Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Unread 10-05-2016, 15:22
Professional Stat Padder
Re: pic: Houston Venue for Championship 2017
Originally Posted by Cory View Post
Hopefully FIRST springs for some with seatbacks this time around.
This. There is nothing worse than sitting the entire day in the stands scouting without seat backs.
Please, dear FIRST, give me seat backs.
(2015-Present)
Unread 10-05-2016, 15:27
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by Richard Wallace View Post
If each field has 100 ft of 15 row bleachers on each side, about 1200 per field could be seated. Each field would occupy about 16,000 sq.ft. This would be much larger than the pit-area fields that St. Louis used a few years ago, but I think it is necessary to provide enough seating in subdivisions. Einstein will be another matter -- not sure how that is going to fit in a convention hall.
So if the fields take up 64K SqF, that would leave about 440K SqF on the first floor for pits etc. Which is 150K SqF more than was allotted to FRC pits this year for 600 teams. Provided there is enough rentable seating available in Houston, I think FIRST can manage to have enough seating available around the fields.
Originally Posted by Tim Sharp View Post
"Bleachers" and "Comfortable" are oxymorons
Xavier is referring to the pullout seating on the 3rd floor of GRB. It's made of individual molded, padded seats with armrests and everything:
I can assure you it is indeed quite comfortable, but I don't know if it's the seating that will be used on the 1st floor where FRC is bound to land.
Originally Posted by Xavbro View Post
The convention center is very large and has 3 different floors. If they only have 4 divisions, I can see it all fitting nicely in the convention center. Maybe two divisions on the first and second floor with Einstein being on the 3rd floor. FLL and FTC could be on the third floor all together.
Xavier, there's 3 floors but only 1st and 3rd have actual floor space. 2nd floor is a long hallway, a few conference room, and some windows staring out into the 35' of ceiling space on 1st floor.
Unread 10-05-2016, 15:43
Originally Posted by Karthik View Post
Sounds like a cool setup. I had far less problems with the pit fields in 2011 than most of my peers. Any idea on the logistics of moving robots and pits from the convention center to Minute Maid for Einstein? How far is this walk?
Google says 0.2mi from the nearest corner of GRB to the near side of Minute Maid. Convolutions to get down to the field would add some time and distance to this. IF* they do it this way, there's obviously going to be a fair bit of traffic to get field crew, etc. down there. They'd probably close down the roads, though I don't know that they'd provide covering as well. I would actually hope for a solution like rolling everything into a 15 foot UHaul and making a short drive over. If we're talking about pit fields, then it's not like you're dragging your entire pit onto the field for division elims again like this year, so it'd only be one giant move between Division Finals and Einstein for 16 teams.
I didn't mind the pit fields that much in 2011, other than the bleachers being very uncomfortable. Hopefully FIRST springs for some with seatbacks this time around.
I will certainly pass that request along. I can see that seating with seat backs is rentable, so I'm going to assume that it'd come down to cost vs. benefit thing. I'll try to explain the benefit as clearly as possible to Lucia.
*Caveat that the event is a year off and my information is from a single member of the board.
Unread 10-05-2016, 18:33
REVving up for a new season
FRC #2848 (All-sparks)
The thing that I want to know is how many fields will there be at each event.
This year we had 8 for 600 teams at ~75 teams per division. This was nice because everyone got 10 matches and for the most part didn't seem rushed. The negative is that is spread the team talent out.
Assuming that each Championship gets 400 teams, are we going to see 4 ~100 team divisions (like the 2014 champs) meaning we will likely see 8 matches per division or are we going to see 8 divisions with 50 teams? (which seems like a bad idea from robot strength but fun when you get to play 12 matches). Could 6 fields work? How would eliminations work on Einstein in that case?
Has this been announced anywhere?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 10-05-2016, 18:36
6 fields would work just fine with Recycle Rush's points based quarter-finals. *ducks*
Unread 10-05-2016, 18:42
Billfred's Avatar
Billfred Billfred is offline
EricH and I hashed out the math here. With a 6-minute cycle time (so either a really fast reset game and/or dual fields), you can get 10 plays out of the 2016 schedule with four 100-team divisions.
And people said will.i.am used dirty words...
Unread 10-05-2016, 18:58
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
They could do it MSC style and have each division have tow fields and bounce back and forth between even and odd matches and do a dozen matches for each team like like MSC does.
