Go to Post No, but you have access to the most powerful machine tool of all; a telephone. We had zero machining sponsors, now we've probably had over 30 unique shops run parts for us; All we did was ask. - AdamHeard [more]
Unread 06-05-2016, 21:01
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
pic: Improved Basketball Drive
Unread 06-05-2016, 21:02
swaxman12345's Avatar
swaxman12345 swaxman12345 is offline
Team Member
AKA: Sasha Waxman
FRC #2512 (Daredevils)
Team Role: CAD
Rookie Year: 2015
swaxman12345 is an unknown quantity at this point
Re: pic: Improved Basketball Drive
What was the philosophy behind caster wheels over something like omniwheels? Wouldn't omniwheels be better for rotational friction reduction?
Beware the Kraken, Jebediah. - Bill Kerman
Unread 06-05-2016, 21:20
Packaging, I'd say. Ball casters are very compact; omniwheels... finding anything smaller than 4" is very very difficult. And if space is critical, the less you use the better. I'd call space critical on this drivetrain.
Unread 06-05-2016, 21:24
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Agreed, but I don't see how this would avoid scrubbing on the higrip wheels while moving without using omnis.
Unread 06-05-2016, 21:31
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is online now
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
There isn't any scrub. The wheels are in the middle of the ball vertically, so if one wheel spins, it rotates around the other. And if both are spinning to go diagonally, the axis of rotation lines up so both wheels have no scrub. I'm not sure, though, how it would work out if it wasn't a 45 degree diagonal, but rather something like a 60 or 30 degree diagonal.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 06-05-2016, 21:54
Depends on what you mean by "scrub".
It looks like there are 2 traction wheels pressed against each basketball.
Consider the simple case where only one of those traction wheels is spinning.
There will be considerable pivoting friction between the ball and the other traction wheel. It may even bore a hole in the basketball.
Unread 06-05-2016, 22:15
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
There axis of rotation of the ball would not line up with the wheels when both are spinning though. Here is a quick sketch of where it would be in relation to the wheels: https://docs.google.com/drawings/d/1...DOI4KIXro/edit
Unread 06-05-2016, 22:52
PreztoElite PreztoElite is offline
FRC #2877 (The LigerBots)
Rookie Year: 2015
PreztoElite is an unknown quantity at this point
Would you mind uploading CAD models of the drive?
Unread 07-05-2016, 09:41
Roboter
Rookie Year: 2015
Looking at the picture made it clearer. I was convinced that, at least with a diagonal of 45 degrees it'd be fine. However, it seems even that would be a problem. Omniwheels, like others suggested, might be the way to go.
Unread 07-05-2016, 12:35
AKA: David Gedney
Grab a basketball and a small wheel (or any ball and a wheel with a smaller diameter than the ball). Try rotating the ball at an angle 45 to the wheel with the wheel perpendicular to the balls diameter.
As long as the balls rotation speed is sqrt(2)*(wheel-diameter)/(ball-diameter) times the wheels rotation speed the only "scrub" is 100% pivotal. I didn't believe this until I tried it since it is extremely hard to visualize.
I might change the traction wheels to omnis just because of the strong pivotal force.
2016, 2017 Colorado FLL Champions
2014 FLL North American Invitational, 1st place Strategy and Innovation Award
2014, 2013 Kentucky FLL Champions
2nd place Strategy and Innovation ward
FLL Team Automaticus Rex, Team Captain('11-'14) youth mentor ('15-'17) FRC Team 4418 Member ('14-') Design Lead ('15-16') Program Managment ('16-')
