Go to Post I think this thread just won "ChiefDelphi is terrible Bingo". - Karthik [more]
Unread 12-05-2016, 09:49
Why_A_Username?'s Avatar
Why_A_Username? Why_A_Username? is offline
AKA: Jacob Pilch-Bisson
FRC #2910 (Jack-In-The-Bot)
Team Role: CAD
Rookie Year: 2015
Why_A_Username? has a spectacular aura aboutWhy_A_Username? has a spectacular aura about
Help with T-Shirt Cannon
Hey CD,
My team has been working on a couple of modules for our outreach robot. Another student and I requested to be in charge of the T-shirt cannon. At first we thought this was fine but now we're a little but stuck (He's in charge of CADD and i do Drive Train and PR). Niether of us has taken physics yet and so we arent entirely sure how to do the calculations for pressure required. We did them on our own, and got some results that didn't seem right, so we where wondering if CD could give us a hand. Below is the poster on which we wrote our answers:
Thanks CD!
"I don't remember how to make that! It came to me in a dream, and I forgot it in another!" -Professor Hubert Farnsworth
"The only difference between science fiction and science is time"
-Dean Kamen
Unread 12-05-2016, 10:05
Steven Smith Steven Smith is online now
FRC #3005 (RoboChargers)
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
Re: Help with T-Shirt Cannon
Why don't you think they look right? I can start explaining from there
2013 - 2017 - Mentor - Robochargers 3005
2014 - 2017 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Unread 12-05-2016, 10:14
ASD20's Avatar
ASD20 ASD20 is online now
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
I would not design the system around aiming for a specific distance, but rather just try to design a system that shoots as far as possible. It's cool to try to do the physics, but kinematics does not account for many real life inefficiencies, such as air resistance that are present especially when shooting something like a t-shirt.
In order to get a good shot, you will want to make sure you have as large a flow rate as possible in your solenoid. Some other important variables that I considered when designing a t-shirt cannon are air pressure, barrel length, and volume of air needed. I am sure other, more experienced people, may have slightly different lists. If designed well, you should easily be able to shoot 50 feet and if you need to lower the range, it is fairly easy to lower the air pressure.
Unread 12-05-2016, 10:19
Team Role: CAD
Rookie Year: 2015
Well, The PSI I have on the poster has Standard Pressure added, sonit was really only about 2 PSI after the calculation, which seemed low, also, the flow rate was only marginally greater than the actual barrel volume, so it seemed to me like it wouldn't actually push the shirt out the barrel at any real speed.
Our coach will not OK a cannon design unless it has a range of 50' or less due to safety concerns.
-Dean Kamen
Unread 12-05-2016, 10:28
ASD20's Avatar
AKA: Andrew
All you need to limit the range is to have a pressure regulator in the system, which you should have anyways. If you use one like the frc one, you just need to adjust the nob to lower the pressure, which will limit the range. You can even use this method to change your shot on demand based on location (If you are in a small room versus a football field, you will probably want a different shot power).
Unread 12-05-2016, 11:23
Team Role: CAD
Rookie Year: 2015
Thank's for the idea. I'll definatly present it. I still don't know if it will be accepted, but I'm going to push for it. That sounds a lot easier than our math homework way of doing it.
-Dean Kamen
Unread 12-05-2016, 13:52
Right or wrong (and it doesn't look "that wrong"), there is still a value to attempting to solve these problems using the math. Even if the error is 50%, it is still getting to within an order of magnitude of the right answer, so it has some value.
If your barrel was filled with 16 psi air, and you were able to flow air at a great enough rate to maintain 16psi throughout the full travel of the shirt down the barrel, despite it "sounding low", it is imparting a decent force on the shirt. That 16 psi is working against ~4 square inches so you have 60pounds of force on a reasonably low mass. Additionally, you are saying your barrel has a volume of 2.1L and your fill rate is ~35 actual L/s, so your shirt is travelling the length of the barrel (2.5 ft) in 0.06sec, for an average velocity of 41ft/sec or an exit velocity of 82 ft/sec assuming constant acceleration.
