Go to Post ... six weeks, it's too long, but not long enough. - Stillen [more]
Unread 08-05-2016, 15:19
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
1.1 CFM Air Compressors?
What air compressor did your team use this year? Given the increase in the allowable air compressor CFM rating to 1.1, I am wondering what new legal compressors teams have found.
Unread 08-05-2016, 15:49
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Re: 1.1 CFM Air Compressors?
We used a Thomas 215 this year. It run below the 1.1 CFM limit, but the rate at high pressures made it a great compressor to use this year. It does run hot, however. A fan on the piston housing cooled it nicely.
http://www.gd-thomas.com/templates/p...t.aspx?id=2722
Unread 08-05-2016, 16:17
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We also use the Thomas 215. It's worked nicely for us for three years.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 08-05-2016, 16:59
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We used a viair 98C. However there website is now listing a higher CFM because they are using 13.8V instead of 12V this wasn't the case during build season. The ones we own list a 1.10 CFM at 12V directly on the compressor. I may need to call Viair and see if we can get 12V specs for their compressors published again.
Unread 08-05-2016, 17:53
Michael Hill's Avatar
Where are you purchasing the 215 compressor? The only place I've seen is here: http://cfpwarehouse.com/shopsite_sc/...oduct2931.html
But it looks super sketchy.
Do you contact Thomas directly?
Unread 08-05-2016, 18:21
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
The VLAIR 330C-IG is rated to 1.06 CFM at 12V and is 100% duty cycle, so no more overheating if it runs constantly...
The downside of course is that it also weighs over 8lbs.
Would be handy if you needed a lot of air pressure and had spare weight to play with I guess.
Unread 09-05-2016, 18:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Eyeroll completely inappropriate here. This is probably the perfect off-board compressor. You don't care about weight, and the fill-rate should be comparable to or better than the 98C or 100C. If you've got a ton of air to store, it's not going to mind running forever, either.
I'm not clear on why everyone is so big on the Thomas 215. Unless the viair 98C and 100C suffer significant performance hits for running at 12V instead of 13.8V, it seems like they have better flow rates and fill rates than the 215.
Unread 09-05-2016, 18:31
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Anyone have experience with this compressor? Advice on where to buy?
We ran an off-board set up this year and loved it, I don't think we'll go back to on-board any time soon.
However, our old trusty Thomas compressors are getting old, and we are looking to upgrade. This looks like a great alternative.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 09-05-2016, 18:39
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
-Mike
I really enjoyed how your cart included the compressor and water bottles for the drive team. How many pneumatics did you actually have on your robot this year to be comfortable not running a compressor on the robot? How long would it take to fill up your robot air tanks?
I am a bit skeptical of running no compressor on one of our teams robots. Especially with our pneumatapult on our bot this year.
Also not that I have any experience with the compressor but, Amazon seemed to have some comparable prices for the 330C-IG.
Unread 09-05-2016, 18:49
I've attached our calcs for this year, using 1114's pneumatics calc sheet.
We had 8 tanks, all roughly the size of the black Clippard tank.
It took about 5 minutes to charge using an old Thomas compressor.
-Mike
Unread 09-05-2016, 22:39
cbale2000's Avatar
AKA: Chris Bale
Could you post the link for that calculator? I've been looking for something like this.
Unread 09-05-2016, 22:55
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
We got ours from http://www.ridetech.com/store/215-th...or-100psi.html
Unread 10-05-2016, 05:49
Originally Posted by Electronica1 View Post
Thanks. I was searching too narrowly I guess. I was searching for "215ADC38/12". I lose 5 Google-Fu points.
Unread 10-05-2016, 08:25
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
I contacted Vair about their 1.1 CFM compressors, and the customer service rep I spoke with said that the specs they have listed online are incorrect. He was familiar with the FRC pneumatic rules, and confirmed that they are NOT in fact FRC legal.
I wonder how many teams ended up with illegal compressors because the spec sheet was wrong...
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 10-05-2016, 08:43
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
Well considering that spec sheets can be used to prove the legality of components to RI's. What spec sheet evidence is there that these are illegal?
Obviously if it would create an unfair advantage, it would be un-GP to use even if the fact sheet was wrong.
