiBotics/wpilib/cpp/current/include/WPILib.h:14:28: fatal error: ../CommandBase.h: No such file or directory
#include "../CommandBase.h"
compilation terminated.
I am unable to see why this error is occurring. it looks like it is pointing to not finding the CommandBase.h file which is clearly in the src folder of the project project
Unread 05-05-2016, 09:42 PM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Unable to build command based program
Looks like you added an include for CommandBase.h to your WPILib.h file on line 14
Line 14 is blank for me
http://img.prntscr.com/img?url=http:...om/K6eKywP.png
You shouldn't modify WPILib files in most cases. Remove the line, or reset your wpilib install by closing Eclipse, deleting %userprofile%\wpilib, then starting Eclipse again.
