#31
Re: pic: Houston Venue for Championship 2017
As I understand each round proceeds normally, there are two matches played, if each match goes to a different alliance than a third is played hopefully generating a winner. The winner of the TF1 round moves on, the winner of the TF2 round moves on and the winner of the TF3 moves on. I do not understand how you narrow down from the three Tri-final winners to the two finalists. Edit: The flowchart makes it easier to understand, I would suggest switching the names of SF2 and SF3. How do you even out the fact that TF2 has played twice as many matches as TF1 or TF3 if SF2(3) is not needed? Last edited by ATannahill : 10-05-2016 at 21:40. |
#32
I suggest you create a table with the following columns: Independent 1: Outcome of SF1/3 Independent 2: Outcome of SF2/4 Dependent 1: Is SF5/6 played? Dependent 2: what alliances become finalists Dependent 3: If D1 is no and D2 includes TF2 (I'm not 100% sure this is possible), how do you make things fair for TF1/3? Another question: What if TF2 plays hard in matches 1 and 3 but doesn't try (maybe even doesn't field a robot) for matches 2/4? |
#34
To give another example for this proposed system, I redid this years Einstein matches in this format. I had to cut two alliances (Sorry Archimedes and Carson, I still love you!), but I made some reasonable predictions so that the finals rounds would still be the same. The quarter finals are the same schedule as the Tri-Finals.
Blue Red TF1 Newton Hopper TF2 Galileo Tesla TF3 Curie Carver TF1 M2 Newton Hopper TF2 M2 Galileo Tesla TF3 M2 Curie Carver TF3 M3 Curie Carver SM1 Hopper Tesla SM2 Carver Tesla SM1 M2 Hopper Tesla SM2 M2 Carver Tesla SM2 M3 Carver Tesla SM3 Hopper Carver SM3 M2 Hopper Carver SM3 M3 Hopper Carver F1 Tesla Carver F2 Tesla Carver F3 Tesla Carver |
#35
SF1 SF2 D1: D2: Finalists TF1 TF2 Not TF1,TF2 TF2 TF2 Yes TF2,SF5 TF1 TF3 Not TF1.TF3 TF2 TF3 Not TF2,TF3 In responce to your other question, I feel that would be going against Gracious Professionalism. If they are not completely sure that they would win the other semi final match, this would not be a viable strategy. I would say if they refuse to field a robot on one of their semi final matches, they would be punished by forfeiting all semi final matches. In this case, the finalists would be TF1 and TF3. |
#36
Block out the prime sections for scouts and VIPs, and make sure everything else has intentionally bad sight lines to the further field (don't want to leave any prime seating free-for-all because people will fight over it). |
#38
I'm starting to get worried that if this thread goes any farther, Bkeeney might stumble upon the forbidden words and summon the Elimination Bracket of Doom.
#39
Reserve your hotel rooms early !
There are many hotels downtown within walking distance of the convention center. The light rail "Convention District" stop is the closest to the venue. http://www.houstontx.gov/abouthouston/lightrail.html Houston has lots of parking, but Bus parking can get complicated especially with the new construction for the SuperBowl. |
#40
I'm curious if any teams will check out the Houston tunnels for lunch Friday . . . so few people ever know about them and the East End expansion is just across Discovery Green now
http://www.downtownhouston.org/site_...DMAP2015-2.pdf |
#41
Did they already say if they'll use the same scientists' names in both 'championships?'
I'd be cool with them adding some famous engineer names. |
