#16
Re: 360 Degree Video... What do you guys think?
It is too bad FIRST did not go with the suggestion to use low frequency RF for FMS and get out of the WiFi business. Then you could use whatever WiFi you could get your hands on.
I suspect you could get stereo video from the robot with 7Mbps at 800x600 if you reduce your color depth (think grayscale), deeply compress and can manage to avoid a migraine at low frame rate. If you were clever you might put a coprocessor on the robot and join the frames such that you must send a synchronized pair either interspersed or bound at the short edge. I suspect interspersed would yield greater compression. Last edited by techhelpbb : 12-05-2016 at 22:26. |
#18
Yes! This would be amazing. There's just so much going on in any given match. Imagine a camera placed just over the center of the field.
#19
If this is a camera looking at a parabolic lens with unfolding software: directly under the camera is a blind spot. If this is not such a setup (I can't see the links due to some software) then maybe that's not an issue. |
#20
In the video, you can see what's under the camera, right up to the top of the pole it's mounted on! The only thing you can't see is the camera itself. |
