Go to Post Come on baby, do the logomotion with me. - JaneYoung [more]
Unread 17-05-2016, 13:24
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Re: what was the best shooting mechanism for 2016?
Originally Posted by Sperkowsky View Post
The best shooting mechanism was the optimized one. Whether it had wheels, or a catapult wasn't the point.
I have seen extremely successful wheeled shooters and catapults as well as extremely unsuccessful wheeled and catapults.
Its all in the execution.
Definitely agree with this. It is all in the optimization and execution...
Originally Posted by TechWaffle View Post
This is just guessing, but the catapult could probably be unreliable sometimes if the springs got stretched out.
Team 230 built a catapult... and we had the 2nd highest OPR at the Championship event. Our catapult was highly optimized (as noted in this post: http://www.chiefdelphi.com/forums/sh...9&postcount=47) ... and it did not suffer from any kind of reliability issues to to springs stretching out, because there were no springs. It is a fully electric catapult, driven by 2 mini-CIMs. The best part about the catapult was that the boulders that were being damaged by the wheeled shooters were not an issue for us as the catapult is unaffected by the size and shape variations.
Unread 17-05-2016, 13:45
Larry Lewis's Avatar
Larry Lewis Larry Lewis is offline
The Spiky Hair Guy
FRC #1511 (Rolling Thunder)
Larry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to all
I feel that "best" is relative to what you value the most. For our team accuracy is the most important over distance, and speed. If you are going to take a shot make it count otherwise you spend more time chasing it down.
We did a two wheeled shooter in 2012 and actually found it to be much less accurate than the single wheel shooters. We thought that going with high speed motors on both sides of the ball would give us more range and having two wheels would make it more consistent but we were wrong. What we ultimately found out was that there is better energy transfer between the wheel and the ball when you give it a curved track to allow the mass to get up the wheel's spinning velocity. Because of this it was more consistent and seemed to go further even with less powerful motors. Ours just kinda burned out on the ball because we were taking something that is not moving at all and all of a sudden trying to get it up to full speed. This varied based on how well the wheels gripped the ball which changed as the wheels got dirty or the balls varied.
Echoing the previous comments I think execution is key and that any design can be successful as long as the time is put in to remove inefficiencies and variability.
Larry Lewis
FIRST Team 1511 - Rolling Thunder
Team Leader
2013 - Present: Systems Engineer - Viewpoint Systems
2004 - 2013: Lead Test Engineer - Harris RF Communications
www.penfieldrobotics.com
Certified LabVIEW Architect
"I haven't failed, I've found 10,000 ways that don't work" ~Thomas Alva Edison
Unread 17-05-2016, 14:44
FRC #1836 (MilkenKnights)
Regardless of type of shooter, there were patterns of thought process that lead teams to consistent, optimized shooting mechanisms.
Every consistent shooter had an optimized shot trajectory. There were two different camps here. One camp set the peak of their shot's parabola at the top of the goal, taking advantage of the vertical goal to maximize the sweet spot of their shot. In fact, many teams had a single, workable shot from the outworks all the way to right in front of the batter. The other camp, including teams like 971 and 987, were able to adjust their shot angle using vision targeting. This camp then used flat shot trajectories, decreasing the impact of exit velocity consistency on shot accuracy.
Additionally, many teams in both camps maximized their release height in order to circumvent the threat of blockers and further maximize their trajectory's sweet spot.
The next variable that posed a threat to consistency was ball variation. As balls were used on the field they became more compressible. Catapults elegantly avoided this variable by never compressing the ball. For the flywheel shooters, minimizing compression also decreased energy transferred to the ball. Thus, competitive flywheel shooters counteracted this with higher wheel surface velocities, more power, and larger contact patches on their wheels. Flywheel shooters also relied on sensor feedback in order to accurately control their wheel velocity. While my team did not extensively prototype the two wheel shooter design, I would also conjecture that the single wheel designs were more consistent because they had less variables to control.
Catapults on the other hand still had a slew of problems to contend with in order to get consistent exit velocities. Pneumatic catapults had to deal with airflow, limited by their solenoids, regulators, pneumatic tubing, and fittings. From talking with some pneumatic catapult teams, I heard that many used high-flow solenoids in conjunction with air tanks after the regulator. Spring powered catapults had to deal with spring wear and consistent release/pull-back points. My team ended up finding success with high-quality extension springs.
Lastly, alignment time was critical in this game, given that teams could only hold one ball. Both camera and flashlight alignment was proliferate, and some teams used turrets to great success, which could align fast and accurately.
Unread 17-05-2016, 16:15
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
I liked 125's catapult. It was integrated into their utility arm, so it was able to shoot from very high up. That paired with its ability to shoot from anywhere on the field made it very difficult to defend against.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 17-05-2016, 17:35
scott.smith's Avatar
scott.smith scott.smith is offline
Inventor guy
FRC #0639 (Code Red Robotics)
Team Role: CAD
Rookie Year: 2015
scott.smith will become famous soon enough
Also 148, the robot with the highest opr at champs, had the highest opr. Catapults are good.
