Go to Post The thought of destroying any robot is just......depressing :( - Richard McClellan [more]
Unread 10-05-2016, 22:55
Paul Richardson Paul Richardson is offline
Strategy/Mechanical/Drive Coach
no team (1477/3320)
Paul Richardson has a spectacular aura aboutPaul Richardson has a spectacular aura about
Re: pic: Houston Venue for Championship 2017
Originally Posted by Richard Wallace View Post
While it does work well for drive teams and volunteers, MSC two-field style is not going to be good for those in the stands. This is because bleacher seats for two fields will not provide adequate viewing of both fields. The much larger seating capacity of the Deltaplex (22 rows on one side, 36 rows on the other) make seeing both MSC fields easy from most seats. Bleacher seats will likely be 15 rows.
With a bit of planning, the problem of poor viewing angles could be used to solve the problem of insufficient seating. If people can't stay in one spot and see every match they will naturally come and go to switch which field they're watching (or visit the pits, or something else), opening up seating.
Block out the prime sections for scouts and VIPs, and make sure everything else has intentionally bad sight lines to the further field (don't want to leave any prime seating free-for-all because people will fight over it).
