Go to Post Way to steal my thunder, Billfred! :p - Koko Ed [more]
  #61   Spotlight this post!
Unread 05-12-2016, 10:18 AM
maxnz's Avatar
maxnz maxnz is online now
Can't wait for next season!
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Re: What COTS parts would you like to see?
A potentiometer that is designed to work with VEX ThunderHex shafts.
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
  #62   Spotlight this post!
Unread 05-12-2016, 10:25 AM
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
Originally Posted by s_forbes View Post
...spacer inserts for tubes. These let you do through-bolt connections that can be tightened without crushing the tube, so you actually have a strong bolted joint. For VexPro in particular, spacers like this that fit their Versaframe extrusion sizes could be very useful for some teams.
+1 million on this one.
In recent years, we usually end up 3D printing all of our anti-crush supports, or else making do with lots of little cut-to-length tube spacers. With the first option, we waste time redesigning and printing the custom support blocks every year; with the second option, we waste time fumbling with (and dropping, losing, and needing to cut replacements for) dozens of tiny round spacers during assembly and maintenance operations.
Standard anti-crush supports that fit inside the VersaFrame extrusions, on the other hand, should be fairly cost-effective if injection-molded en masse!
  #63   Spotlight this post!
Knufire Knufire is offline
You can do this pretty easy already. Just drill the center of the shaft out to 1/4", hacksaw a slit ~0.75" down the length of the shaft, and put a shaft collar over the slit. The shaft collar will now clamp the potentiometer shaft like a collet would.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #64   Spotlight this post!
Unread 05-12-2016, 10:31 AM
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
Yeah, but if it had the pwm cable pre-attached, like most VEX EDR electronics do, then it would be a lot easier to wire. That's mainly what I was getting at.
2. Wire the robot
7. Be active on CD
  #65   Spotlight this post!
Unread 05-12-2016, 10:39 AM
REVving up for a new season
FRC #2848 (All-sparks)
Originally Posted by MechEng83 View Post
An inside corner bracket for the 1" REV extrusion similar to the 15mm version: http://www.revrobotics.com/product/rev-41-1038/
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
  #66   Spotlight this post!
Chris is me's Avatar
AKA: Pinecone
Originally Posted by jwfoss View Post
-Anti-backdrive stage for VersaPlanetary
-Disc Brake set up with 1/2" Hex or "Standard" Sprocket Hole Pattern
Was just thinking about both of these.
An anti-backdrive VP stage would be awesome - that is basically the only feature I miss from the old DeWalt transmissions, and it can't be *that* hard to do, right?
I would really like 4140 pinion gears (at least 18T, 20T, 24T) for high load applications. Aluminum works sometimes, but sometimes you want steel.
  #67   Spotlight this post!
Unread 05-12-2016, 10:40 AM
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Originally Posted by ASD20 View Post
This year AndyMark and a few other suppliers were told some details about the game and that is why they came out with Rhino Treads.
Originally Posted by Bkeeneykid View Post
Citation: http://www.firstinspires.org/robotic...g/distributors
It doesn't say that the Rhino drive was a direct result of finding out about the game, but it seems a perfect product for the game, so I'd imaging it is something similar.
I would imagine they had already been designing the Rhino tread for some time previously, and being alerted that the new game would have "driving over obstacles" simply sped up the time frame for releasing it. A COTS tread system had always been something people wanted (for whatever reason ).
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
  #68   Spotlight this post!
Unread 05-12-2016, 11:03 AM
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
For those interested, this chain tool is still available in the wild.
http://www.davesmotors.com/DarkSoul-...Tool-3466.html
We used to sell it...it's a long story as to why we do not anymore.
This is hands down the best chain tool for #25 chain that exists....the main advantage is the inclusion of a re-press mandrel that allows you to eliminate master links.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
  #69   Spotlight this post!
Unread 05-12-2016, 11:23 AM
Michael Hill's Avatar
Will that work on the Vex #25 chain? It seems a bit thicker than other #25 chain.
  #70   Spotlight this post!
Unread 05-12-2016, 11:27 AM
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Yes it works with Vex #25 chain.
It is the best chain tool I've used.
1058 PVC Pirates 2016 - xxxx
  #71   Spotlight this post!
AKA: Pinecone
Yes. We used it this year on Vex chain - if anything the extra thickness makes it harder to drive the pin too far out, so it works better with Vex chain.
  #72   Spotlight this post!
Unread 05-12-2016, 11:35 AM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I would like to see a better solution for using LED's. Right now LED's paralyze my team with how many choices / setups there are, so usually there's a mediocre attempt at them but never a finished product.
- How do we connect power to the LED's?
- Which LED brand, model, and length do we use?
- Do we really have to care that each light is addressable, seriously?
- To control them do we use an offboard processor, use a Spike, or is there a better way?
Would love to have something simpler that doesn't depend on in-house custom circuitry or an arduino. Plug this 12" LED strip into this device, then plug this device into the PDB and into the RoboRIO using these connectors. Then use this sample code to get going with writing different colors/brightnesses or blinking lights to the LED's.
FWIW, introductory courses in embedded electronics in college were all about blinking LED's, and connection of those circuits to the corresponding code was way more straightforward than the FRC LED situation.
GitHub
  #73   Spotlight this post!
Unread 05-12-2016, 11:54 AM
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Aluminum HTD pulleys with more hearty outer walls. Almost all of our larger diameter pulleys had the wall ring pop off at some point during the season. The belts themselves very rarely slipped off as they were fairly well aligned, but I would love to have not had to deal with it over and over.
If they can't get away from the ring design of the walls, maybe make the walls a little larger so that you could tap and screw it back on after it pops off? It's doable right now with (I think) a #4 screw, but something larger would be nice to work with.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
  #74   Spotlight this post!
Unread 05-12-2016, 12:04 PM
JesseK's Avatar
FRC #1885 (ILITE)
You could tap the base aluminum pulley, close to the ring, and use a washer to retain the ring. This is similar to how many gearboxes retain bearings (AM Toughbox Nano, WCP DS gearboxes, and a few others I'm sure).
GitHub
  #75   Spotlight this post!
Unread 05-12-2016, 12:08 PM
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
VersaPlanetary "Inverter"- allow you to run a motor on the side of the planetary. Our team fobbed our own with a dual motor input and some shenanigans, but COTS would be nicer. The issue with planetaries' packaging is that they package long.
