Go to Post I have always liked to see people get recognized for what they do, not people doing something to get recognized. - sanddrag [more]
Unread 05-14-2016, 11:59 AM
stavinski's Avatar
stavinski stavinski is offline
FRC #2231 (Onyx Tronix)
Team Role: Electrical
stavinski is an unknown quantity at this point
Tips for new 'Head of Electronics'
Hi ,
I just got chosen to be head of electronics for this year.
i would like to hear if you have any tips for me about electronics and also about how to manage my team?
Thank you!
Stav
2011 - FLL student
2012- Present - FLL Mentor
2016 - FLL nantional 4th place & participated in the Philippines Islands Invitational
2016 - FRC student
2017 - Head of Electronics
Unread 05-14-2016, 12:03 PM
414cnewq 414cnewq is offline
FRC #3844 (Kentucky Wildbots)
414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of
Re: Tips for new 'Head of Electronics'
Keep your wiring clean! The last thing you want the robot inspector to see is a rat's nest in your robot.
Unread 05-14-2016, 12:27 PM
J_B_Wood's Avatar
J_B_Wood J_B_Wood is offline
Joey Wood
AKA: Joey Wood
FRC #1389 (The Body Electric)
Team Role: CAD
J_B_Wood is an unknown quantity at this point
On a similar note, does anyone have tips for CADing electronic systems? Could be 2D or 3D.
Unread 05-14-2016, 01:35 PM
PMotor's Avatar
PMotor PMotor is offline
AKA: Piotr Milewski
FRC #0694 (StuyPulse)
Rookie Year: 2015
PMotor is an unknown quantity at this point
I did plenty of electronics this year on my team and I have a few pointers that I could give:
A. Don't lose anything.
This year I managed to misplace both the PDP and the roboRio. Make sure you have shelves where you can store everything and you keep your workspace neat and organized.
B. Try to keep the electronics as far away from any parts that can move.
The last thing you want to hear is that your encoder stopped working because the wire was dangling out of the bot. I suggest using zip ties, zip tie holders (http://www.amazon.com/Startech-HC102.../dp/B00008VFBE ), and a lexan board with 1/4 in. holes cut into it so u can put a wire against the lexan plate and put a zip tie through the holes and around the wire to keep it secure and keep your electronics in one place.
C. Get an electronics tool box
Having all your necessary tools as well as things you know could break in one toolbox definately saves you time in the pit and build season from not knowing where you placed something. Just keep it with you at all times.
D. Check all your connections pre-match
After every match your bot's wire connections may have been loosened. You should stay in the pit and check all your connections before the next match and run a systems check to see if everything is still working. You could also check the mechanical connections such as checking for loose bolts (shouldn't be an issue if you used lock nuts but your never know).
As for CADing the electronics, it is definately possible as there are pre-CADed parts that you can download with a bit of searching. I definately recommend CADing the electronics before attempting to randomly put them on because the other engineers need to know before hand if you will need an extra electronics board machined out.
Unread 05-14-2016, 02:02 PM
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Fpr 3D, download the minimum competitive concept from WCP and then go into the design and save the individual modules and distribution boards. Create an electronics board or whatever you use to house your electronics by using bodies and then insert the modules onto the board. I use fusion 360 and it has a "Pipe" body that you can use for wire. Just make sure you color the positive and negative wires. For 2D, you can use Express CSP and use lines to direct your wires.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 05-14-2016, 02:20 PM
Michael Hill's Avatar
Michael Hill Michael Hill is online now
Make sure you work with your mechanical design team to ensure good placement of electronic components. You may have to be assertive with them that your roborio or pdp shouldn't be buried and inaccessible, but be prepared to be overruled.
As for doing a schematic...yeah, you can, but in general, it will change very little between this year and next year. It may be better to study the schematic given by FIRST and make sure you understand it. You don't have to wait until build season to learn how everything connects together and operates. During the season, your time may be better spent helping to get prototypes operating with motors with a motor controller (you're kidding yourself if you think hooking a motor up to a battery is going to represent a real controlled system). Once prototypes are hooked up, work with the design people to work on component placement, then after you get stuff being built up, go ahead and lead the effort on wiring.
Think of things that would help you out during a competition. When you're trying to debug something, it's much better to have labeled wires than to try to trace a wire back to the source. Additionally, a lot of people may forget about it, but make sure your batteries are being taken care of. That means not overusing one battery over another. The goal is consistency. If you continually use and abuse one battery, eventually, your robot will perform differently with that battery than another battery (which can lead to unexpected voltage drops when loaded and can result in slow shooter speeds, stalled motors, etc.).
Unread 05-14-2016, 02:22 PM
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Tug test all your crimps. Make sure the red and yellow fuses in the PDB are fully seated. Make sure the electronics are covered when someone is filing or cutting metal in the robot -- swarf is the enemy.
Unread 05-14-2016, 04:25 PM
Spillertb Spillertb is offline
FRC #5752
Spillertb is an unknown quantity at this point
- Don't make a rats nest of wires like I did
- Make sure that the mechanical team secures the battery very well so that it won't break the tiptoes holding it in allowing it to knock out half the pwm wires therefor disabling half of your drivetrain like I did
- I used some tape the ppm wires to the roboRio because the are super important and they tend to wiggle out of their place, but there is probably a way better way to secure them
- Make sure the robot inspector doesn't drop a battery on the Voltage Regulator Module knocking out the radio power wires disabling you for an entire match
- Use lock tight on any talon SR screw because they will come loose.
