Go to Post I wouldn't want to replay Lunacy -- the Moon is a harsh mistress! - Richard Wallace [more]
Unread 11-05-2016, 23:22
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Re: What COTS parts would you like to see?
Originally Posted by ASD20 View Post
VexPro offers an assortment of delrin 3/8 and 1/2 inch hex spacers.
http://www.vexrobotics.com/vexpro/ha...rs-vexpro.html
Whoops, knew about the 1/2" hex but not the 3/8". Guess I'll settle for just the round variants then.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 11-05-2016, 23:24
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Since they're just spacers, can't you use the hex spacers on round shaft?
Unread 11-05-2016, 23:31
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
Originally Posted by Eric Scheuing View Post
Stronger alloy options for gear stages.
7075-T6 is the best alloy for aluminium gears available.
Yes, perhaps small gears such as those gears up to maybe 24 tooth could have the option of being replaced with drop in 4140 gears.
Unread 11-05-2016, 23:37
AKA: Thomas
Team Role: CAD
Every broken gear picture on CD has the teeth sheered off. I've never seen the body of a gear crack. So, the failure mode seems to be the teeth. Would 4140 steel gears with lightening holes be an option? How much more would it cost?
Unread 11-05-2016, 23:38
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
After going through a season thinking "man, I wish we had a -----", I'm totally blanking out.
The tube spacers would be super useful, for sure. That would have saved us a lot of pain this year. Other standoffs would also come in handy.
Totally separate CIM mounting holes on the WCP gearboxes- the CIM bled into the 12t pinion mounting distance from the 14t distance, causing massive friction.
3/8" hex versahubs, however the 3/8" hex to 1/2" hex adapter by WCP solves a lot of 3/8" hex issues.
More GT2 belt pulleys would be great; WCP sells 12t pulleys and belts but not the larger hex broach pulleys we need! Small 12t 5mm HTD pulleys would also be nice.
Unread 11-05-2016, 23:45
Right angle output stage for the Versa-Planetary gearbox, not an adapter but an integrated output stage that takes the place of the normal output stage.
Unread 12-05-2016, 00:00
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
This would be very useful, depending on the input motor and the reduction there would be significant torque on the bevel gears( if bevel gears were used). It might be difficult to find small enough bevel gears that would be able to take the torque.
How efficient are bevel gears? I've heard worm gears can be quite in-efficient.
I know team 33 made a tutorial on how to modify a versa-planetary and a drill/driver right angle adapter to accomplish this:
http://www.chiefdelphi.com/forums/sh...ht=right+angle
Unread 12-05-2016, 00:06
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Cycloid stage in a versa planetary. Couple that with a right angle adapter and you've got a monster of setup to lift arms etc.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 12-05-2016, 00:08
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
VersaBlock with 1/4" drop when flipped allowing drop combinations of the following when mixed with the current 1/8" flipped:
1/16", 1/8", 3/16", 1/4"
Unread 12-05-2016, 00:13
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
1/2" hex bore bevel gears.
I'm sure there are others I could think of, but that's what pops into my mind right now.
Unread 12-05-2016, 00:19
AdamHeard's Avatar
Lead Mentor
The attached gear was pocketed on each side .112, leaving a web thickness of .150.
Unread 12-05-2016, 00:56
That is a 7075-T6 gear isn't it?
Andymark sell a few gears with weight saving holes in, I think in the weight saving your not going to be able to reduce enough weight to make it equal to an un-weight saved Aluminium gear however it would still be great to do some experimentation
Team 254 did some really nice weight saving for the large VEXpro aluminium first stage gear in their CIM-over wheel gearbox, I'm not sure if they had any problems with any gears during the season.
We probably don't want to hi-jack the thread with a Aluminium gear vs steel gear debate
Unread 12-05-2016, 01:01
Knufire Knufire is offline
Is the slot to prevent the gear from resonating?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 12-05-2016, 01:17
JohnFogarty's Avatar
AKA: @doctorfogarty
Originally Posted by Sperkowsky View Post
A metal versaplanetary cim adaptor.
10/10 would buy.
John Fogarty
Unread 12-05-2016, 01:19
Oblarg Oblarg is offline
AKA: Eli Barnett
Clamping hubs and other hardware. I've been waiting for an FRC supplier to do a clamping hub for *years* and, so far, been disappointed.
"The breakfast of champions!"
