Go to Post Isn't that the connector used on the F.L.U.X. Capacitor? - Ed Sparks [more]
View Poll Results: What would your interest level be?
No Thanks! We are happy with our Arduino or DIY solutions! 1 7.69%
We would happily take the Eagle files! Open HW Rocks! 1 7.69%
Interested in blank PCBs! 1 7.69%
Interested in kits! 6 46.15%
Interested in fully assembled boards! 4 30.77%
Voters: 13. You may not vote on this poll
Unread 21-11-2015, 20:32
cbyrne's Avatar
cbyrne cbyrne is offline
FRC #3941 (Absolute Zero Electricity)
cbyrne is a jewel in the roughcbyrne is a jewel in the roughcbyrne is a jewel in the rough
Gauging Interest - Teensy 3.2 Breakout Board
Hello CD readers!
I am working on a design for a <3"x3" board to break out the Teensy 3.1/3.2 pins to individual or paired Molex SL latching connections, same as what Hansen sells as Latching Polarized connections. Similar to servo connections, where there are one or two signals, plus power and ground.)
Currently, the board is looking like it will have:
8 Digital I/O only lines,
12 Analog In or Digital I/O
SPI
CAN
2 or 3 Serial (notionally one RS232 and one TTL)
2 I2C
Trying to gauge interest among the community if this will be something they are looking for. Any requests, reply below. Plan is to release the board as Open Hardware, but because the connectors can get expensive, looking into bulk buys and selling kits.
Thanks for the input!
Unread 21-11-2015, 20:55
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Gauging Interest - Teensy 3.2 Breakout Board
Absolutely. We've used them before on robots and in other projects. Plus I don't think I've seen a breakout or "shield" for the Teensy before.
If anyone doesn't know what a "Teensy 3.2" is, it's basically an Arduino with way more processing power, I/O, small footprint (more like an Arduino pro mini), and low price. Plus you program it with the Arduino IDE and any sketches that run on the Arduino run on this.
Spark fun page: https://www.sparkfun.com/products/13736
Would really like to see an MXP board based on this too.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 21-11-2015, 20:58
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Can you post links to the connectors on mouser or digikey or similar? Thanks.
Unread 21-11-2015, 23:22
cbyrne's Avatar
PCB Header: 3 Pin; 4 Pin; 7 Pin
Female Wire Housing: 3 Pin; 4 Pin; 7 Pin
Female Wire Crimp Connector: Digikey
3 pin for single channel, 4 pin for I2C or paired channels (think encoders) and 7 pin for SPI. I love these connectors - shrouded from accidental contact, mechanically keyed, latching against vibration, rated up to 3A each (perfect for 22AWG 2A circuits).
Bonus: Use the same series for locking inline connectors:
Male Housing: 3 Pin; 4 Pin; 7 Pin
Male Wire Crimp Connector: Digikey
Unread 24-11-2015, 11:50
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
Very cool, 2 years ago I built a breakout board for the 3.1 for driving WS2811 strips: http://hackcasual.io/blingboard/
Unread 28-11-2015, 12:38
cbyrne's Avatar
Ok, Renders from OSH Park. Seeking comments on layout.
Top:
Bottom:
Eagle Files:
http://www.afterdarklabs.com/wp-cont...y32Breakout.7z
All the connectors on the sides are the Molex connectors discussed above. Except the ones on the wider spacing at the top - they are standard Weidmuller wire connectors.
Board measures under 3" on a side, mounting holes are on a 2.5" center spacing. Makes the Teensy a little less teeny
Power is select-able:
  • Teensy powers the board through USB power and onboard regulator. (Requires no SMDs)
  • Teensy 250mA LDO receives power from 5V plugged into board. (requires a few SMD for reverse voltage and current protection.)
  • Board gets 5V power from robot, runs through the breakout board's 1A 3.3V LDO regulator. (requires all the SMD components - 0805 or larger for easy soldering.)
In addition, there are four power selection banks for the IO, to allow 3.3V or 5V devices to be plugged in.
Unread 17-04-2016, 10:35
cbyrne's Avatar
Just in case anyone cares - do not use the boards as they are. We tried to use one this season for some led strips, and the outputs at the board edge were not correct.
Being a CS major and not a CE or EE, I probably made some mistake. Trying to look into the design and errors now. (I have made other boards successfully, but this was the most ambitious to date.)
Unread 22-04-2016, 11:08
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
I am a CE/EE. Drop me a message if you want a second set of eyes for schematic and board review.
Unread 11-05-2016, 14:03
Ringo5tarr's Avatar
Ringo5tarr Ringo5tarr is offline
AKA: Lake Hall
FRC #1764 (Liberty Robotics)
Team Role: Electrical
Rookie Year: 2015
Ringo5tarr will become famous soon enoughRingo5tarr will become famous soon enough
Quick question-
What do you use a Teensy in? Like, this isn't a "Gauging interest" question, I would really like to know what other teams are doing with this sort of thing (since my team really isn't using it at all)
Unread 11-05-2016, 14:16
BenjaminWard BenjaminWard is offline
Programming/Controls
FRC #0612 (Chantilly Robotics)
BenjaminWard is an unknown quantity at this point
Are these available at this point? I've been looking into solutions like the rioDuino and this and this seems like a much better solution due to the advantages of the Teensy over the Arduino Uno.
Unread 11-05-2016, 16:43
I've programmed a Teensy for 3 things. One was as an example for my son to modify and extend for a senior design project (a home monitoring system). The second was a USB HID for arbitrary button inputs, with the beginnings of support for a rotary-encoder-based control knob. Finally, with an audio output peripheral as a museum exhibit controller that waits for a button to be pressed then plays a message and enables a motor to spin a turntable.
I also planned a programmable thermostat, but I could never get the built-in temperature sensor to give me reasonable data, and I wasn't motivated enough to connect an external sensor.
Unread 13-05-2016, 07:12
cbyrne's Avatar
Appreciate the interest, but the breakout board is not ready yet. When we tried using it during the season, the outputs we tried where barely getting above ground. (read: major electrical error somewhere)
As I get a chance I will work over the summer on this.
Unread 29-05-2016, 18:43
cbyrne's Avatar
Quick Status Update:
Just redid the entire board in 4 layers. Previous 2 layer board had a lot of vias, and I think they were harming the signals. Also removed the ground plane that meandered everywhere, as I suspect that was causing a lot of coupling error.
*Fingers crossed* Will let everyone know how it goes!
