Go to Post After all, life is what you do outside of FIRST. No wonder it's so short. - Vashts6583 [more]
Unread 16-05-2016, 15:14
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Weird Gearbox Sound
We were at an outreach event this past Saturday and our robot started acting weird. Here is a video: https://drive.google.com/open?id=0By...3lnRkZwN0FFaXM
Just some notes:
  • It was around 35 degrees Fahrenheit that morning
  • The robot was out for about 2 hours and driven on and off for a total of about 10 minutes
  • The weather was cold enough that the DJ's CD players needed to be warmed every 15 minutes to keep them working
  • The robot started acting weird after about 1.5 hours in
I can give more details as needed.
Thanks!
Team 2855
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 16-05-2016, 15:19
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Re: Weird Gearbox Sound
I bet it's a dead battery.
When it stuttered and the orange RSL light flashed (not the normal flash, flashing with the stuttering motors), that led me to think it's the battery.
You should be able to check the driverstation logs if you don't have the robot right now.
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Was there any condensation forming from the cold? Could the grease in the gearbox have frozen? I had a similar problem with a gearbox on an R/C truck. Either the gear or the motor output shaft had become loose(maybe both, can't remember) and the gear wasn't making constant contact with the motor. There was some dust where the gear had worn. What gearbox and motors are you using? What are the gears made of? Any plastic moving parts?
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 16-05-2016, 15:43
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
I just checked the battery and it tested at 39%. So that could be part of the problem. We actually never replaced it with our backup the whole time.
As for the gearbox sound, they were taken around 5 seconds apart, one side, then the other. The robot hadn't been driven for about 45 minutes prior to that clip. So the grease freezing could be the source of the sound, but only one side sounded like that.
The gearbox is a Toughbox Mini. No plastic parts (other than the casing). We currently have the robot bagged for the MN State tournament, but we have a pep fest on Thursday where we will be able to drive it again.
2. Wire the robot
7. Be active on CD
Unread 16-05-2016, 15:56
Team Role: Student
Rookie Year: 2016
Was the robot driven on or near anything that could have damaged the gears, such as sand? Did the robot take a drop or any sort of impact? Could anything have happened when it wasn't in use for 45 minutes? It sounds a bit like something rattling inside of the box, maybe a piece of plastic broke off and fell inside the box somewhere?
Unread 16-05-2016, 16:02
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
No sand was present, the floor was swept prior to us unbagging the robot. There was no dropping of the robot. I don't believe anything could have happened in the 45 minutes (other than it getting colder due to the weather).
2. Wire the robot
7. Be active on CD
Unread 16-05-2016, 16:08
AKA: CAAAAAD
39%, at what load?
As batteries age, they may appear to still be good (have a high voltage) but under high load they drop voltage very quickly.
If you're using the CTRE Battery Beak, use the % or voltage at whatever the highest load is (18A?). That should give you a better idea of what it will actually run at during driving.
Unread 16-05-2016, 16:17
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
39%, at what load?
I'll check the battery again as soon as I can, probably in 30 minutes. The battery tested at 95% that morning before we started, if that helps at all.
2. Wire the robot
7. Be active on CD
Unread 16-05-2016, 16:25
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
39%, at what load?
The battery beak says 11.872@18Amps with an internal resistance of .02 ohms.
2. Wire the robot
7. Be active on CD
Unread 16-05-2016, 16:26
Team Role: Student
Rookie Year: 2016
OK, post another update when you unbag it again. (You have to bag it for some offseasons?) I think the temperature probably had something to do with it, especially since it was affecting CD players, though I've never heard of them being affected by temps just above freezing.
39%, at what load?
True. I've had this experience with nicad cordless tool batteries. They appear to take a full charge(measure at full voltage), and may even hold their charge for a while, but as soon as they're used to drive a motor...almost instantly unusably weak.
Unread 16-05-2016, 16:30
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
If you'd like, I'd be happy to stop by after work sometime this week - I know you have very little time to get it fixed before States, only 6 hours of robot access outside of the bag!
My first guess is a dead battery, and we can look through your driver station logs pretty quickly without unbagging the robot to see if that was the case.
My second guess would be some sort of mechanical interference or damage, something that would require the robot outside of the bag and running to figure out, eating up work time!
Let me known in a PM if you want me to swing by after 5 one of these days, I'm available all week (except for Friday, when I'll see you guys at load-in!).
Edit for those curious: the Minnesota State High School League State Tournament is held every may, a few weeks after champs, and is a bag and tag event, following the district bag and tag rules of 6 hours of robot access leading up to the event. This is done to keep the playing field level for the event, as someone last competing in week 1 would otherwise have significantly more time than someone competing at Champs would. It's not perfect, but the best we can do!
2016: Lake Superior WFFA
Unread 16-05-2016, 16:33
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
We have the pepfest on Thursday (2:15) if you want to come by then. We'll have it unbagged then. Thanks for the offer!
2. Wire the robot
7. Be active on CD
Unread 17-05-2016, 08:01
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
As someone who has seen more matches than most (close up, on the field) I would check your pulleys and belts. It sounds, and looks, more like the belts were slipping than a gearbox gear broke. While I don't think the cold would have had that much of an effect, with the intermittent driving, there could have been some issues with heating and cooling of parts unevenly.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 17-05-2016, 08:18
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
We have had the belts slipping a few times this season, and this wasn't that. That was what I checked for first when it started acting weird.
2. Wire the robot
7. Be active on CD
Unread 19-05-2016, 08:53
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
So, we had a little parade through the school this morning where we ran the robot, and the robot seemed fine. The stuttered movement never happened, so we think that that was due to the low battery.
As for the gearbox, it still had the weird sound like there was sand or something in the gearbox. The other gearbox sounded similar this morning. It ran fine, but we don't know what the sound is from.
2. Wire the robot
7. Be active on CD
