Re: Drive Base Help
Re: Drive Base Help
It seems like using this with pneumatic wheels would be very easy:
http://www.team221.com/viewproduct.php?id=130 |
Re: Drive Base Help
Wow, so much help! You guys are great!
Re: Drive Base Help
Ok, to answer some questions:
We are planning on taking the new bot to an offseason event, probably Calgames. Our old bot ran a KoP 6WD with 8-inch pneumatics. We had major issues with our gearboxes, which happened to be the exact same 3-CIM ones suggested before. Since the only thing we could do was defense, our gearboxes took a lot of stress and it was enough to fracture and completely shred our aluminum gears. We were advised to just use 2-CIM systems in the future and also decent steel gears. Also, we didn't secure our gearboxes very well, and that combined with the hole we had in the frame for intake resulted in the bot bowing inwards and twisting the wheels/axles out of alignment. The wheels were actually hitting the metal of the base. This was probably exacerbated by turning scrub, since all wheels were on the same level. So, we took the bot apart multiple times at competition, which was a pain with the KoP base. We aren't trying to rebuild the same bot though-we're entirely redesigning. Also, with 6 8-inch wheels, it was a really really tight fit. We had to trim down the bars perpendicular to the wheels so that they wouldn't hit the metal. Also, does the KoP base have pre-drilled holes that would let us drop wheels a good distance? The AM2494 and 221's chassis seem simple and stable, but would we be able to drop wheels with them? After reading through, we're leaning towards the VersaChassis. Also, using four Colsons and four pneumatics sounds good. When teams go over obstacles like the cheval and moat, they tend to fly over and then land. Is stress upon landing an issue with the Colsons? Thanks so much for the help, everyone! ![]() |
Re: Drive Base Help
Re: Drive Base Help
If you're using pneumatic tires, you can just inflate the center wheels slightly more than the outer wheels, or use a belt sander to take off some of the tread on the outer wheels. (or both) Not only will it create a drop center, you'll have less issues with turning scrub.
#7
Re: Drive Base Help
Do you have access to a press brake? If so you could build something similar to our drive this year (pictures below). We used 8 8" wheels with 15mm belts and 4 toughbox micros at 12.57:1 (I think). We used 1/2in of drop on the centre wheels. The side plates are .090 5052 aluminium, laser cut, but could be handmade.
#8
Re: Drive Base Help
Re: Drive Base Help
I would be careful with using the angled plate of you plan to have an opening in the middle.
#10
Re: Drive Base Help
The 3/8 drop works well with pneumatic wheels, you are right in that inflation barely does anything at all on these specific AM wheels. I saw a team next to us really struggling at Champs to get their robot to turn without brownout issues because they neglected to include the drop. I told them to try wrapping the center wheel with layers of duct tape and that actually fixed their issues aside from the duct tape appearance.
#11
Re: Drive Base Help
The Team Cockamamie Robot in 3 Days build also ran an open front and saw the same frame bending you describe on a smaller scale before we parked it--it also had a way-too-small bellypan in hindsight and suffered for that. You aren't going crazy there either. Strongly consider a sturdy plywood bellypan on your offseason robot; it will lower your CG a bit and give you some great resistance against twisting and bending. If you're using the AM14U3 with 8" pneumatic wheels, there are different hole placements and belts you're supposed to use. They sold them as a kit, which would place the axles at the correct place to avoid notching the end bumpers. It would also space the outer plates out further to cut down further on rubbing. We didn't drive the Team Cockamamie robot on carpet or at high weight (we were waaaaaaay under), but the drop was enough for that. You can also play with air pressures there; a little less pressure in the corner wheels will increase the effective drop. 4901 used a variation on the 221 chassis for its drivetrain this year, except we knew we wanted drop (especially since our corner wheels were pushed inboard). We ended up using 1x3 tubing for the drive rails, which was overkill but suited the purpose of putting our axle holes exactly where we wanted. Hope some of these data points help! Last edited by Billfred : 11-05-2016 at 15:07. |
#12
Re: Drive Base Help
I suggest that if you are redesigning a robot in the offseason to complete the same challenges that Stronghold had such as the moat, I would consider using the AM14U3 from andymark with the Upgrade Kit 6WD with 8" Pneumatic Wheels. This will give you suspension and a bit of bounce when going over obstacles. Just note, this drive base CANNOT go over obstacles without in house customization. Our team noticed that at the competition our robot could not cross any defenses other than the rough terrain. We used an angle grinder to cut off about an inch off of the bottom of the front of our chassis and made an angle so that when we would hit an obstacle it would pop our bot up onto the moat, ramparts, rock wall, or rough terrain, which would allow our wheels to get on top of the defense and drive over with ease. We had only gotten stuck in the moat only one match and that was when our path was obstructed with a boulder. I also suggest adding support in the middle of any chassis to ensure the sides do not cave in (just a precaution)
Hope this helps! |
#13
Re: Drive Base Help
#14
Re: Drive Base Help
See the attached photo. Every team should be supporting their gearboxes in some way because it will also stiffen your frame up. |
#15
Re: Drive Base Help
