Go to Post Teamwork, dedication and friendship have a lot of play in all factors of life, including a robot contest. - tenthirtythree [more]
Unread 12-05-2016, 21:59
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: 360 Degree Video... What do you guys think?
Originally Posted by TheMilkman01 View Post
The practicality just isn't there right now, and may never be, but driving a robot with a VR headset for demos or even in free time sounds like a really fun idea. If it ever could be implemented, I'm sure it wouldn't be the primary driver or coach. But here's another idea: having a VR headset that an audience member can wear and experience a match from the perspective of the robot. That would be sick and definitely put spectating at a whole other level.)
Good luck convincing the GDC of that
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 12-05-2016, 22:22
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
It is too bad FIRST did not go with the suggestion to use low frequency RF for FMS and get out of the WiFi business. Then you could use whatever WiFi you could get your hands on.
I suspect you could get stereo video from the robot with 7Mbps at 800x600 if you reduce your color depth (think grayscale), deeply compress and can manage to avoid a migraine at low frame rate.
If you were clever you might put a coprocessor on the robot and join the frames such that you must send a synchronized pair either interspersed or bound at the short edge. I suspect interspersed would yield greater compression.
Unread 13-05-2016, 15:24
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Originally Posted by KPSch View Post
Wouldn't it be awesome for matches to be streamed or recorded in 360? Oh heck, even 180 degrees from a camera on the sidelines. You could watch matches with Google Cardboard or that Viewmaster thing.
Yes! This would be amazing. There's just so much going on in any given match. Imagine a camera placed just over the center of the field.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 13-05-2016, 15:29
techhelpbb's Avatar
I see a slight issue with that:
If this is a camera looking at a parabolic lens with unfolding software: directly under the camera is a blind spot.
If this is not such a setup (I can't see the links due to some software) then maybe that's not an issue.
Unread 13-05-2016, 15:53
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Website says 25 minutes long of continuous shooting. Not total storage. It has 8 GB of memory and – I quote from the website – a total video recording time of "(L) approx. 65 minutes, (M) approx. 175 minutes." I assume the L and M stand for Large and Medium, but that's just guesswork there. If your not satisfied with this model I'd suggest looking for other brands and options too, there's some good stuff out there – just gotta budget effectively
The m15 seems to only allow 5 minutes max. The S does have live streaming capability, so I guess you could record from there.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 13-05-2016, 15:56
Team Role: Student
Rookie Year: 2016
What if these had been on top of the pyramids in 2013? The tops of the castles and standards may have been good places for one this year...
In the video, you can see what's under the camera, right up to the top of the pole it's mounted on! The only thing you can't see is the camera itself.
