Go to Post Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk. - Andy A. [more]
Unread 17-05-2016, 14:50
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Connecting DS at home with FMS programmed radio
Helpless coach here trying to get the robot up and running for a demo tomorrow and none of our programmers are available to help me. We've not re-programmed our radio since our last competition (so it's still looking for FMS I guess) and I'm not sure if I can connect to our DS laptop wireless or if the radio needs to be reprogrammed. So far I'm not having any luck connecting to the robot.
Unread 17-05-2016, 14:52
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Connecting DS at home with FMS programmed radio
Your radio needs reprogrammed. There is a provided tool to do this.
Unread 17-05-2016, 15:03
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Check out this tutorial:
https://wpilib.screenstepslive.com/s...o-for-home-use
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 17-05-2016, 15:05
pribusin's Avatar
Uber Alien
AKA: Mike 1
I was afraid of that. Thanks.
Unread 17-05-2016, 15:47
We've not re-programmed our radio since our last competition (so it's still looking for FMS I guess)...
No, it's looking for a wireless access point with your team number as the name (SSID) and with a specific WPA key as the password. Since you have no way of knowing what that password is right now, you will have to reprogram it for "home use" as an access point.
What's to be afraid of? Just plug it in to a computer with the FRC Radio Configuration Utility installed and run it, using the Programming your radio for home use instructions.
Unread 17-05-2016, 16:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Remember to run the radio tool as an administrator. Otherwise it may be unable to set your computer network adapter's IP address and the reprogram will fail with a very unhelpful error message.
Unread 17-05-2016, 16:36
pribusin's Avatar
Uber Alien
AKA: Mike 1
Works now - thanks everyone for the quick responses