- if you don't need a CAN bus then make sure you connect the roborio to the PDP with some yellow green twisted wire, not red and black like I did, (they did not like that)
- Have the team one of those good pair of wire strippers were it automatically does the right size, those things are cool
- Get a good set of screw drivers, I used some of my own personal iFix-it tools
- Learn to solder, I learned the hard way
- Lean the basics of programming just so you kinda have an understanding of how it works, ex: if you should use brake or coast depending on the programming (I was also the lead programmer so I did all of the electronics to my liking)
- You and at least one other person check over the main important wiring before each competition, and at least check to make sure all the correct lights are on before each match
- Get a navX-MXP, they're super cool
- When using the navX-MXP also connect it to a USB A port for a second source of power to protect from brownouts
It should work...
Unread 05-14-2016, 04:34 PM
Speaking of inspection, ALL your parts should be accessible for inspection. You never know when some inspector will ask to see that one thing you buried under everything else... and then you need to get it out!
Unread 05-14-2016, 04:45 PM
FRC #5752
Actually everything was perfectly accessible, its just that our battery wasn't that secure on the top which he tested by yanking it out and dropping it very fast, still out fault though, we didn't check the wires before our first match due to time restraints.
It should work...
Unread 05-14-2016, 05:35 PM
AustinNordman's Avatar
AustinNordman AustinNordman is offline
FRC #3476 (Code Orange)
AustinNordman has a spectacular aura aboutAustinNordman has a spectacular aura aboutAustinNordman has a spectacular aura about
Communicate with the design team and demand enough room for well-organized electronics. The lack of electronics space on our 2013 robot is still an in-joke on my team.
Code Orange 3476 Alumnus
My comments do NOT necessarily reflect the views of my team.
Unread 05-14-2016, 05:45 PM
On one of the teams I've been on, there was a space joke that went something like this...
"But [electrical mentor], we gave you three times as much space as last year!"
"Three times zero is still zero."
"Last year", in this case, was about a foot high, standard footprint at the time, and had cutouts on both ends and a hefty turret in the center. The robot under discussion had to go into the sizing box at an angle, and didn't take up the entire floor, but because it was taller, the team was able to use a two-to-three deck layout.
Unread 05-14-2016, 05:56 PM
Holo3453 Holo3453 is offline
Drive Coach, Electrical Director
FRC #3453 (DEM BOTS)
Rookie Year: 2015
Holo3453 is an unknown quantity at this point
  1. Keep wiring clean and easily accessible
  2. If your are coding too. Keep code nice and organized
  3. Stay updated on Firmware updates and rule changes
  4. Use proper gauge wire, it says which one to use in the manual for the control system
Electronics Head is a lot of fun. I direct electronics on my team. Without electronics the robot is just a pile of metal, you bring it to life.
BaB Drive Team Operator
Electrical Director
Drive Coach 2016
Unread 05-14-2016, 06:20 PM
ATannahill ATannahill is offline
AKA: Alex Tannahill
This is coming from a former electrical lead and CSA.
1. Read the robot rules within three days of kickoff (don't post question to CD unless you have read all pertinent rules). Read to understand. After each rule think about what the ramification of the rule is and why the GDC included it.
2. Read any source you can find for the hardware you are using. Read the screensteps, manuals for the electronics, including the batteries.
3. Read the team updates and Q&A. This takes less than 15 minutes twice a week, it is worthwhile to make sure you understand the rules and the changes. Again, read to understand.
4. Keep everything organized. I think the thread has hit this enough.
5. Do an inspection check at the end of the season. Go through the inspection checklist (posted mid to late build season), preferably with someone else. Make sure to pay attention to the power routes for the radio, RoboRIO and PCM (if you are using it).
6. Check with your mentors/other team leaders to make sure the electrical system is properly represented on the BOM/CAW. Make sure to check the rules (and Q&A) about if items from the kit need to be listed.
7. Make sure all connections are secure. Push down on the red and yellow fuse in the PDP (I have pushed them until I had an imprint of them on my finger and the lexan the board was mounted on was bending and still not had them in all the way).
Always remember that you are working as part of a team. You cannot succeed unless the rest of the team does as well. It can be helpful for you to nudge other sections of the team and remind them of things they may not have noticed or may have forgotten. Commons items include creating the CAW, updating firmware, changes that were made in team updates and reviewing the inspection check list.
- Arizona North
Unread 05-14-2016, 09:07 PM
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumni
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
This. Communication is the biggest piece of advice from me. The design team will change the room given for electronics on the robot frequently during build season, so communicate with them and adjust/keep up on those changes. Don't make changes to the electronic system or start working on it without the approval or agreement of the design team otherwise your work will be wasted.
While we are all in a hurry near the end of build season, take your time while wiring... it pays off when your team doesn't encounter shorts, bad crimps, etc. that hinder your robot performance later on.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