Unread 10-05-2016, 18:59
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I propose we take a page out the VEX playbook.
5 Divisions each with 80 teams and a full round robin for Einstein. Everyone plays every other division once and the best 2 records play a best 2 out 3 finals.
Unread 10-05-2016, 19:34
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
While it does work well for drive teams and volunteers, MSC two-field style is not going to be good for those in the stands. This is because bleacher seats for two fields will not provide adequate viewing of both fields. The much larger seating capacity of the Deltaplex (22 rows on one side, 36 rows on the other) make seeing both MSC fields easy from most seats. Bleacher seats will likely be 15 rows.
80 teams is still too many to share bleachers and allow adequate views for scouting.
So, I think 8 subdivisions of 50 teams each makes the most sense. 100 qualifying matches, 12 plays per team. That will sort out the subdivision seeds.
I also like round robin Einstein, but maybe in four groups? Four alliances per round robin group, comprising finalists from each subdivision. Then send group winners to the final four. Group play on the convention hall fields, final four in the big arena.
Richard Wallace
since 2003
Unread 10-05-2016, 19:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'd rather have 8 matches than have 50 team divisions...if they go with 8 divisions you may as well crown the champ on Friday night because those will be about the shallowest fields ever.
2001-2004: Team 100
2006-Present: Team 254
Unread 10-05-2016, 19:52
araniaraniratul's Avatar
araniaraniratul araniaraniratul is offline
294-Alum
AKA: Arani (Ron) Bhattacharyay
araniaraniratul is a jewel in the rougharaniaraniratul is a jewel in the rougharaniaraniratul is a jewel in the rough
Send a message via AIM to araniaraniratul
Or you know, watch them pull the top 50 in this year's Newton
The Greybots
973
- Mentor
Beach Cities Robotics
294
- Student/Mentor
The Sloth Bears
5499
- Mentor
Unread 10-05-2016, 20:54
And then watch Newton get eliminated on Einstein anyways. How different would it really be with 8/50? I'd you think it's that predictable, you're basically assuming 1seeds out of each division. Would the 1 seeds out of 8/50 look that different than 1 and 2 out of 4/100? 2nd and 3rd picks would be weaker, but there's usually a big drop off there anyways.
Unread 10-05-2016, 20:57
Billfred's Avatar
So if my team escaped the 64-team Palmetto Regional (where 24 make the show), we'd attend a 50-team Championship subdivision (where 32 make the show)?
I know I've been one of the people ill at ease over the dilution of the Championship, but this feels like someone took the can of Diet Dew and poured it in a 5-gallon bucket of water.
Unread 10-05-2016, 21:14
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
I decided to work on a 6 alliance elimination schedule. This is probably a crazy idea, but it'll probably work.
Match    Blue   Red
TF1       1        6
TF2       2        5
TF3       3        4
SF1       TF1    TF2
SF2       TF2    TF3
SF3       TF2    TF3
F1          SF1     SF3
(repeat each match, then do tie breakers, like normal eliminations)
To explain this, the Tri-Finals (for lack of a better name) would be the equivalent of the current Quarters. The Semi-Finals is where it gets weird. They get split up into two Semi finals, one with TF1 and TF2 winners, and one with TF2 and TF3 winners. The big caveat of this is that TF2 winners have to play two semi final matches instead of one like everyone else, unless they win both of their matches (both SF1 and SF2),in which case, they do a tiebreaker for the two losers. The two winning alliances then go onto regular finals.
With only six alliances, there's a potential maximum of 27 rounds for eliminations, assuming each round goes to a tiebreaker. There's a minimum of 14, so I could see the wide variety of times to plan for an issue. But it proves that six alliance playoffs are possible.
EDIT: Made a quick flowchart of how this proposed flow would go:
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Last edited by Bkeeneykid : 10-05-2016 at 21:43. Reason: Edited Flowchart for correct match numbers
Unread 10-05-2016, 21:34
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I find the idea of shifting from the Championship event with 4 fields at 100 teams in 2014 to 16 fields between the 2 postseason expos at 50 in 2017 intriguing. Coupling that with the knowledge we have only had a 15.6% increase in the global team, it's a very thought provoking scenario. The thought: why not just save tens of thousands of dollars and go to a mid-tier out-of district event?
