Go to Post No, I'm not a Superhero...I'm a FIRST Mentor. Common Mistake. - Mr. Van [more]
  #106   Spotlight this post!
Unread 06-05-2016, 09:39
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: New Off-season Defenses
Originally Posted by maxnz View Post
Let me ask this: Where exactly was the problem on the portcullis? I know what the problem is but I just want to know what part of the portcullis caused the problem. Then we could try to think of a new portcullis that removes this problem.
1) Size
2) Little bit topheavy
3) The giant blade that can easily deal enough damage if it slides on its track
4) the fact that, atleast in FiM, you have to have four people grab the portcullises and shove them on top of everything else
  #107   Spotlight this post!
Unread 06-05-2016, 11:45
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by DareDad View Post
So, an improved portcullis is:
  • lighter.
  • has no exposed counterweight components.
  • has fewer sharp edges.
  • has a door that can be locked in place during transport.
  • has handholds for the field reset folks.
I'm sure there's more.
I'd specifically say "has no exposed track components" - the weighting isn't the issue regarding pinch points (aside from the top-heaviness), it's the exposed track/wheel And if you cover that, you also pretty much cover the spring. But otherwise, that's a solid list. Just adding a latch/lock or handholds alone would have saved a lot of fingers.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #108   Spotlight this post!
Unread 06-05-2016, 12:17
scott.smith's Avatar
scott.smith scott.smith is offline
Inventor guy
FRC #0639 (Code Red Robotics)
Team Role: CAD
Rookie Year: 2015
scott.smith will become famous soon enough
I have heard a lot of ideas for a rolling log defense, and I really like the concept, but I feel one rolling log would be impossible to get over. I think that a better design for the defense would have 3-5 rolling cylinders, so it still has challenge, but isn't impossible.
  #109   Spotlight this post!
Unread 06-05-2016, 12:46
Doug Frisk's Avatar
Doug Frisk Doug Frisk is online now
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
Something like 5 lengths of 1 1/2" PVC suspended across the base on taut paracord?
I like it, but it seems to me that something would have to be added to slow the robots down, otherwise crossing that defense would simply be a matter of charging at it at full speed at which point the defense wouldn't last more than a couple of matches.
  #110   Spotlight this post!
Unread 06-05-2016, 12:49
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
This was the strategy for over half of the defenses this year... including the portcullis.
  #111   Spotlight this post!
Unread 06-05-2016, 16:38
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
A box with closing walls. Cause everything should get a great big hug:
or
Something like this:
Drive fast...drive true...otherwise it will kind of crush you:
  #112   Spotlight this post!
Unread 06-05-2016, 17:46
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
or
YES! Definitely! This or a Bomb-Omb, or maybe a Chain Chomp. Goombas and Koopa Troopas would probably be good too.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
  #113   Spotlight this post!
Unread 10-05-2016, 10:44
Flywheel Police
Just wanted to give everyone a heads up of what I've heard from HQ.
Matt, thanks for your patience on this.
We just sent emails to District management instructing them not to supply the full portcullis to off-season events, but giving them the OK to supply the portcullis bases (as you have pictured below). As the game-specific elements stay with the Districts after the season is over, they have control of their own destinies on this.
We’ve also provided similar instructions to AndyMark.
  #114   Spotlight this post!
Unread 10-05-2016, 13:39
TheMagicPenguin's Avatar
TheMagicPenguin TheMagicPenguin is offline
AKA: Josh B
FRC #1640 (Sab-BOT-Age)
TheMagicPenguin is an unknown quantity at this point
There is no problem with the portcullis.
I competed at MAR district and even was a field reset volunteer at one of the events. I never hurt myself on it (wasn't wearing gloves either), and I haven't heard of anyone else hurting themself on it. Sure it's possible but after you get a cut once you learn to not put your fingers there. That simple. Getting rid of it because a few people weren't paying attention is ridiculous. With that logic we may as well get rid of all defenses because people can cut themselfs on it.
Getting rid of the portcullis penalizes all the teams (like mine) who spent hours on a autonomous for it. Even if HQ is nit letting people ship it out, make a almost identical defense, that doesn't penalizes teams who built a specific mechanism for it.
  #115   Spotlight this post!
Unread 10-05-2016, 13:45
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
If it were in season, you can bet that all of us would be up in arms over this. Hell, look at the reaction when they changed the material of the low bar, let alone got rid of an entire defense.
Since it's off season though, I don't feel quite as shafted that they're not distributing the Port. It's large, difficult to see around when reffing (Particularly when it's in position 2 or 3), and there seems to be a few "major" injuries related to it (Or at least, more injuries than I've heard about from past seasons field reset), and teams have already had a chance to use whatever mechanisms that were purpose built.
And on the plus side, if you take off your Port manipulator, you might now have enough weight to cheesecake a climber on!
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
  #116   Spotlight this post!
Unread 10-05-2016, 14:00
AKA: Josh B
I see your points and your certainty not wrong, but I still believe it's not enough of a reason to get rid of it.
I would normally agree with this however we already have a hanger and a pound or two to spare. Another good point though.
  #117   Spotlight this post!
Unread 10-05-2016, 14:25
Flywheel Police
There were multiple instances of multiple fingers broken because of the portcullis. That right there is absolutely enough reason to send it to the off-season events.
Had it been sent I would still be considering not running it at the Rumble in the Roads. The last thing I want is one of my volunteers to get a major injury.
  #118   Spotlight this post!
Unread 10-05-2016, 14:39
PayneTrain's Avatar
PayneTrain PayneTrain is online now
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
yea matt but what about the love of the game bro
  #119   Spotlight this post!
Unread 10-05-2016, 14:40
Flywheel Police
  #120   Spotlight this post!
Unread 10-05-2016, 18:38
Crew Cox's Avatar
Crew Cox Crew Cox is offline
Electrical team Captain
FRC #5546 (A.R.T)
Team Role: Driver
Crew Cox is a jewel in the roughCrew Cox is a jewel in the roughCrew Cox is a jewel in the rough
Anyone got an old treadmill belt and some spare 775s?
Really easy to cross one way not so much the other.
