Go to Post Just a word of advise dont come running up to someone and say OMG OMG its just remember to introduce yourself first. - Mike Schroeder [more]
Unread 06-05-2016, 13:46
gofmannir gofmannir is offline
AKA: Nir Gofman
FRC #2096 (RoboActive)
Rookie Year: 2015
gofmannir is an unknown quantity at this point
Teach me Vision
Hello,
There is some how can teach me from scratch how to do Vision Processing?
Wait before you close this thread - I promised my team I will succeed doing that and I failed...
I have 2 ways to do that (Programming with java):
  • Raspberry Pi
  • GRIP
Please if you know to program one of this ways a vision process Please comment me and teach me.
I'm not an idiot, I'm programming for 5 years - Websites and Application.
I am in the FRC program for 2 years and I know how things works, just in that topic I'm getting troubles..
Thanks,
Nir.
Unread 06-05-2016, 13:48
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Re: Teach me Vision
The biggest thing that helped me learn vision was looking at other teams code. 548 will post their vision code soon, you can also look at other teams code from 2012 or 2013 when vision was used alot
Unread 06-05-2016, 13:54
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is online now
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: Teach me Vision
Also, remember to start with crude vision. Don't try to over complicate things before you get a basic form working. As to the actual details, I'm sorry but I can't help you. We work in LabVIEW with NI Vision Assistant.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 06-05-2016, 14:16
Data Nerd
FRC #0079
Re: Teach me Vision
I can walk you through the process I used to get started with OpenCV, or at least the steps I used.
Step 1: Compile a sample program - This may seem trivial but do it. It makes sure your environment is set up right.
Step 2: Load a static image and display it - Again, simple, but you'd be surprised at just how important small successes are in programming.
Step 3: Run a simple filter on your static image(I'm partial to threshold by a color) and display the result. - Not only does it get you an understanding of how to process images but you're going to do a lot of this anyway.
Step 4: Convert between different color spaces. Typical you have an RGB image, you should convert to HSV. Even if you don't need to it's good to know how to.
Step 5: Start writing your filter to find the desired feature. Typically this is a series of steps to isolate the feature. Ours was a simple threshold by and hue range this year.
Step 6: Extract Filter - For this I typically use the various contour functions.
Step 7: Filter your contours - maybe you got a light, maybe there's multiple targets. This isn't really vision just simple data cleaning.
Step 8: Interface with robot - ??? This is the hard part.
Unread 06-05-2016, 17:22
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
Re: Teach me Vision
To add on to this question. How do you export the video feed into java run on eclipse? in other words what i want is to use grip for the image processing but do the calculation for a crosshair, shape detecting and alignment on the live video in eclipse and I don't want to use the smart dashboard or anything. if this is at all possible that is
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
Unread 06-05-2016, 17:26
Roboter
Rookie Year: 2015
Re: Teach me Vision
I'm pretty sure that if you use grip, you need to send the data through network tables, which necessarily implies the use of a smartdashboard.
Unread 08-05-2016, 21:31
Active Alumni
Re: Teach me Vision
well darn. Can you get smartdashboard on a mac?
Unread 08-05-2016, 22:35
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Teach me Vision
Unfortunately Smartdashboard is a component of Driver Station, a Windows only program. If you use Bootcamp (https://www.apple.com/support/bootcamp/) you can run Windows and thus Driver Station and Smartdashboard on your Mac. Boot Camp is significantly better than virtualization as it runs directly on the hardware, so no bottlenecks. That's what most of our programming guys with Macs do.
Edit:
Originally Posted by Joe Ross View Post
Other then the fact that the driver station can launch smartdashboard, they aren't related at all. Smartdashboard is a Java program that can run on macs. See here for an example https://m.youtube.com/watch?v=qnS6O04Yjrc
Oops, I didn't know that. I've kept my original post if you want to run Driver Station, but perhaps someone with more knowledge than me can tell you how to get it running on Mac.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 09-05-2016, 08:57
