Go to Post Mob JVN for autographs - Jay Trzaskos [more]
Unread 07-05-2016, 16:23
lorykzarr's Avatar
lorykzarr lorykzarr is offline
AKA: Theo Camilleri
FRC #0854 (Iron Bears)
lorykzarr is on a distinguished road
Re: Workshop/Tools/Parts
You're definitely on the right track trying to find a cheaper place then McMaster. I would recommend a few things:
- Make sure the soldering iron you get has a stand or you get a stand for it
- The tin snips won't be much help cutting 1/8" sheet. They're designed for much thinner stuff
- You'll probably chew through those 1/8" drill bits really quickly if you ever drill out steel rivets. If you end up getting steel ones, stock up on drill bits.
Also, do you have a tool box/chest to store everything? If not, look into getting one so you can keep all of your stuff reasonably organized. And as far as the bandsaw, try looking for a used one. You might be able to get one for way less then new.