I say all this not because it's strictly right, but your math probably isn't that far off.
So back to reality, the issue is that 35 actual L/s (which at 16psi is ~73 standard L/sec or ~150 SCFM of air. That is a LOT of air, enough that to transmit it without extreme pressure drop. Even with a 1" line, if you start at 16psi, you are losing ~0.2psi per foot of travel. At 0.5", you are losing 6.6psi per foot! Couple that with the fact that fittings, valves, regulators, and other restrictions are often much greater than your piping.
So the tl;dr on how to make a pneumatic cannon is that you need to design for higher flow, and have a nice accumulator to hold that flow really close to your barrel to minimize pressure drop. A typical design is something like a 1" solenoid right on the barrel, with an accumulator tank of sufficient volume right at the barrel. You fill it to whatever PSI you want (set with a regulator), and then fire the solenoid to shoot the T-shirt. You can test it with your teacher to determine what pressure is "safe" on the accumulator and then handle it administratively by saying "never set the regulator higher", or adding something like a analog pressure switch and doing it in code, or adding a mechanical safety relief or even a burst disk, depending on how robust you need your safety to be.
Keep one other thing in mind though, even low pressures of air (10-20psi) can be dangerous in plastics that fail in a brittle manner (PVC) so you should aim to build as much out of more ductile metal as possible, and shield any plastic parts. I would encourage you to develop a design and come back to CD for input on ways to keep it safe.
Unread 12-05-2016, 14:21
KohKohPuffs KohKohPuffs is offline
The one with the punny last name
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Since a discussion on T-shirt cannon designs has been brought up, I thought I might ask this: as opposed to a pneumatic approach to the firing of the t-shirt, has anyone ever thought of using flywheels?
I had this idea an year ago, but people had concerns over shredding by the flywheels although I'm partially convinced that such a design might be better and perhaps more safer than these pneumatic t-shirt cannons that we usually see being made.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 12-05-2016, 14:31
Interesting thought, always worth trying out Maybe a team with a test rig for this year could alter the spacing and give it a whirl.
My gut says for most wheel/shirt combinations that there isn't enough compressibility/springback for it to work well and you might impact more energy shearing the layers of the T-shirt vs. each other versus propelling the mass. But... just intuition, and still would like to see someone try.
Another plus for many basic pneumatic cannon designs is being able to load by just shoving the shirt down the tube, versus having to work out a load from the back side, a way to advance the shirt into the wheels, etc.
I do think there is a potential for issues with pneumatic launchers, but having a reasonably safe design out there could probably benefit a number of teams... might add that to my offseason todo list...
Unread 13-05-2016, 09:51
Team Role: CAD
Rookie Year: 2015
You have some good ideas, I particularly like the burst disk safety idea, and it got me thinking about some upgrades to my taser-ignited propane powered potato cannon, but that's a story for another time.
The gist of what i got from your post is that basically flow rate is equal too, if not greater than PSI in importance, because it is hard to maintain a constant PSI. We want a fast-fireing solinoid with a wide flow in between the resovior and the barrel tube to minimize the pressure drop between the two. Our current design has multiple barrels so thst presents a challange for multiple resovior connections. Thanks for the great reaponse!
-Dean Kamen
Unread 13-05-2016, 10:11
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
A bit of experience from 2014. We had a pneumatic catapult to launch the giant ball that year. We initially used our in-house SMC Solenoids. About halfway through the season, we started having issues (some Teflon tape had gotten into the solenoids) and we started looking for alternatives. We also started to log the air pressure on both sides of the solenoid for debugging purposes and were very shocked by the pressure differential. We had up to a 30 PSI delta across the solenoids.
