Go to Post I would argue that you are not overdosed if you don't know the correct name of this year's game - KarenH [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 10-05-2016, 08:08
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: OpenCV Python! Where to start?
Originally Posted by tomy View Post
I wrote some simple code to calibrate the camera in openCV using Track-bars. Would you like a copy of it? I haven't had time to implement it into working code yet I'm just using it to get the values for HSV and manually putting them into another part of code.
This was my last year so I doubt I'll be able to make use of it. You can always post it on this sub forum if you think it merits use.
