Go to Post You know you're addicted to FIRST when robots are sexy! - Pat Arnold [more]
View Poll Results: What did you use for vision tracking?
Grip on RoboRio - IP Camera 3 2.07%
Grip on RoboRio - USB Camera 9 6.21%
Grip on Laptop- IP Camera 19 13.10%
Grip on Laptop- USB Camera 6 4.14%
Grip on Raspberry Pi- IP Camera 5 3.45%
Grip on Raspberry Pi- USB Camera 13 8.97%
RoboRealm IP Camera 6 4.14%
RoboRealm USB Camera 7 4.83%
Other - Please Elaborate with a Response 77 53.10%
Voters: 145. You may not vote on this poll
  #46   Spotlight this post!
Unread 06-05-2016, 09:16
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
Re: What Did you use for Vision Tracking?
Team 107 was using the NI Vision software and IP or USB camera. The vision software was located on the driver station. This has limits for bandwidth from the field but running smaller pictures and some compression we were able to push these limits.
They also had a on board Kangaroo computer running NI Vision and using the network tables to communicates. Doing this will allow for faster video processing in the future if we write our own camera drivers or see what is out there. It also allows for bigger pictures so we get more resolution and accuracy. Doing this would also allow for a second camera to be used going through the driver station so the drivers could see where they were going without taking up targeting bandwidth.
Both solutions were capable of running 30fps so for weight reason they went with the desktop version of the software. It is fun to play with the kangaroo and a target.
  #47   Spotlight this post!
Unread 07-05-2016, 22:24
We used the LabVIEW vision example, integrated into our dashboard. I took a quick look at the teams calibrating their vision on the Einstein Mass field, and over half of them used LabVIEW or the NI Vision assistant.
  #48   Spotlight this post!
Unread 08-05-2016, 10:23
s5511's Avatar
s5511 s5511 is offline
FRC #5511
s5511 is an unknown quantity at this point
Did using the Labview Vision example running on the roboRIO result in a significant performance decrease?
Did robot controls become more sluggish or have more lag because of the extra CPU usage of the Labview Vision Processing?
NC Rookie All Star, Rookie Highest Seed 2015
NC THOR Winner 2015
NC Guilford County Winner and Creativity Award 2016
  #49   Spotlight this post!
Unread 11-05-2016, 16:50
alebcay alebcay is offline
FRC #4828
alebcay is an unknown quantity at this point
We began the season with GRIP running on the roboRIO for an IP camera. For some reason, it would never work on the official field FMSes (it worked fine in our shop and on the practice fields).
We decided to throw all of that out the window and we eventually rolled a Python script utilizing OpenCV on a Raspberry Pi 3 with an accompanying camera module. The Pi communicated with the roboRIO through a USB to Ethernet cable (Ethernet went into the Pi, USB went into the roboRIO's USB Host port), thus creating a separate network between the RIO and the Pi. Finally, we used NetworkTables to actually transport data on the connection. We hoped to avoid any sort of meddling that the FMS might cause by creating our own direct connection between the RIO and Pi (bypassing the radio altogether), and this seemed to do the trick for us.
  #50   Spotlight this post!
Unread 11-05-2016, 17:18
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
That's an interesting idea. How did you get the values over the serial connection?
  #51   Spotlight this post!
Unread 20-05-2016, 10:53
TomLockwood's Avatar
TomLockwood TomLockwood is offline
Lead Mentor
FRC #5712 (Hemlock's Gray Matter)
TomLockwood is an unknown quantity at this point
You reference "The latency correction discussed in the presentation at worlds" - is that presentation available?
Thanks,
Originally Posted by slibert View Post
The latency correction discussed in the presentation at worlds is a great idea. We have a plan for that....
  #52   Spotlight this post!
Unread 20-05-2016, 12:03
alst alst is offline
Programming Mentor
AKA: Alan
FRC #0830 (RatPack)
Rookie Year: 1830
alst is an unknown quantity at this point
Assuming you mean this one, there's a mostly-complete recording of it here. There may be a better recording posted in the future, but I haven't seen it yet if it has been.
  #53   Spotlight this post!
Unread 18-07-2016, 08:09
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Here's an interesting question... did any teams run live tracking like 254? In other words, were any other teams able to get their turrets to track the goal as they drove towards it, dynamically following it?
  #54   Spotlight this post!
Unread 11-08-2016, 14:53
cprofitt cprofitt is offline
FRC #3181
cprofitt is an unknown quantity at this point
We ended up using openCV on a RasPi 2 then used Network Tables to transmit the data to the RoboRio.
