Go to Post If you are playing foozball and your ball bounces back out of the goal, do you expect the table's manufacturer to fix it? No - you groan and keep playing! Nothing's different here. Like Dave said, it's part of the challenge of playing the game. - petek [more]
View Poll Results: Would you buy or make this product? (More $ = more freebies for teams)
I would not buy or make this product. 2 7.69%
I would make this product myself, but not buy it. 6 23.08%
I would buy this product for $10 (including shipping). 16 61.54%
I would buy this product for more than $10 (including shipping). 5 19.23%
Multiple Choice Poll. Voters: 26. You may not vote on this poll
Unread 06-05-2016, 01:24
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Presenting MVPWM-102: A cheap motor controller tester anybody can make or buy
Original thread: http://www.chiefdelphi.com/forums/sh...d.php?t=147470
MVPWM-102 is a FRC motor controller tester similar to the AM Thrifty Throttle, featuring a 0-100% knob-adjusted forward and reverse and powered by Micro USB (android phone charger cable) or direct 5v power.
Due to fabrication limitations, I cannot implement the Talon SRX power in this revision (although I'm looking into alternative ways to do it).
Boards are $4.82 each to make not including the Talon SRX header (that makes it $5.59) or shipping. Please answer the poll on what you would pay for a product like this. I'm not aiming to make money, but I do want to be able to offer this to as many teams as I can. With that in mind, I'll be releasing the design files for both a surface-mount and a through-hole version (which is slightly more expensive, around $7 not including shipping) once I test to see if the Talon SRX header can be used. PM me if you would like the current design files.
Nerd facts: pulse high time tolerances are +/- 2us on average when the potentiometer is held still, about a 0.4% power variation, with a range of 700-2300us (slightly larger than the normal 1000-2000 range, but this is because of potentiometer limitations). Much better than I expected.
You can see a video of it outputing pulses here: https://youtu.be/rlQgoI_rx1o
The numbers on the screen are in microseconds, and change as I turn the potentiometer up and down.
Please reply below if you have any comments or reasons as to why you would or would not use this.
Unread 06-05-2016, 05:48
Michael Hill's Avatar
Re: Presenting MVPWM-102: A cheap motor controller tester anybody can make or buy
I think a good in-between spot would be to sell it as a soldering kit. However, if you do that, it may be better to switch things to through hole (though SMD isn't hard, people, for some reason, think it is). If you wanted to sell it as a product, people expect a somewhat decent molded case if they're going to be using it seriously. Nobody wants to hold a bare PCB and turn a pot with no knobs, so that can drive the price up quite a bit.
Unread 06-05-2016, 06:01
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I have and use a similar device made by a mentor on 1640. It's mounted on a 9 volt battery so it's self contained. I use it all the time to test VEX motors.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 06-05-2016, 07:16
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
If you need production, I would love to parter! I work at a circuit board shop, and I also moonlight my own little circuit board shop.
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 06-05-2016, 11:29
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Good point. I did get a quote for injection moulding custom cases, and to say it was expensive would be and understatement. I will definitely make something that can be 3D printed, but unless there's a cheap way to make these cases otherwise I'll stick to that. Shapeways and places like it can sell you 3D printed things anyway. Currently the case should cost around $6 if you were to order it.
As far as SMD soldering by hand goes, I avoid it as much as I can. Sometimes I'm forced to fix a part on a PCB, but depending on the package size it can really screw me up. 1208's don't usually pose a problem, but most of my work is in 0803 which takes a lot out of me.
Wonderful, I'll get in contact with you soon about this. I use OSHPark right now, and the turnaround times are a little too long sometimes.
That's a clever way to do it too. A team member of mine is making a battery pack PCB (we'll be soldering that up tonight) so if it works that would let me package this even nicer.
Unread 06-05-2016, 11:38
teslalab2's Avatar
RogueBotix LLC
VRC #8091
Do you want RoHS, or is tin/lead fine? I'm not sure if they still are,(but I know they used to be) FRC components are RoHS compliant by exemption.
Unread 06-05-2016, 11:42
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I've been using tin/lead so far, but in case repairs need to be done I'm thinking about moving to load-free. I'm not sure yet, because I need to wait a few weeks for my new solder paste to come in to see if it works.
The lower melting point of tin/lead makes it easier for home production, especially because of the easily burned leds.
Unread 06-05-2016, 12:23
teslalab2's Avatar
RogueBotix LLC
VRC #8091
I can do RoHS, I can run them through our reflow oven,
edit: sorry we should be discussing this in PM
Unread 08-05-2016, 18:36
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
All the design files are up here.
MVPWM-103 is the through-hole version. Be warned though; it has no case so you'll have to design your own.
You can also purchase one of the ones I have here:
http://www.ebay.com/itm/121980834159...84.m1555.l2649
I currently have 5 in stock, but if I get more requests (PM me) I'll try and make some more.
