Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
  #37   Spotlight this post!
Unread 09-05-2016, 15:23
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Workshop/Tools/Parts
Originally Posted by Cory View Post
Automatic feed is a huge advantage. When cutting thicker materials it makes a big difference in blade life.
A horizontal is also more likely to have a wider blade, which is going to cut straighter and withstand more blade tension.
Most importantly it's going to give you a much straighter cut than a vertical purely because the material is static and the blade is moving. This is important for anything going on a mill/lathe.
If you can only buy one though, the vertical is the way to go.
One other advantage of most horizontal saws is that you can cut long objects. Many vertical saws have a "throat" that only allows for 12-36" depending on the saw size. Most horizontal saws tweak the angle of the blade such that the saw can cut any length of material. Long material may require additional supports to keep cuts straight and material from falling.
