Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Unread 05-05-2016, 20:38
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
C.Lesco will become famous soon enough
Cheap Electrical Parts
Hey guys, my city is planning to build a community robot built over the summer so we can have rookie teams able to do outreach with it in their first year as well as have our community teams grow closer as a whole.
Problem is the electricals, unlike the frame and metal, you cant dumpster dive your schools auto shop waste bin to build half of your bot with. Is there a cheap alternative? Doesnt need to be FRC legal, just needs to be frc motor combatable.
Rookie Allstar winner North Bay regional 2016 [Team 5870]
Driver 2015 [Team 4814]
Lead Driver 2016 [Team 5870]
Build, Design and Engineering Captain 2016 [Team 5870]
Mentor 2017 [Team 5870]
Unread 05-05-2016, 20:47
Billfred's Avatar
Billfred Billfred is offline
Re: Cheap Electrical Parts
I'd take a look at the Cheap and Dirty control system. Even if you use a different control system, the electrical setup is good enough for light-duty stuff. (You'd have to come up with different fusing to run 40A breakers, and I wouldn't run your 6-CIM drive on that in a pushing match...but it would drive.)
(Full disclosure: I'm starting at AndyMark in about two and a half weeks.)
Unread 05-05-2016, 21:02
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
The Arduino is adequately ample to do what you want.
You can usually get a Mega2560 from MicroCenter for about $10.
The Mega2560 is capable of running a 3D printer with a RAMPS 1.4 shield to set expections.
Either using some of the many FRC related projects or just bit smashing on your own.
The only place you might find a bit tricky is around encoders.
If you do that look for ICs to count the rotations or a dirt cheap Xilinx or Altera FPGA development board.
If you want to take that up a notch use an Arduino Yun and that will give you WiFi.
Unread 06-05-2016, 10:59
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
A few ideas:
- Go garage-saling and look for a Power Wheels ride-on toy to scavenge
- Cordless drills are a source of high-torque motors and gearboxes (and a throwback to how FRC bots used to be made)
- AndyMark's Cheap and Dirty R/C system as previously mentioned
- (For smaller projects) Continuous rotation servos can serve as an all-in-one PWM controller, motor and gearbox
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 06-05-2016, 12:57
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
CTRE has a new system out we're looking at for keeping older robots up and running. For less than the cost of one roborio (probably even PDB) we can run a robot.
http://www.ctr-electronics.com/control-system/hro.html
Unread 07-05-2016, 00:08
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
And here I thought you had already started at Champs!
Unread 07-05-2016, 00:31
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
I would go with this personally. If it is just for display and demo, there should be no issues running it with the AndyMark gear. Alternatively, you could see if any teams near you are willing to spare an old cRio with the digital sidecar, PDB, and some speed controllers.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 07-05-2016, 00:52
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz will become famous soon enough
Assuming that this will be a simple robot (no vision or crazy sensors) if you can find someone that can code in pbasic or C, you could even use the old IFI control system. They're inexpensive and many older teams may have boxes of the robot controllers, operator interfaces, radios, and serial port joysticks. If they have those, they probably also have some 883s that they'd be willing to part with.
You'll never have a radio issue and they can take quite a beating. If you do manage to break one, all you have to do is load your code onto the new controller and drop it in. You won't even have to re-tether the radio.
We have some sitting around from 2003 and 2004 and they still work flawlessly (even though the robots don't)
Unread 07-05-2016, 01:53
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
The use of a R/C transmitter to control a robot could give the wrong impression in demonstrations and make the audience think that your robot is nothing more a glorified R/C car than it is a robot(it is an R/C car if you are using this control method).
Although expensive the VEX Cortex, is used by quite a few teams as a Robo-rio replacement. It will simplify your demonstrations as no driver station is necessary, but it still allows a great range of functionality and is similiar to program as a normal frc control system, making it a good learning opportunity for programmers.
http://www.vexrobotics.com/276-1604.html
Couple the VEX Cortex with a few low cost PWM motor controllers like Sparks or Victor SP's or old Victor 884/888's, Talon SR's and Jaguars with a basic power distribution board ( could be from an old control system or just a small fuse board, depending on how many motors you plan to run) a circuit breaker and a SLA battery and you have a relatively low cost control system, which allows you to utilise as many existing parts as possible while making demonstrating the robot simple and professional
Unread 07-05-2016, 09:50
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We have tons of old IFI Controllers. PM me if you are interested in anything like that.
http://robotnext.typepad.com/.a/6a00...6ae78b9970b-pi
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 07-05-2016, 15:18
Billfred's Avatar
(full disclosure still applies)
If the robot is going to need programming and be operated without troubleshooters around, then a VEX Cortex is a perfectly good option. (Note that you're going to need to change genders on the PWM outputs, either by crimping new cables or using both male ends of a Y cable.) However, at $400 there may be alternatives that provide the needed functionality (depending, of course, on the team's parts pile and willingness to figure out a new platform that may or may not be built with this particular application in mind).
That said, 4901 has a Cheap and Dirty radio that's seen public use (we ran the Team Cockamamie build on it at Relay for Life--not exactly a high-tech affair) and several drive bases were running them at the AndyMark booth at Championship. While I agree that none of them were true robots in the textbook definition, probably 99.5% of the people were too engrossed in the object being controlled to care--and the other 0.5% that bothered to ask learned the differences between our competition robots and a demo robot. It's just not that big a deal.
