Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Old 05-16-2016, 01:36 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: A(nother) Sad Day For FIRST
Originally Posted by efoote868 View Post
As a side bar, someone has just negative repped me for "You can not make up reasons to give neg rep". I didn't rep the OP, but the irony is strong with this one.
My apologies. I did not mean to imply that any individual specifically gave the negative rep; I have no way of knowing who did it, but based on the red dot, it was obviously done. I have not given anyone negative rep for this thread.
Addendum:
Originally Posted by Kit Gerhart View Post
I wasn't on the field, but reliable sources said that using the batterie(s) for ballast was OK'd be the inspectors before the start of the quarter finals. Then, there was a change of mind, and a call to FIRST HQ.
Didn't they have a manual handy?
Originally Posted by 2016 Game Manual
R32 No batteries other than those allowed per R31 are allowed on the ROBOT, whether or not they are being used to supply power.
Originally Posted by blue box
This means teams may not use additional batteries as extra weight on their ROBOTS, for example.
