Go to Post Yes, a big part of FIRST is learning from others. But a just as important part of FIRST is learning from discovery. - [more]
Unread 13-05-2016, 14:35
Re: Jaci's Annual FRC Datadump 2016
If you export the database tables, the "sqlite_sequence" table lists the number of records in each table:
event_types			7
match_levels			5
defenses			9
districts			8
events				139
alliances			1088
alliance_picks			3336
matches				13302
match_defenses			133020
match_teams			79812
match_scores			26604
awards				3251
stats				6194
rankings			6194
district_teams			1180
district_rankings		1179
district_event_points		2789
Unread 13-05-2016, 14:41
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
For all 3-alliance teams that actually played a match:
6138+6137+6208 = 18483 (blue)
11+56+41 = 108 (red)
Here is the SQL that gives the same answer:
sqlite> select a.team, b.team, c.team, max(a.team+b.team+c.team) from match_teams a join match_teams b on a.match=b.match join match_teams c on b.match = c.match where a.team <> b.team and a.team <> c.team and b.team <> c.team and a.alliance_color = b.alliance_color and b.alliance_color = c.alliance_color ;
6138|6137|6208|18483
sqlite> select a.team, b.team, c.team, min(a.team+b.team+c.team) from match_teams a join match_teams b on a.match=b.match join match_teams c on b.match = c.match where a.team <> b.team and a.team <> c.team and b.team <> c.team and a.alliance_color = b.alliance_color and b.alliance_color = c.alliance_color ;
41|11|56|108
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Last edited by jvriezen : 13-05-2016 at 16:43. Reason: Corrected to simply show SQL.
Unread 13-05-2016, 14:59
Originally Posted by Whatever View Post
I am not an SQL expert so I was hoping someone could help me out.
Some trivia questions I was curious in:
3. Alliance with the narrowest range of team numbers;
4. Alliance with the widest range of team numbers;
Widest range:
sqlite> select a.team, b.team, c.team, max(a.team - c.team) from match_teams a join match_teams b on a.match=b.match and a.team > b.team join match_teams c on b.match = c.match and b.team > c.team where a.alliance_color = b.alliance_color and b.alliance_color = c.alliance_color ;
6231|5536|11|6220
Narrowest:
sqlite> select a.team, b.team, c.team, min(a.team - c.team) from match_teams a join match_teams b on a.match=b.match and a.team > b.team join match_teams c on b.match = c.match and b.team > c.team where a.alliance_color = b.alliance_color and b.alliance_color = c.alliance_color ;
177|176|175|2
John Vriezen
Unread 13-05-2016, 15:04
Whatever Whatever is offline
FRC #2502
Whatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond reputeWhatever has a reputation beyond repute
Thank you
Unread 13-05-2016, 15:05
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I haven't done SQL in decades. I just cobbled up an AWK script to read the match_teams table.
Yay AWK, and once again showing there is more than one way to parse the data. I'm going to guess that Ether's was a little faster, since the data only will get a single read, the other method using SQL has quite a few joins.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-05-2016, 15:08
440 milliseconds on my 10-year-old Pentium D desktop running 32 bit XP.
Unread 13-05-2016, 15:23
antman antman is offline
FRC #3238
Rookie Year: 2016
antman is an unknown quantity at this point
41|11|56|108
I think this "max" was supposed to be a "min".
Unread 13-05-2016, 15:27
Fixed.
John Vriezen
Unread 13-05-2016, 15:28
markmcgary's Avatar
markmcgary markmcgary is online now
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
(ac=="red") && ($3=="red"){red+=$4; next}
(ac=="blue") && ($3=="blue"){blue+=$4; next}
(ac=="red") && ($3!="red"){
	if(red>max){max=red; idmax=$1}
	if(red<min){min=red; idmin=$1}
	ac="blue"; blue=$4; next}
(ac=="blue") && ($3!="blue"){
	if(blue>max){max=blue; idmax=$1}
	if(blue<min){min=blue; idmin=$1}
	ac="red"; red=$4; next}
I had to do a little AWK research. If I read this correctly, your idmax and idmin will point to the record in match_teams that immediately follows the max/min alliances?
It's amazing how many tools there are to accomplish a given task. Always something new to learn.
Unread 13-05-2016, 15:39
Yes. I could have subtracted 1, but this is not production code
I started using AWK a lot back in '96 when my main workstation was a DEC VAX/VMS and I had to wrangle large text datasets in various wacky formats. It was a lifesaver.
Unread 13-05-2016, 15:48
FRC #3238
Rookie Year: 2016
I think there is a problem with jvriezen's SQL to get the max sum of team numbers on an alliance. I can't find a match where the 3 teams 6204|6191|6212 are on the same alliance. Here is my approach to answering this question:
select m.match, m.alliance_color, sum(m.team) as team_number_total from match_teams m group by m.match, m.alliance_color order by sum(m.team) desc
It gives a descending order list with the winner being match 5986, blue alliance, team total 18483 (which agrees with Ether's answer).
Unread 13-05-2016, 15:55
I think there is a problem with both jvriezen's SQL to get the max sum of team numbers on an alliance and I guess Ether's awk method too (can't speak to that, haven't used awk), since they are giving the same answer...
team total 18483...the 3 teams on the blue side were 6137, 6138, and 6208.
Go look again at my post. That's the answer I gave.
Unread 13-05-2016, 15:57
FRC #3238
Rookie Year: 2016
Sorry, you're right, I was going by what jvriezen had said but his/her answer wasn't the same as yours. I'll edit my earlier post.
Unread 13-05-2016, 16:05
His original SQL code had an error; he was pulling the top 3 team numbers from match 445 without regard to alliance:
2662,444,blue,6083
2663,444,blue,4739
2664,444,blue,5331
2665,445,red,5876
2666,445,red,4729
2667,445,red,6191
2668,445,blue,6212
2669,445,blue,3132
2670,445,blue,6204
2671,446,red,6018
2672,446,red,4788
2673,446,red,4774
...he then corrected the SQL code but forgot to update the answer
Unread 13-05-2016, 16:33
FRC #3238
Rookie Year: 2016
Question for Ether or anyone else interested: is there a simple way using awk or other tools to get information about streaks from relational data like this? I've always resorted to writing a program (VB, T-SQL, java etc) because the SQL gets too ugly. For example: longest winning streak for each team (crossing events). It would be hard to do with this data currently because the event dates are not included but easy enough to add event_date field to the events table. To simplify my question, assuming id in the matches table was in chronological order for each team, how would you approach getting each team's longest winning streak?