Unread 17-05-2016, 19:05
Kevin Leonard Kevin Leonard is online now
Professional Stat Padder
Those are two examples. They certainly don't constitute a proof, especially if you're basing it solely on OPR.
Why don't we do something similar and look at all the captain and first selections that made Einstein- not necessarily representative of the best, but pretty close.
  • Newton 217, 3476
  • Curie 694, 3339
  • Archimedes 1501, 1986
  • Galileo 195, 987
  • Carson 2122, 2052
  • Tesla 2056, 1690
  • Carver 330, 2481
  • Hopper 148, 1678
Hooded Single Flywheel Shooters:
  • 217, 3476, 694, 3339, 1501, 2056, 2481, 1678
Catapults:
  • 1986, 195, 2122, 2052, 148
Double Flywheel:
  • 987 (horizontal), 1690 (vertical)
Linear Punch:
  • 330
This data could be the way it is for multiple reasons.
  1. These are the best kinds of shooters
  2. These are the most common types of shooters
  3. These are the shooters that happened to make Einstein
But if you look closer at how they got there, you'll start to notice trends.
9/16 of these teams had inarguably high release points. 5/16 couldn't go under the low bar as a result of that.
These teams prioritized certain objectives, and met them 100%. It's obvious when looking at 1678 and 1690's designs that they anticipated needed a high release point, but also needed to be able to get a solo breach. They have the resources to execute that at 100%, so they did.
Other awesome teams on Einstein had other priorities above high release point.
2122 showed up at their first regional just making low goals. They then improved by adding a climber and then eventually their extremely accurate high goal shot. They did, however, shoot from almost the ground.
1986 had a catapult, which allowed for a relatively high release point that would get over most blockers while still going under the low bar.
217, 3476, and 1501 eschewed the low bar in favor of a harder to block shot and a climber.
The type of shooter you choose isn't about which is objectively "the best", but rather which one fits your priorities and resources the best.
(2015-Present)
Unread 17-05-2016, 19:48
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
Originally Posted by Kevin Leonard View Post
.....and 2481 eschewed the low bar in favor of a harder to block shot and a climber.
To the extent of my knowledge, 2481 didn't have a climber.
Unread 17-05-2016, 19:50
You're correct. I edited my post to reflect that. The rest stands.
(2015-Present)
Unread 17-05-2016, 21:36
Amit3339 Amit3339 is offline
B B BumleB
FRC #3339
Amit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to behold
  • Newton 217, 3476
  • Curie 694, 3339
  • Galileo 195, 987
  • Carson 2122, 2052
  • Tesla 2056, 1690
  • Carver 330, 2481
  • Hopper 148, 1678
Catapults:
Double Flywheel:
Linear Punch:
  • 330
Thank you for this great data! I understand that we cant deifne what is the "best" type of shooter. My main goal was to see what mechanism the teams that were successful at shooting this year used. I can say about my team(3339) that we used one wheel shooter and it worked well, we've reached the consistency we were looking for but our main problem, like most of the wheeled shooters was the damaged boulders.
Again, it is obvious that we can't define what is the "best" type of shooter, this disscusion was ment mostly for sharing data and experience about the types that were used by different teams.
2016- Team Captain, Driver & Programming Crew Member
Championship Curie Sub-division Winners| Curie division
Regional Winners | Israeli Regional
2015- Driver & Programming Crew Member
Championship Carson Sub-division Winners| Carson division
Excellence in Engineering Award sponsored by Delphi | Israeli Regional
2014- Driver & Programming Crew Member
Unread 18-05-2016, 09:19
Mattb706 Mattb706 is offline
AKA: Matthew B
FRC #0706 (Cyberhawks)
Mattb706 is an unknown quantity at this point
when we were looking at shoots we looked at wheels but the problem with that is ramp up time. Catapults are wishy washy. So a liner punch seemed like the best design for consistent shots. But most teams had wheels.
Unread 18-05-2016, 09:47
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
We didn't worry about ramp-up time as much because of the fact that robots can only carry one boulder. With only one boulder to shoot, you only need to make sure that your shooter gets turned on sufficiently ahead of time (for us we turned it on right after crossing the outer works). Another neat trick I've heard of is that some teams leave their shooter running at half speed or quarter speed for most of the match so it takes them less time to spin up.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 18-05-2016, 10:50
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
I'm curious about how you came to this conclusion. Our catapult could shoot from any legal spot on the field.
Unread 18-05-2016, 11:42
I'd love to know how your catapult was powered. One of the bigger advantages to a catapult in my opinion is that you can make it have a consistent amount of power with relatively little programming by using springs, pneumatics, and hard stops.
Now there are ways to make each of these methods shoot from multiple positions, and also ways to make your trajectory flat enough to shoot from a ton of different locations with the same shot.
I'd love to hear about how some of the best catapult teams made their catapults work this year.
(2015-Present)
Unread 18-05-2016, 11:59
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
1493kd will become famous soon enough
Ditto, I would love to see some more details of your catapult. I loved watching your robot put shot after shot in the high goal. I figured it was spring or pnuematic powered.
Unread 18-05-2016, 12:59
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
No springs or pneumatics. It is a fully electric catapult powered by 2 mini-CIMs. Steve describes it here:
