Go to Post yes, we've gone over every possible idea multiple times. No, we're not going to stop. Welcome to FIRST. - logicalyrandom [more]
Unread 10-05-2016, 08:43
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
Re: 1.1 CFM Air Compressors?
Originally Posted by cbale2000 View Post
Could you post the link for that calculator? I've been looking for something like this.
Here's a more recent version of the calculator. We added extend and retract pressure in case we wanted to use inline regulators to save some air when we don't need as much force in one (or both) directions.
We've been using the compressor off-board since FIRST opened up the pnuematic air tank rules in 2011 to allow plastic air tanks, and haven't looked back.
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 10-05-2016, 08:45
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Originally Posted by Michael Hill View Post
Where are you purchasing the 215 compressor? The only place I've seen is here: http://cfpwarehouse.com/shopsite_sc/...oduct2931.html
But it looks super sketchy.
Do you contact Thomas directly?
I've bought from these guys for 3 years -- no issues and fast shipping.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 10-05-2016, 08:49
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Originally Posted by roboruler View Post
Well considering that spec sheets can be used to prove the legality of components to RI's. What spec sheet evidence is there that these are illegal?
Obviously if it would create an unfair advantage, it would be un-GP to use even if the fact sheet was wrong.
The spec sheets are updated now. Here are some snippets from my convo with the rep. Not trying to put any teams on blast for using something with misrepresented properties; there's no way they could have known.
Regarding the 97C and the new 1.1CFM restriction
Originally Posted by VAIR
Eric,
No problem at all. We've had a few people inquire about that and our new testing has changed the CFM to 1.52. We are just waiting for final confirmation so it can be changed on our site.
Thanks,
VIAIR
Follow up asking about the 100C
Hello Eric,
Unfortunately even the 100C is going to be out of spec once we list the new CFM data. The new CFM at 0psi for the 100C will be 1.27.
Hope that helps and let me know if there is anything else I can help you out with.
Thanks,
VIAIR
Asking about other legal compressors
Hello Eric,
Thanks for contacting VIAIR! The only compressor we have seen work for FRC is the 90/92C. They are available through Andy Mark or a number of our distributors. That would be the least expensive option for you since they will also give you free shipping.
Thanks,
VIAIR
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 10-05-2016, 09:26
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
All of these values are for a supply voltage of 13.8 volts. The 100c, as an example, is 1.27 CFM at 13.8 volts. If 12 volts is the supply voltage, is the CFM reduced at the same ratio? 1.27 CFM at 13.8v is 1.10 CFM at 12v thus making it legal?
Like Aquidneck Island Robotics on Facebook!
Unread 10-05-2016, 09:37
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Math does not make them legal. Only a spec sheet detailing the CFM makes it legal. The Thomas 215 and VIAIR 90/92 meet those requirements.
Unread 10-05-2016, 09:48
Rick's Avatar
Ready to STRIKE!
AKA: Rick Blight
Is VIAIR aware that we run these compressors at 12 volts? It would be nice to a spec sheet for 12 volts.
We'll see what the 2017 rules and Q&A have for rulings.
Unread 10-05-2016, 09:55
Might be worth reaching out to them. Their customer service was very responsive!
Unread 10-05-2016, 10:12
FWIW I just checked, and VAIR lists the performance data of the 90/92/95C at 13.8V as well.
Unread 10-05-2016, 18:33
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Yes this is definitely an issue. I'll try to call them tomorrow if I have time. Do we know for sure that it was just their measurements that changed or did they change anything about the compressor it self. It would make sense that they would want to rate their compressors at higher CFMs (for every application other than FRC). Currently we have no way to prove the legality of any VAIR compressor since we don't have a 12V CFM rating at 0psi for any of them. We can assume the 90/92/etc are legal since we are supplying a lower voltage but we don't actually know their CFMs at 12V either.
Unread 10-05-2016, 20:21
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
The VLAIR 330C-IG is rated to 1.06 CFM at 12V and is 100% duty cycle, so no more overheating if it runs constantly...
The downside of course is that it also weighs over 8lbs.
Would be handy if you needed a lot of air pressure and had spare weight to play with I guess.
We had the weight to play with it and used it on-board. Loved it. We had issues with the little kit viair because as it started going south, it seemed to give us issues with the PCM, causing all of our pneumatics to fail. Simple solution is to mount it with a spike, but we opted to go bigger this year. HAD to use a spike because of the higher AWG wire.
Edit: The only issue we had was when we mounted our fittings into the head, we over-torqued it and cracked the head. We had a high-strength epoxy we used around the fitting and didn't have any issues.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
