pic: Improved Basketball Drive
Re: pic: Improved Basketball Drive
What was the philosophy behind caster wheels over something like omniwheels? Wouldn't omniwheels be better for rotational friction reduction?
Packaging, I'd say. Ball casters are very compact; omniwheels... finding anything smaller than 4" is very very difficult. And if space is critical, the less you use the better. I'd call space critical on this drivetrain.
Agreed, but I don't see how this would avoid scrubbing on the higrip wheels while moving without using omnis.
There isn't any scrub. The wheels are in the middle of the ball vertically, so if one wheel spins, it rotates around the other. And if both are spinning to go diagonally, the axis of rotation lines up so both wheels have no scrub. I'm not sure, though, how it would work out if it wasn't a 45 degree diagonal, but rather something like a 60 or 30 degree diagonal.
Depends on what you mean by "scrub".
It looks like there are 2 traction wheels pressed against each basketball. Consider the simple case where only one of those traction wheels is spinning. There will be considerable pivoting friction between the ball and the other traction wheel. It may even bore a hole in the basketball. |
#7
Would you mind uploading CAD models of the drive?
#9
As long as the balls rotation speed is sqrt(2)*(wheel-diameter)/(ball-diameter) times the wheels rotation speed the only "scrub" is 100% pivotal. I didn't believe this until I tried it since it is extremely hard to visualize. I might change the traction wheels to omnis just because of the strong pivotal force. |
