Go to Post When all you're holding is a hammer, every problem looks like a nail. - artdutra04 [more]
  #46   Spotlight this post!
Unread 12-05-2016, 18:24
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
Re: Java vs Labview
Originally Posted by aeastet View Post
Are you still using the roboRIO to run these small robot? Do you make these available for other team to buy? Where would I get one if I did want to buy one?
No we do not use the roboRIO. We actually use a ChipKit wf32. It is basically a high power arduino with wifi. We do this to keep the price down allowing use to have a higher robot to student ratio. If you are interested in getting one you can get it from http://playingwithfusion.com/product...=65&catid=1009
if you have any question let me know or if you would like to see any other youtube video on programming Labview
2016 Tesla Division Finalist
2016 Central Illinois Regional Finalist
2015 Newton Division Finalist
2015 Newton Quality Award
  #47   Spotlight this post!
Unread 12-05-2016, 18:58
Landonh12's Avatar
Landonh12 Landonh12 is online now
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Re: Java vs Labview
Another thing about LabVIEW compared to Java or C++ is that it is able to help people who have a hard time understanding written languages. I know that when I first started programming, I couldn't really grasp the idea of a class or a function and how they interacted with parts of a program. LabVIEW helped me realize that a sub-vi is just like a function: there's inputs which feed into a block of code, which then in turn output a set of data. Seeing that visually really helped me grasp written languages a lot easier.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
  #48   Spotlight this post!
Unread 12-05-2016, 22:04
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Java vs Labview
Java byte code is platform independent. It can be reverse engineered programmatically into UML and other diagrams. There are tools for Eclipse and standalone that can do this.
http://www.class-visualizer.net/
  #49   Spotlight this post!
Unread 13-05-2016, 06:12
dmelcer9 dmelcer9 is offline
AKA: Daniel
FRC #0810 (Mechanical Bulls)
dmelcer9 is an unknown quantity at this point
Re: Java vs Labview
Forgot to mention, but new tools such as JShell/Kulla are really lowering the Java learning curve.
  #50   Spotlight this post!
Unread 13-05-2016, 22:17
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: Java vs Labview
How did you calculate this data? Just from this seasons record or a total record?
This is just from this season's records. I knew there were successful teams that used each but I was sort of interested see what came out.
