Re: What COTS parts would you like to see?
So we built a prototype of a product about a year ago to do simple LED control called the "blinkin Board" The basic idea was to allow on a single board the ability to drive the WS281* LEDs or 12v RGB LEDs. The voltage buck 12 to 5 with 3 amps of supply is on board, so just give it 12 volts and it would work. The real beauty (in our minds) was the fact that you can control either kind of strip with a PWM input, we were able to sub-divide the standard PWM signal into tons of discrete signals and using a provided chart teams could make their LEDs do things with no hard programming required. There are a bunch of jumpers on the board so you can select things like your team colors & strip length. We got the prototype almost ready for production (needed a bit more DFM work and software) but we ran out of time as we needed to focus on other things (like the SPARK). We also were not sure how many teams would be interested in something like this to justify the effort to bring it to market. It is still something we can definitely make, we just need to figure out where on the priority list it falls compared to some of the other large initiatives REV is working on. ![]() Last edited by Greg Needel : 12-05-2016 at 15:31. |
I'd be all over this too. I sure hope your market research shows demand, I'd love to see it get built.
I think it was a little late last year when I voiced a hope for inverse mounted CIM gearboxes (like http://www.chiefdelphi.com/forums/sh...d.php?t=140713) as a COTS item; maybe this year the Wizards at WCP will bring one to market. I'd also love to see the Raw Box made more like Joey Milia's original version; my team would probably keep several sets of that box in stock, it seems like one of the better designs I've ever seen.
A system like this definitely makes LEDs less cumbersome. 558 would be very interested in this set up.
A bigger version of the versaplanetary.
#7
Some of these are (unmet) repeats from my 2015 wishlist:
I'll probably come up with more... |
#8
Hmm, I generally really like this one...
#9
I have mentioned this before but I would love a VP output stage with a female 1/2" hex coupler.
Also more small usable motors would be great. Stuff in the RS-550 size. Said this earlier but an electric solenoid and coupler for shifting with no pneumatics would be epic. |
#10
Vex and only sell so many variants of their products w/o losing money due to the increased difficulty of inventory forecasting. |
#14
Now making your own female hex coupler, not very hard. |
#15
The spline is a separate piece. The shaft and spline are combined with a dutch key. I almost did this last season: Press out the shaft and insert a new one and drill in a new hole for the dutch key.
