Go to Post Have we all said "thank you for all you do" lately? :) - RoboMom [more]
  #46   Spotlight this post!
Unread 12-05-2016, 09:04
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
Re: What COTS parts would you like to see?
I second what Sperkowsky said about the metal versaplanetary adapter and gussets. If it was metal it could be a lot smaller.
I would also like to see the versaplanetary encoder housing be made out of the same metal as the gearboxes because we had two of the plastic ones create a failure where once the encoder cracked and failed the entire gearbox would fall to pieces in our robot. The bolts failed in double shear and we had three pieces of each bolt every time this happened on two different gearboxes. I will attach photos to show the failure. I think we already sent this to Vex but I will check on that. I think vibration was the cause of the failure and not overloading based on our applications.
I also strongly agree with what Marshall said and will add a little on to that. If the AndyMark kit came with bumper instructions and sheet metal hardware for next year I feel like some of the teams with fewer resources in NC would actually arrive to competition with bumpers and I would not have to help them build the bumpers before inspection! It would be nice to have something sort of like an "add plywood, noodle, and cloth kit" and you have a robot ready for inspection.
ID:	20757  Click image for larger version
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
  #47   Spotlight this post!
Unread 12-05-2016, 09:05
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
Originally Posted by MechEng83 View Post
A breakout board for the Talon SRX that contains the index signal pin.
A breakout board for the Talon SRX that plugs right into the motor controller, rather than requiring those really thin cables.
Not hardware, but the ability to set brake/coast in a Talon SRX with code.
Multiple sizes of Talon SRX data cable, currently the only size is 12" which can be difficult to work with.
  #48   Spotlight this post!
Unread 12-05-2016, 09:07
Joining the 900 Meme Team
FRC #0079
Uh, using CAN you can.
  #49   Spotlight this post!
Unread 12-05-2016, 09:21
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
+1
  #50   Spotlight this post!
Unread 12-05-2016, 09:28
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
http://www.andymark.com/product-p/am-2617.htm AndyMark sells a 6" version. I was also able to find 20cm version from random internet sources (search for 0.05" or 1.27mm 10 pin), but I agree, having multiple length options would be nice.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
  #51   Spotlight this post!
Unread 12-05-2016, 09:42
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
a CAN plug-in vision aiming module.
  #52   Spotlight this post!
Unread 12-05-2016, 09:43
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
That is very difficult for suppliers, it is almost a gamble, as they have to buy or fabricate parts in advance, and if they are not useful for a particular season then that is a huge burden on them. A way around it is to get certain suppliers like Andymark and Vex in the loop in terms of the season so they can plan ahead, but it is really not ideal at all.
What about the AndyMark tank treads? That must have been the best gamble they ever had for they only came out about a month prior to kickoff. I do feel that suppliers should be in the loop so they can prepare their inventory for the influx of purchasing specific parts.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
  #53   Spotlight this post!
Unread 12-05-2016, 09:50
Kellen Hill's Avatar
Kellen Hill Kellen Hill is online now
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Originally Posted by jwfoss View Post
-4"x1.5" and 4"x2" Aluminum Wheels with 1/2" Hex Broach
-Anti-backdrive stage for VersaPlanetary
-Disc Brake set up with 1/2" Hex or "Standard" Sprocket Hole Pattern
For the anti-backdrive stage, you could even add in a switch to the stage, similar to a ratchet wrench, to engage, disengage, or flip the direction of the anti-backdrive.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
  #54   Spotlight this post!
Unread 12-05-2016, 09:53
Billfred's Avatar
Billfred Billfred is online now
Three key distributors--AndyMark, VEX, and REV--were given a few high-level details about the game in September and October.
Originally Posted by Frank
They were given general information such as that the robots would be driving over obstacles, climbing, and throwing game objects. All distributors made their own decisions about stocking levels and what components they should stock. As an example, while we told distributors that robots would be climbing obstacles, we did not tell them what specific components we thought would be useful in addressing that challenge. Each made their own business decisions. In some individual cases distributors were given more detailed information out of necessity. For example, as AndyMark had agreed to make the game objects available to teams, they knew about, and stocked, boulders ahead of time. Specific details like this were on a 'need to know' basis, if they didn't need to know, they didn't get to know.
  #55   Spotlight this post!
Unread 12-05-2016, 09:54
ASD20's Avatar
AKA: Andrew
This year AndyMark and a few other suppliers were told some details about the game and that is why they came out with Rhino Treads.
  #56   Spotlight this post!
Unread 12-05-2016, 10:03
FRC #0079
[citation needed]
  #57   Spotlight this post!
Unread 12-05-2016, 10:08
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Originally Posted by Andrew Schreiber View Post
[citation needed]
Citation: http://www.firstinspires.org/robotic...g/distributors
It doesn't say that the Rhino drive was a direct result of finding out about the game, but it seems a perfect product for the game, so I'd imaging it is something similar.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
  #58   Spotlight this post!
Unread 12-05-2016, 10:09
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Rollers are a pain. It would be nice if there were a couple more COTS methods to transmit torque to a roller. The only one I know of is from Competition Robot Parts.
  #59   Spotlight this post!
Unread 12-05-2016, 10:12
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
A COTS 4 stage gearbox for a single CIM would be pretty handy for arms.
  #60   Spotlight this post!
Unread 12-05-2016, 10:15
mklinker's Avatar
mklinker mklinker is offline
Coach FRC4485
AKA: Mike Klinker
FRC #4485 (Tribe Tech Robotics)
mklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to behold
I would like to see a ratcheting gear and pawl. It would be nice if the ratcheting gear had a 1/2 inch hex broached bore.
Option B would be a ratcheting gear with the standard FIRST bolt circle to attach to a hub.
Mike Klinker Mentor, Tribe Tech Robotics FRC 4485
2016 Walker Warren District Semi-Finalist
2015 Indiana District Championship Semi-Finalist, Purdue District Quarter Finalist, Kokomo District Quarter Finalist, R2OC Finalist
2014 Boilermaker Regional Quarter Finalist
