Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 17-05-2016, 10:07
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Re: what was the best shooting mechanism for 2016?
Originally Posted by Chris is me View Post
All other things equal (specifically, tip speed / torque of the flywheel, and energy transfer between the wheel and the ball), a hooded shooter will throw a ball half as fast as a double wheel shooter.
And this is why 775Pros are a godsend.
Crazy power output? check
Fast as heck so I don't have to gear up? check
I would also argue that the main reason that the two wheeled shooter is faster is because it has twice as many motors. If you really need the extra power Vex has you covered
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
