Go to Post I cannot inspire greatness with mediocrity! - Jim Zondag [more]
Unread 08-05-2016, 20:25
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Continuous Feedback Sensor on CANTalon
Does anyone know if the CANTalon PID supports continuous feedback like the PIDController does?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 08-05-2016, 21:41
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Continuous Feedback Sensor on CANTalon
Hey Tim
Actually the sensor feedback is continuous by default.
AnalogEncoder is continuous (over and under wraps are tracked so 3.3V=>0V equates to sensor pos 1023=>1024).
Same is true for PulseWidth sensors and the CTRE Magnetic Encoder.
AnalogPot is not continuous (meant to be used with analog sources that cannot wrap).
Unread 08-05-2016, 22:31
ArchdukeTim
Originally Posted by ozrien View Post
Hey Tim
So if the sensor is at 200 and I want it to go to 1000 it will go backwards 223?
Unread 09-05-2016, 16:41
ozrien's Avatar
Omar Zrien
AKA: Omar
So assuming 1024 units per rotation (analog sensor), if you want to go "backwards" set the target to -23. This will move backwards by -223 (since your current position is 200), instead of moving forward by 800 (pos200=>pos1000).
The basic idea is if you want to move forward, use the appropriate multiple of your target position in the positive direction. If you want to move reverse, use the appropriate multiple in the negative direction. If you want to servo using the shortest distance, calculate how far the target is moving forward, and moving backwards, pick the shortest one, and use that as the final set point.
Attached is an excel sheet demonstrating a few examples of how to do this.
Unread 09-05-2016, 17:21
If I may:
Let P be your present angle sensor reading (converted to degrees)
Let T be your desired angle position (in degrees)
the angle between them (let's call it ERR) is found by the equation:
ERR = (T-P) - 360*floor(0.5+(T-P)/360);
the above returns a value for ERR between -180 and +180 degrees,
the shortest angle path to the target.
So it tells you which direction to rotate as well as how much to rotate.
So compute your setpoint:
SetPoint = P + ERR
Unread 09-05-2016, 17:36
Or in native units do this:
double P=200;
double T=1000;
double SetPoint;
void main(void){
SetPoint  = T - 1024*floor(0.5+(T-P)/1024);
printf("P=%f  T=%f   SetPoint=%f \n",P,T,SetPoint);
Output:
P=200.000000  T=1000.000000   SetPoint=-24.000000
If the sensor goes from 0 to 1023, then you have to go backward 224 steps (not 223) from 200 to get to 1000.
(Because 0 is equivalent to 1024, just as 0 is equivalent to 360 degrees).
Unread 09-05-2016, 18:18
If your compiler supports the REMAINDER function "x REM y" per IEC 60559 as specified on Page 235 Section 7.12.10.2 of ISO/IEC 9899:TC3 (which java does I believe), then the following single line of code should work:
SetPoint = P + Math.IEEEremainder(T-P,360.0);
or in native units:
SetPoint = P + Math.IEEEremainder(T-P,1024.0);
