Go to Post I would suggest spending a few more hours digesting the manual before you finalize your designs. You seem to have missed a few key rules. - GaryVoshol [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 12-05-2016, 21:28
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Python Network Tables Raspberry Pi 2
I am looking for some in-site on the python network tables. I am using the example code found here. I try to run it and I get and error stating that I need to set my ipadress. I read up on the error here. Where would you put the IP adress and what would it be? It doesn't seem to be that well explain for newbies. Thanks for any help ahead of time.
Unread 12-05-2016, 21:42
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Re: Python Network Tables Raspberry Pi 2
In the Driver Station example you linked, the IP is set through sys.arg. For me, I just skip that and set the IP directly like this:
NetworkTable.setIPAddress("10.XX.XX.XX")#Your IP goes here
So the entire code would look like this if you were using the example(This is untested but is similar to what I used before):
import time
from networktables import NetworkTable
# To see messages from networktables, you must setup logging
import logging
logging.basicConfig(level=logging.DEBUG)
NetworkTable.setIPAddress("10.XX.XX.XX")#Change the address to your own
NetworkTable.setClientMode()
NetworkTable.initialize()
sd = NetworkTable.getTable("SmartDashboard")
i = 0
while True:
    try:
        print('robotTime:', sd.getNumber('robotTime'))
    except KeyError:
        print('robotTime: N/A')
    sd.putNumber('dsTime', i)
    time.sleep(1)
    i += 1
Just makes sure to change IP address and that should be a working example. Let me know if it still doesn't work!
#Python4Life
Unread 12-05-2016, 22:08
import time
import logging
i = 0
while True:
    try:
    except KeyError:
    time.sleep(1)
    i += 1
So if I am running this on a raspberry pi 2 I would put the ip adress of the roboRio? If so should I change the roboRio to a static IP address such as 10.xx.yy.?? --> xx.yy would be team name but what would the ?? be at the end?
Thanks for you help.
Unread 12-05-2016, 22:13
team-4480's Avatar
Debug? What's that?
FRC #4480
Yes, you would put the address of the roboRio. It has been a while since I used networktables so I don't quite remember, but if I recall correctly, you can use roborio-xxxx-frc.local where xxxx is obviously your team number. If that doesn't work, you can use the 10.xx.xx.?? where the ?? is where the Rio is located on your network. To find this out, connect to the WiFi network and type "roborio-xxxx-frc.local" into your browser(again your team number) and the webpage for the Rio will pop up. There, you will see the exact address of the Rio.
#Python4Life
Unread 12-05-2016, 22:31
On the trouble shooting link it states
Yes, I know it says setIPAddress... it will accept a hostname also. If you are team 1234, then the hostname would be ‘roborio-1234.local’. Make sure you have an mDNS client installed on the coprocessor (like avahi)
Do you know how avahi works?
Unread 12-05-2016, 22:42
team-4480's Avatar
Debug? What's that?
FRC #4480
I haven't ever used it since I have always used the driver station for vision(which is what I assume the Pi is for). It appears that avahi is available through "apt-get" which would pretty easy to install then. Have you tried the script without installing avahi? Does it not work?
#Python4Life
Unread 12-05-2016, 22:52
I haven't tried it yet. I'm just thinking ahead in case it doesn't work. Thanks again for you help I will let you know if it works tomorrow.
Unread 13-05-2016, 11:22
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
When using a coprocessor (at least this year), you're better off setting everything up with static IPs. There are issues connecting to the roborio when mDNS is used.
Unread 13-05-2016, 12:24
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Quite unsurprisingly.
Unread 13-05-2016, 12:52
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Yeah my team had a plethora of issues in districts than worked totally fine at MICMP and CMP after switching to static. mDNS just isn't as battle tested as static ip
Unread 13-05-2016, 13:49
I've heard about people having troubles with mDNS but I dont know what it is or how to change it? Can someone explain it to me?
Unread 13-05-2016, 17:55
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Assign a static IP (such as 10.te.am.2) for the roborio on the networking tab of its NI web dashboard.
Choose "static" in the dropdown and then enter the static IP you want.
Unread 13-05-2016, 18:10
Thank you! That helps a lot.
