Go to Post Any adult can open a door. Some can give direction. A few can give leadership. These are the true mentors. This is where true success comes from. - sanddrag [more]
Unread 12-05-2016, 03:18
ns3517's Avatar
ns3517 ns3517 is offline
FRC #0316 (Lunatecs)
ns3517 will become famous soon enough
Intake RPM
Hello I'm curious around what RPM different teams intakes were spinning and what motor teams were using on their intake. If you chose that speed for a specific reason what was that reason?
Unread 12-05-2016, 03:31
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Re: Intake RPM
A general rule of thumb is to run the intake such that the speed at the tip of the roller intake is 2x your robot's max speed.
I don't want to speak for most teams, but the motor selection comes down to making sure that you don't stall your motor out when intaking a ball. Consider the worst-case scenario where the ball gets jammed.
These two considerations can help guide you in figuring out a motor/gearing combination that you are comfortable with. But, if in doubt, go with the new 775Pros.
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 12-05-2016, 03:38
RoboChair's Avatar
AKA: Devin Castellucci
Re: Intake RPM
775 pro all the things
front intake was 1800 rpm about 11 FPS surface speed
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 12-05-2016, 07:32
414cnewq 414cnewq is offline
FRC #3844 (Kentucky Wildbots)
414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of
Re: Intake RPM
50 percent of our shooting speed, theoretically 65 ft/s, but I know its less.
Our intake wheels are the same as our shooting wheels (six inch wheels mounted to to mini-CIMS) with two outrigger wheels to avoid a tangent point. Heres a picture.
Unread 12-05-2016, 08:46
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Intake RPM
...snip...
This is true for "ball" intake systems, though more so for previous robots that drove a bit slower.
The reason for this is a rolling ball has zero surface velocity at the point of contact with the ground, and 2X its center rolling velocity at its upper surface. Thus the 2X multiplier so the ball rolls into the robot instead of the robot rolling over the ball (which can cause the robot to climb a ball).
As robots are getting faster and faster top speeds, this metric makes for higher and higher surface velocity of the rollers which in turn makes risk of stall much higher.
I think a more accurate target should be 2X the speed with which you expect the robot to be traveling when you acquire a ball. In 2014, this was possibly a very high ground speed. In 2016, due to sprint distances, the actual speed robots saw was quite a bit lower.
For non-ball objects, target should be at or near robot speed, but the likelihood of dealing with stall is much higher.
Chris is me's Avatar
AKA: Pinecone
Re: Intake RPM
Two keys to powering a good intake:
  1. Throw power at it
  2. Make it go fast
We ran a BAG motor at 9:1 on our 1.5" rollers. You can do the surface speed math. It was pretty good. A smidge faster and it would have been able to shoot into the low goal from the bottom of the batter, which is sometimes useful. If possible I would have just left it at 9:1 and put a 775pro on it.
We briefly tried a mini-CIM direct into it, but that was clearly ridiculous, not enough torque.
The 2x robot's max speed rule is also only valid if you are intaking the ball from one side. If you have top and bottom rollers (or left and right), you're pulling in the ball instead of rolling it, so 1x max speed is fine. And as robots gear themselves ridiculously fast, 2x max speed just might not be all that practical.
Unread 12-05-2016, 08:47
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Re: Intake RPM
1800 rpm with a 1" diameter intake roller so we had a surface speed of about 8 fps. We were originally worried about stalling out the intake and burning the motor so we didn't go for the 775pro, opting instead for a bag motor. As it turns out though, the stall torque of a bag is almost the same as a 775pro's optimal power output torque, so going 775pro is almost always the way to go. We switched to the 775pro for champs.
Edit: I failed at math: 8 fps, not 400 fps
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 12-05-2016, 08:51
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Re: Intake RPM
Originally Posted by jijiglobe View Post
1800 rpm with a 1" diameter intake roller so we had a surface speed of about 400 fps. We were originally worried about stalling out the intake and burning the motor so we didn't go for the 775pro, opting instead for a bag motor. As it turns out though, the stall torque of a bag is almost the same as a 775pro's optimal power output torque, so going 775pro is almost always the way to go. We switched to the 775pro for champs.
you may want to check your math. I get closer to 8 fps....
(1800 rpm = 30 rev/second, 1" DIA = 3.14159" circumference, this equals about 94 in/sec which is about 8 fps).
Unread 12-05-2016, 08:58
jijiglobe's Avatar
FRC #0694
Re: Intake RPM
I thought I was doing something wrong... minutes != seconds
RoboRio
Rob/oRio
oRio
Unread 12-05-2016, 09:28
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Re: Intake RPM
We used upper and lower Bag Motors on a 10:1 VP with a 1:1 9mm belt from gearbox to 2.375" Banebot wheels. Theoretical RPM on those wheels is about 1300rpm. Robot ground speed was max 15fps (though I don't think we were ever near full speed when intaking). The belts were fit slightly loosely on 3D printed pulleys to create a "slip-clutch" to prevent motor stalling. The plastic pulleys held up just fine all year, no broken teeth, and even took quite the beating from impacts of robots and walls. Never had a single issue with belts from ratcheting over the pulley teeth either. We've done this a few times for these very low load type of applications - I would NEVER do this setup on our drive (though I know as our wheel axles got bent over the course of the year, we did quite a bit of ratcheting on those belts...but again, no issues).
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 12-05-2016, 10:50
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Re: Intake RPM
We ran a 775 at a 7:1 ratio with a 1.75" roller. That's roughly 2600 rpm.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 12-05-2016, 11:11
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Intake RPM
One 775 pro at 9:1 on 2" diameter rollers. About 17ft/s. The rollers were 1/2" ID polyurethane pressed on to a steel round shaft with a 1/8" key in it. They acted like a clutch when a ball was captured instead of stalling the motor.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 12-05-2016, 12:39
cpiravi's Avatar
cpiravi cpiravi is offline
FRC #3476
cpiravi has a spectacular aura aboutcpiravi has a spectacular aura about
Re: Intake RPM
We started with two 550s, but then we switched to two 775 pros because they kept smoking halfway through a match.
Team 3476 Code Orange, Student 2013-2016
Unread 12-05-2016, 12:47
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: Intake RPM
We ran 2 775's through 3:1 gearboxes at 0.4 speed. That comes out to about 2400 RPM.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 12-05-2016, 13:22
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Re: Intake RPM
Maybe not 2x, but gearing a linear speed of an intake faster than the drive allows you to intake while the robot is moving in any direction. Just gearing faster than the drivetrain is a better rule of thumb.
NS3517,
I don't think you're asking the right question.
The RPM of any intake is not a good measurement, because the same RPM on different rollers provide for different performance.
The most important factor of the intake is the Linear Speed, as Adam described in the quoted post. The linear speed of an intake is independent of the roller diameter, and is a better way to measure intakes across other robots.
As for motors, the 775pro is bomb.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