The key item with flow rate is that at some point increasing your PSI has zero effect on the performance of the system. There is only a finite amount of air a given solenoid can pass (as I understand it from the aerospace engineers, the air can travel no faster than the speed of sound through the solenoid, speed of sound at what pressure is TBD). For solenoids, we had very good experience with the ones from Automation Direct (low cost, HIGH flow). Related note, I also recommend using Single Solenoids (as opposed to Double Solenoids). If you do use Double Solenoids, ensure both solenoids are 'off' prior to firing. We found there was a noticeable performance difference with the SMCs when we went directly from Forward to Reverse on the solenoids vs. Forward-Off-Reverse (we also had a significant time we were at Off).
One final item is to watch your pneumatics connections orifice size. You're not limited to the FRC legal 1/8" NPT or the 0.16" tubing. The larger you go the higher flow rate you can have. The tubing diameter, length, orifice sizes and quantity will have an impact on your system. You can also parallel Solenoids for greater airflow. Again, you aren't limited by FRC rules here. Just ensure you maintain safety so you don't hurt yourself during development.
Unread 13-05-2016, 10:19
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
We are using a 2-1/2" copper tube. Roughly 2-1/2" ID. About 24" long. Insertion depth past a minimum doesn't seem to have a big impact on distance fired. 16 psi won't push the tee-shirt out of the tube. Our shoot pressure ranges from 30 to 60 psi for normal shots. Air storage pressure is 110-120 psi with a separate shooting accumulator that is fully discharged on every shot. We adjust the shooting accumulator pressure to control the shot distance. Cannons with 3" barrels will shoot with lower pressure. How tightly the tee shirt is wrapped will greatly affect distances.
A couple of factors hard to calculate would air drag on the tee shirt and force required to move the tee shirt in the barrel. (Barrel drag)
Unread 13-05-2016, 10:35
What you really care about is PSI at the point of delivery (base of the barrel). If the T-Shirt could magically travel down the barrel without flow, you would essentially try to pull a vacuum on the tube, as an extremely small volume of starting air expands to try to fill the tube. The more air you flow into the tube, the more pressure you will have throughout the travel of the T-Shirt, and the more total force imparted.
Flow and starting pressure are linked of course, such that a higher pressure can drive a higher flow through the same size solenoid/tubing, etc. However, the pressure loss is exponential as tubing and orifice sizes decrease, and you are ultimately limited by what is called "choked flow". Simply put, air can not travel faster than the speed of sound in the gas system, so if there is a tight enough restriction, increasing pressure further doesn't add more flow.
Therefore, your solenoid does need to be "fast firing" but also have a large flow orifice (specified as a Cv value, which is basically the total flow across a valve for a unit pressure drop... bigger is better for this). A typical FRC solenoid will not work well for this application.
Multiple barrels and multiple connections is not as much of a design challenge as a cost challenge, if you wanted to have a solenoid valve per barrel. You could also consider (if you really wanted to push the envelope) of a revolver style design with a single barrel and a t shirt magazine that advances through it. There you still just need a single solenoid, and the main challenge is getting a good seal between the barrel and magazine.
Feel free to keep asking questions. Gas system design was my day job for a number of years.
Unread 13-05-2016, 12:17
One Eyed Man
Originally Posted by FrankJ View Post
We are using a 2-1/2' copper tube. Roughly 2-1/2" ID. About 24" long. Insertion depth past a minimum doesn't seem to have a big impact on distance fired. 16 psi won't push the tee-shirt out of the tube. Our shoot pressure ranges from 30 to 60 psi for normal shots. Air storage pressure is 110-120 psi with a separate shooting accumulator that is fully discharged on every shot. We adjust the shooting accumulator pressure to control the shot distance. Cannons with 3" barrels will shoot with lower pressure. How tightly the tee shirt is wrapped will greatly affect distances.
Just checking, but is all your air storage at 120PSI or do you have any low pressure tanks? The regulator is a choke point.
Unread 13-05-2016, 12:57
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
We use a shooting accumulator. Essentially a low pressure tank. It is a 2" pipe 24" long. That feeds the barrel through a 1" high flow valve and a couple of inches of 1" pipe. The charge valve from the air storage tank is actually closed when shooting. It takes a couple of seconds to charge the shooting accumulator through the regulator and a FRC legal solenoid valve.
