Go to Post Sounds like a silly idea... so of course I'm in. - George1902 [more]
Unread 07-05-2016, 22:45
pHolmgren's Avatar
pHolmgren pHolmgren is offline
AGM
AKA: Preston Holmgren
FRC #2557 (SOTABots)
pHolmgren has a spectacular aura aboutpHolmgren has a spectacular aura about
Watch the ramparts!
Throughout the match the ramparts get breached but near the end of the match the light go back on, as if they had only been crossed once.
I know that nothing can change now but I was just shocked that the system even allows the lights to go back on after they had been turned off.
https://www.youtube.com/watch?v=7UQk...RmsYG&index=19
Preston Holmgren
FRC 2557 SOTAbots
Unread 07-05-2016, 22:53
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Watch the ramparts!
Since the lights can take a while to turn off sometimes, I think they might be manually controlled. Maybe someone accidentally hit the button and turned them back on? I'm not sure how they work, but that's the best I can think of. At about 1:38 in the video, the blue rough terrain is pushed out of its platform. Maybe that had something to do with it?
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 07-05-2016, 23:00
Actually... They WERE only CROSSED once.
Read the full definition of crossing; there are three elements, and one of the three was, in fact, violated on the second crossing attempt. That should have been a wave-off by the refs, I think... but the refs at CMP weren't very good at signaling to each other so the teams could see from the stands.
They are manually controlled, in the sense that the refs have to touch their tablets to record crossings, and recording a crossing controls the lights. Removing a crossing has to be a deliberate act, as it requires two separate button pushes in two different areas of the screen. I would say that that particular crossing was deliberately removed--as for why, see above.
The rough terrain would have nothing to do with that particular incident.
Unread 07-05-2016, 23:08
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
What was the violation? I couldn't catch it. Seemed just fine to me.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 07-05-2016, 23:10
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
I assume (and hope) this match was replayed, right? If they replayed a match when there was no live scoring, they have to replay a match which essentially had the wrong live score.
Unread 07-05-2016, 23:12
ATannahill ATannahill is offline
AKA: Alex Tannahill
Did you read the rules again? They require the bumpers of the robot to pass fully between the shields.
- Arizona North
Unread 07-05-2016, 23:24
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
If you watch, the "foul" ref WAS waving the crossing attempt off and then was talking to the "crossing" ref on the radio. Looks like the conversation went back and forth a few times and then the crossing was removed.
Nate
