Go to Post I think the winning robot will be the same as every other year, a robot that is excellent at ONE thing. - Kel D [more]
Unread 17-05-2016, 20:55
bdaroz's Avatar
bdaroz bdaroz is online now
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Re: 2016 IRI - Rule Changes and Reasoning
Originally Posted by Chris Fultz View Post
10. 5.4.4 - In Eliminations, up to THREE tied MATCH SCORES between two alliances will be re-played. If the 4th re-play results in an additional tied MATCH SCORE, the published FIRST tie-breakers will be used.
I read this twice but this might warrant a confirmation/clarification...
You mean this to say: "... the published FRC tie-breakers will be used on the 4th re-play" as opposed to "... the published FIRST match tie-breakers will be used."
Yeah, I'm probably lawyering this a bit, but in case anyone else read it the way I did....
