Go to Post Result: 44 volts through the DAP-1522. NOT FUN. - DtD [more]
Unread 17-05-2016, 18:58
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
2016 IRI - Rule Changes and Reasoning
Below are the 2016 IRI Rule Changes / Modifications. The goals of the changes was to minimize the impact on robot designed from any changes, assure a rapid flow of matches, increase the challenge for teams and adjust a few areas.
We are posting this now so that teams are aware before confirming their attendance at the 2016 IRI.
1. 3.1.4 Tower Strength = 12 for all matches.
2. 5.5.10 - In QUALIFICATIONS - Defenses will be randomly selected / placed per the details below. The placement will be defined in advance and will change every 10-12 matches to match the robot cycles. There will be no Audience Selection of Defenses.
A. Cheval de Frise
B. Ramparts or Moat
C. Sally Port
D. Rough Terrain or Rock Wall
E. Low Bar (Always in play and in position 1.)
3. 5.5.10 - In ELIMINATIONS - Defenses will be selected by the opposing alliance (Category and Placement, except Low Bar) per the categories below. There will be no Audience Selection of Defenses.
A. Cheval de Frise
B. Ramparts or Moat
C. Sally Port
4. G21 Revision - A ROBOT contacting carpet in the opponent’s SECRET PASSAGE may not contact opposing ROBOTS who are in contact with the carpet in the SECRET PASSAGE, regardless of who initiates the contact.
5. G38 Clarification - Driving over or getting stuck on a boulder while holding another bolder will not be a violation of G38.
6. 3.1.3 No change to defense crossings for RP.
7. R5 A +5 pound weight allowance is provided. There is no formal inspection, however if a referee questions a robot weight it will be verified.
8. 5.4.1 - Draft Order 1-8, 1-8, 8-1. Alliances select their own backup. No requirement for any robot on an alliance to play.
9. G13 Exception – G13 Applies, however, AFTER a robot has fully crossed a defense and returned to the midline, a robot may cross the midline with no foul and contact with an opposing alliance robot will not be an additional foul.
10. 5.4.4 - In Eliminations, up to THREE tied MATCH SCORES between two alliances will be re-played. If the 4th re-play results in an additional tied MATCH SCORE, the published FIRST tie-breakers will be used.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
