Go to Post Have you ever found yourself staring at a physics problem, not understanding it, then connected it to a past FRC game and suddenly felt the light bulb start shining? - StephLee [more]
Unread 12-04-2016, 13:17
Re: Radio discontinued?
That limitation was the source of one of the fatal flaws in the DLinks.
Unread 12-04-2016, 14:49
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Originally Posted by Thad House View Post
Something interesting is looking at the OM5P-AC, its looks like in order to meet new FCC standards they are not allowing external firmwares to be loaded onto the device. With FIRST wanting to write their own firmware this could be a problem for pretty much any new radio they choose.
If the Manufacturer approves the new firmware, then it is ok to load.
Unread 12-04-2016, 15:13
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
My understanding from Beta testing is the FCR firmware really isn't custom. You can download it from AndyMark. The FRC version uses specific configuration profiles.
Unread 11-05-2016, 11:12
bobbysq bobbysq is online now
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
I really hope the replacement has a boot time of 10 seconds at most. Programming the routers for events this year took way longer than before.
Unread 11-05-2016, 11:21
The router's embedded web server is a major contributor to the boot time. If teams can live without a convenient web interface to the settings, perhaps it can be removed from the FRC-specific firmware.
Unread 11-05-2016, 11:33
Rookie Year: 2015
That wouldn't be too bad if there was just a file to edit. The router config could also then be done by simply copying over the file.
Unread 11-05-2016, 11:42
Web server is essential to configuring the router when you can't get the software to work.
I don't see why they can't have the basic functionality of the router boot quickly, then let the webserver boot up in a parallel process.
